3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Super Specs - 3D and much more
The title for this Instructable was really hard to pick because these Super Specs have so many uses.
So many uses? Let’s list a few:
* 3D stereo glasses that will work on any screen that uses passive split polarity for 3D regardless of brand.
   (Will not work for electronic switched 3D stereo.)
* 3D stereo glasses that work with any color code of anaglyph (common type of color coded stereo image).
* Preview a scene so you can see how it will look when you later photograph with a filter.
* Magnifying glasses with a whole range of magnifications.
* Sunglasses with any shade of darkness or color you like.
* Exploit the extended sensitivity of human vision to see infra red light.
* Protect your eyes from UV or just about any wavelength of light.
* Have different things happening with each eye.
All this and more from one pair of glasses by simply screwing in your favorite filters in a few seconds. Moreover you can make a pair of these quite cheaply in about an hour if you already have the parts.
OK, OK there is a little catch; to achieve all this you are going to have to get various camera filters to use in your Super Specs. I can guess you are thinking “Oh Oh! This is going to be expensive.” But there is a way to get a whole range of cool camera filters that are very cheap and will still work on your camera too: get them on eBay and try clicking that box so you can search worldwide; what you need are the Chinese suppliers. I have bought polarizers for as little as $3 and you can often get bundles of mixed camera filters for less than $20 all brand new.
Having said that I guess it will be no surprise that I bought everything for this project on eBay. Even though I did the purchasing some months ago, I have done fresh search to get prices for the parts list (including postage). Your mileage will vary depending on patience and luck finding bargains.
To attach the filters to the lenses so that they can be easily unscrewed and changed I glued two lens adapter rings into the glasses frames.
(Please vote for me, I would really like to win the Epilog laser cutter. Thanks)
Step 1Step 1, What you will need:
Listed below are the parts you need together. It pays to be patient and wait for bargains. Get the glasses first and measure them to determine the size of the adapter rings and filters. I was lucky, my first pair of "Ga Ga"s were just the right size for 52mm-55mm adapter rings and my camera filter collection for my FZ50 are all 55mm.
If you plan to screw in heavy filters or lenses (for example fisheye lenses) then you may need a glasses frame strap to keep them on your face.
Parts List:
One pair of “Lady Ga Ga” fashion glasses or other glasses with large circular framed lenses. ($13.20)
Two lens adapter rings to fit the glasses. ($1.82 each)
At least one pair of filters to start. eg. 2 circular polarizers at $6.18 each.
Some metal/plastic adhesive (eg. 5 minute Araldite) (You only need a tiny amount.)
So all up less than $30 or much less if you have filters already for your camera.
Tools:
Miniature (Jeweler’s) screwdrivers
Dish of boiling water
18 comments
Mar 10, 2012. 9:11 AMsanty22 says:
Haha, this is inventive. I'd love to see some steampunk brass Super Specs.
Apr 23, 2011. 9:55 AMlschwartz says:
I first encountered pseudo-3D glasses at a Smithsonian Institution presentation. Their glasses were cardboard with a tinted, non-polarized, filter over one lens. The 3D effect was explained as a result of the brain interpreting darkness as an additional indication of depth. I've used one side of broken sunglass for over 20 years to achieve the effect. Any movie theater showing 3D movies based on polarized images will freely give you a pair of their glasses. Just punch out one side and PRESTO! For the effect to really work, there should be some movement in the screen image. If your particular glasses dim the TV too much, just increase the TV's brightness.
May 17, 2011. 6:11 AMwobbler says:
It's known as the Pulfrich Effect ref http://en.wikipedia.org/wiki/Pulfrich_effect and is usually shown by using a pendulum swinging side to side. When a dark filter is placed over one eye, the pendulum bob appears to swing in a circle. I'll have to try it with TV!
Mar 20, 2011. 5:06 PMstringerR says:
I sometimes use elastic support for my normal specs so they don't slip down my nose.
The super glasses is a great idea and I think they would be comfortable for a long time with my type of support
Mar 17, 2011. 10:58 AMkillbox says:
Note stacking most CPL filters wont get you the total blackout stacking non circular polarizer filters will. so if you want to "dial-A-dark" pickup 2 CPL's and 2 regular polarized filters (or another trick is to get 4 CPLs and dissasemble 2 and flip the glass over)
learned alot about all that when was making steampunk goggles. http://www.flickr.com/photos/killbox/4475363810/
Mar 17, 2011. 3:28 PMkillbox says:
Yah, even cheap cpl's and a normal polarized layer/lens/screen will work, but if the light is going the same direction through 2 same cpl's the 2nd layer causes a roll in the polarized light which the 2nd filter lets through.. (flipping the glass over in the front lens or using a non CPL P filter, works.
odd effect of polarized filters CPL or not, is if you try and see your own eyes in a mirror though your glasses the lenses will look totally dark. as the light from behind the lens is filtered then hits the mirror and is filtered coming back.
Mar 17, 2011. 6:48 AMsnafell says:
Hi,
What type of glue did you use?
Mar 17, 2011. 3:17 PMsnafell says:
Thanks,
maybe I should speed read less
Mar 15, 2011. 4:38 PMNemesis201077 says:
These look like a great addition to my lads night in attire for watching footy on the 3D TV, when I can finally afford one (or a clever instructabler makes one).
I think I'd have to go one step further and pair these with a leather flying helmet fitted with earphones. The googles could be altered to accept an elasticated strap.
Very clear instructable too.
Mar 17, 2011. 8:51 AMsrilyk says:
I'm going to make these steampunk-style.
Mar 15, 2011. 5:25 PMilpug says:
man, i would just wear these for sunglasses. if they work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:Light_Lab
