3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Steampunk Goggles: Personal Vision Enhancers
These Steampunk Goggles inspired by, amongst others,  the work of Gogglerman on Instructables and Jake Van Slatt at The Steampunk Workshop, are an attempt to combine the Steampunk aesthetic with production of some functional eye-wear which would produce excellent lighting and variable magnification. I use commercial loupes in my day-to-day job and have an old pair for use in my shop as needed, so really this was just an excuse to make something I considered aesthetically pleasing, satisfying to make and well into the Steampunk genre. I apologize for any lack of detail, but I would think that this would be more of an inspirational jumping-off place to go out and make something of your own, rather than a detailed "how-I-did-it" account.
Step 1Making The lens Holders
  • last photo ←
The actual goggles, the part that holds the lenses in front of the eyes is the body of the design, just as the frame holds the spectacle lenses. I made these from 1/8" recycled brass sheet which I got at the metal recycling plant. I annealed the sheet by heating to red-heat with a gas blowtorch and then quenching in cold water, before cutting with tin snips to fit the paper template. Annealing makes brass and copper soft and easier to work with. I used a stainless steel former, again acquired from a scrapyard, around which to bend the sheet and held the curvature with a wire wrap before soldering. The external brass ring was used for aesthetics rather than because it was absolutely necessary.
20 comments
Dec 30, 2011. 3:06 PMdoomsdayltd says:
dear god those are beautiful
May 7, 2012. 3:11 PMzorwick says:
Very interesting project! Congratulation!
Jan 22, 2012. 4:08 PMFinchbyFinch says:
what kind of gas did you use with your blowtorch when working on the brass? will propane work?
and also, what kind of solder did you use? did you use a soldering iron for it or did you use the blowtorch?
Jan 8, 2012. 2:37 PMacoleman3 says:
" I would think that this would be more of an inspirational jumping-off place to go out and make something of your own, rather than a detailed "how-I-did-it" account."
sorry but your're rather wrong on that. for those who have no idea on what they're doing....have no experience in your field....its too difficult to fathom making something this complicated. it ends up being a jumping point into the depths of nowhere.
Jan 11, 2012. 7:36 AMlongwinters says:
I am currently on my first pair of Goggles, already I have made 2 pair of iris I'm on my second complete frame and about to completely redo a lens assembly,
WHY would I mention this to you? Because the thing in your mind needs to come out as you saw it. What stinks is the amount of work your hands must do to get what your mind thought up so easily.
One of my problems when doing a project like this is when you have a great idea for an assembly and when you go to do it you see physically it can't be done, conflicting intersection points or it's an incompatible sub-assembly.
If you decide to do another similar project, (and I hope you do) here is a hint that may help, a bench buffer, grinder with a wire wheel will eat away excess solder when curves and small areads need the solder cleaned away.
Wonderful project, and best wishes to you.
Bill
Jan 8, 2012. 1:01 AMT-Hawke says:
Very Interessssssting! It does look heavy, I think that is what I like about it though. Improvisation (Mothers Milk of Steampunk in my opinion) and the "crudeness" of the piece. Excellent. Can't wait to see your next pair of goggles or your next piece.
Well done.
Jan 10, 2012. 1:18 AMT-Hawke says:
I will be watching. Thanks for the heads up.
Jan 8, 2012. 12:00 PMArty Marty says:
Very very nice!
I am studying Jewellery making at the moment, and have been making art/sculpture/props/weird things for years, and you do have the creative/artistic gift.
Believe me, its actually rare. ;o)
I will be making something like this for sure, it will give a good laugh to my fellow students, and freak out any of the more 'square' teachers hehe All this while being practical.
If you have a set of metal rollers, you can roll out the metal after annealing it, which will make it go a lot further, and drastically decrease the weight. all the curves in this will ensure its still rigid with the thinner metal.
Amazing stuff mate!
Warmly, Marty
Jan 9, 2012. 8:19 AMmaskhunt says:
gorgeous...i want one...
Jan 7, 2012. 12:23 PMcoolgirl75 says:
This project shows that you have unusualy creative abitilies.
Jan 8, 2012. 10:24 AMdthomas-1 says:
It's refreshing to hear you say that. I get frustrated that my designs generally look far better in my head than Im able to produce. These are really great looking goggles and something to be proud of. Even if it doesn't match up with what you envisioned. In terms of being a jumping off point for inspiration, you succeeded wonderfully. Thank you for sharing this.
Jan 8, 2012. 7:59 AMKomaToast says:
Wear them at the airport.
Jan 3, 2012. 4:02 PMPenolopy Bulnick says:
Very intense! Awesome!
Dec 31, 2011. 3:55 AMgogglerman says:
I like it! A complex and interesting project. Develop your skills in soldering and metalworking. You are on the right way, I think.
Very flattered that you mentioned my name :)
Happy new year!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:cutshopguy(Tristan de Chalain)
