3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Stylish Chopsticks With Toothpick Storage
These chopsticks are easy to make, look great, and have a hidden compartment to store toothpicks or anything else you would want to store (but mainly just toothpicks).
Made of hardwood and aluminum tubing, they are low cost and durable, allowing them to be reused many times.
Also, using your own utensils over and over again helps reduce the cutting of trees to make new chopsticks (albeit by a very tiny amount).
Step 1Materials
materials
All you need for this is a 6mm dowel and a piece of 6mm aluminum (or really any kind of metal) tubing.
In the spirit of re-purposing, I used an old Airsoft barrel I had lying around for the tubing. All I needed to do was to wash it thoroughly to remove grease.
Both tubing and dowel can be found at any good hardware store or home center.
You could also cut up an old pair of chopsticks to use in place of the dowel, but I didn't have any.
At my local Ace Hardware (Northern California) you can get materials for four pairs of chopsticks for $7.50.
3 comments
Aug 14, 2011. 1:18 AMacoleman3 says:
also a bloody good way of making collapsible hashi for ease of transport. like.....putting them in a pack, if you carry one around, so you always have them with you. although i *would* use brass 'cus aluminium is slightly toxic and the oxide rub off turns your fingers dirty. ....but cudos to you for re-using the airsoft barrel. quite brill of an idea there.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:ilpug
I am a High School Senior in the heart of Northern California, and i have been making things as long as i remember. I am on track to become an Engineer when i get to college, and i would be happy to h...
more »
