If you have a CFL bulb installed in an illuminated wall switch (these are switches that are lit when in the off position), this instructable can help stop the flashing.
First, why does the CFL bulb flash? Many times this is due to the circuit inside the CFL charging up, even when the bulb is off. This happens many times when the CFL bulb is being controlled by an illuminated wall switch, because the wall switch uses the CFL bulb itself as neutral. When the wall switch is on, the CFL bulb gets full line voltage. When the wall switch is off, the CFL bulb is the neutral for the light of the wall switch, causing a tiny current to flow through the CFL bulb.
This tiny current charges up the capacitor in the CFL bulb, until it releases it's energy. This cycle can repeat once every few seconds.
Remove these ads by
Signing UpStep 1
To solve this flashing, what you want to do is put a bleeder resistor inbetween the two contacts of the light bulb. What this resistor does is cause the tiny current to pass through it, when the wall switch (or whatever causes the tiny current) is off, instead of charging the capacitor of the CFL and causing it to flash. This only works if the current is really small. If the bulb is flashing every second, the current may be too large for this to work effectively. In my case, the CFL bulb was flashing every 16 seconds, and 240k Ohms of resistance solved the flashing.
1) When you change the bulb, you lost your enhancement. Is it possible to make it on the lamp socket instead of on the lamp?
2) Does Increase appreciably the electric intake this improvement?
As for the increase in load, it would be something really small (basically can be ignored), assuming 110V and 240k ohms, it would cause an additional 0.4mA or so of current, which equates to a wasted 0.04 watts.
I've noticed that most of the energy saving bulbs do not last as long as the manufacturers promise.
