Tatted Mask
Tatted Mask
  • last photo ←
My tatted mask is made with cotton thread, swarovski crystals and a few small pieces of wire. You will need an intermediate to advanced knowledge of needle or shuttle tatting to complete this project including split rings, josephine knots and adding beads to tatting.
This project uses size 10 crochet cotton thread, size 5 tatting needle(or shuttle), 45 3mm/4mm swarovski crystals, 1 piece of wire at 6.5cm and 2 pieces at 17.5cm, jewelry pliers, scissors, steel crochet hook (optional for joins)
If you need help learning tatting check out Bella Online or join the tatting group Intatters.
This mask as well as many of my other tatted creations can be found in my Etsy store. If you have any questions or problem, please let me know. This is my very first instructable so I'm certain it's a bit of a rough draft.
Happy tatting!
Step 1Wire Eyes
Wire Eyes
Using your own eyes as a guide form an almond shape with the 17.5mm wire. Fold over at the corner and use the pliers to tighten down. You may cut off excess wire if desired, but it's not necessary as the wire will be covered by thread in the last step.
116 comments
1-40 of 116next »
Nov 9, 2011. 11:11 PMMajikTime says:
I made the same mistake as everyone else even after reading the whole pattern before starting. Instead of trashing the whole project (put to much work in to do that) I substituted a ch 6 starting from where I mistakenly joined to the first round, and then continuing on with 5 clovers.
Apr 28, 2011. 3:56 PMmisssweetie2u says:
i love the mask. any specific kind of faux rhinestones?
Oct 2, 2011. 8:40 PMpaqrat says:
The mask is beautiful and very cool. Hopefully this won't come across as creepy but its very sexy. I think, however, it would even be better without the swarovski crystals. To me they are gilding the lily. Great work.
Sep 17, 2011. 4:15 PMAnimeEyes19 says:
so pretty!! :)
Apr 6, 2011. 10:26 PMNaturalCrafter says:
Though I may be a bit late replying to the post, I love this and always wanted to try tatting.
Aug 15, 2009. 3:07 PMclaws.33 says:
very confusing because this mask is not the same as the one in step 4. there, the side medallion is already attached where it says to attach first here...
Mar 23, 2011. 7:43 PMjvaujin says:
Step 4 is all medallions. Starts at center medallion and goes to side then says to mirror prior steps which would include connecting the side picot of side medallion.
"6ds 1p 3ds 1p 3ds join to side picot of side medallion 6ds cl rw" "Continue around mirroring the top edge"
Mar 21, 2011. 9:11 PMjvaujin says:
As much as I love your mask, your instructions are hard to follow. You seem to leave out certain key points which I have only been able to discover after referring to the photos and tearing out a good portion of my work.
The center ring (last one written out) should be connected to the ring before it as well should it not?
And it would be helpful to say "ch6 cl rw, r 3ds+3ds connect to medallion picot 3ds 1p 3ds cl rw" so we have a perspective as to where we are suppose to be.
(it would have been nice to have the "+" explained earlier as well seeing how many people had issues with that step)
Mar 14, 2011. 10:46 PMchaitanyak says:
wow! and i thought your sandals instructable was sexy!... this is brilliant!
have followed here and on twitter
Mar 10, 2011. 5:44 PMTanya Snively says:
A intricate and lovely piece. Thank you for posting!
~Tanya
Mar 6, 2011. 7:51 PMWhyHello says:
wish i could fav this =( already working on leads of instructables
Feb 25, 2011. 6:25 PMThamarBerber says:
One more question: Are the mask and necklace one piece?
Because I also would like to make the necklace as well.
The mask & necklace are so pretty together!
So if it's apart from the mask; please, make an Instructable for the necklace as well!
Feb 8, 2011. 1:29 AMdesmondtheredx says:
OMG you are so sexy bet u would look even more pretty without the mask, I would have flirted with you if I knew you
Jan 4, 2011. 9:30 AMcyberdork says:
Inconceivably gorgeous and sexy. It would make my brain melt If I ever saw a woman wearing that somewhere around me.
Jan 27, 2011. 7:07 PMlunius says:
And she doesn't look half bad in it either, I have to say.
Love the mask idea, and I'm definitely learning to tat now. I already make some papier mache venetian style masks, and those make good money, but now I will start making these and just adding more flair to my selection!
Jan 27, 2011. 5:29 PMThamarBerber says:
I saw your picture with the mask, and I think it's awesome!
Tomorrow I will buy the necessities, to try and make something for myself first.
I might have found a new hobby.
Jan 19, 2011. 2:08 AMmarylee512 says:
On etsy there is a woman with areally cool arm tattoo. What does it say, and is there a pic of the whole thing?
Jan 17, 2011. 8:35 PMKeira_Yagami says:
Thanks for the Instructable! I saw your Etsy store a few weeks back while looking for Masks for our Masquerade Prom coming up in a few months. I really loved the mask, but a little expensive for my tastes, looks like Ill be making my own now, Thanks!
Dec 26, 2010. 4:54 PMLizzieR716 says:
i am very very lost... im not new to tatting and i know how to make split rings but i just cant figure out how the three rings work onto the top of the clover.
Outside: ring(r) 8ds join to center picot(+) 8ds close(cl) reverse work(rw), r 4ds 1p 3ds 1p 1ds cl do not reverse(dnr), r 1ds+3ds 1p 3ds 1p 1ds, Split ring(sr) 1ds+3ds/4ds cl rw
i get to here and then get stuck: r 1ds+3ds 1p 3ds 1p 1ds, Split ring(sr) 1ds+3ds/4ds cl rw
am i supposed to close the ring before starting the split ring?
Dec 19, 2010. 5:00 AMPhilomela Sidhe says:
I did the same mistake... In the first picture for step 5 it looks like the side medallion is connected, and the description sounds like that. only by a second veeeery close look (of course after i did the mistake *sigh*) i saw that it isn't ...
but it works with the mistake too ...
Dec 8, 2010. 1:30 PMaly572ymail.com says:
Hey Michele;
Thank You so much .
I'll keep it in mind.
As always; great idea.
Love Always Alejita.
Oct 18, 2009. 8:45 PMDrCoolSanta says:
I don't have to say that the mask looks pretty hot... And the first pic, totally sexy :D
Nov 10, 2010. 11:40 AMWingDings says:
Agreed! :)
Oct 28, 2010. 6:57 PMnebulous1 says:
Just wanted to let you know that I think you're madly talented!!! Your designs lead one to believe that you are certainly a romantic, and perhaps even tragic soul. Roses that don't die and spidery black wrought iron designs in funeral lace. This purple prose is not nearly as rich as the art which inspired it, but the most suitable compliment I could think of in response to the beauty I've beheld in your creations. Your designs are truly...immortally beautiful.
Oct 12, 2010. 8:11 AM383417477 says:
wow~so beutiful~i like it~@,~
Aug 22, 2010. 4:48 PMchiapetrescue says:
This is awesome. I tat, and I'm always looking for new ideas. I never thought of making a mask! Great work, you have inspired me to get more creative with my tatting projects.
Jul 20, 2010. 9:44 PMTarantulady says:
This is just awesome and a real creative twist on an age-old method. A really elegant look, too. And you wear it so nicely! Great job. Nice dye job on the hair too.
Jun 15, 2010. 4:17 PM1aminstructable says:
I am impressed. My grandmother used to tat doilies and hand towels and the things expected (then) to be added to your home. Every now and again I buy a shuttle and an instruction book, but I never get started. Incorporating the crystal and wire may get me going as I am into jewelry making. Kudos to you for being part of keeping a very cool skill alive.
Mar 16, 2010. 7:06 PMShadowJesus says:
amazing:]
Mar 14, 2010. 5:10 PMRavenShadow519 says:
This is absolutely beautiful, it sparked emotion in me! well done!
Mar 11, 2010. 11:40 AMtonyaomps says:
Very awesome! I think this mask is amazing!
Mar 10, 2010. 3:29 PMglassy_lassy says:
This is the stuff of fantasy!  You are incredibly talented, thank you for sharing this!
Mar 8, 2010. 5:29 AMhandmadebeginnings says:
WOW that is beautiful!
Feb 28, 2010. 9:07 AMPurocuyu says:
the mask, of course, is incredible, but so is that necklace.  Is the instructable for the mask something we can look forward to?
Feb 12, 2010. 8:40 AMknottynaz says:
Beautiful! and I found it just in time for Mardi Gras! Oh, and Valentine's Day! Oo-la-la!  "Laissez Les Bon Temps Roulez"
Jan 22, 2010. 2:16 AMpiper1234 says:
haha a spiderweb on face :P watta imagination, it look like venetian carnival masquerades style, somekinda like iron forge very original indeed, and looks like big filigree  ; )
1-40 of 116next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
407
Author:TotusMel(TotusMel Tats)
I'm a tattooed needle tatter, a stay at home mom and a homeschooler. I sell my work on etsy. I hope to offer a few patterns more here as I get the time. You can also follow me on twitter as TotusMel a...
more »
