Tea Light Lamps (an Easy Last-Second Gift)
Introduction: Tea Light Lamps (an Easy Last-Second Gift)
Homemade Holidays Contest
Runner Up in the
Make a last-second gift, with long drink glasses (possibly used ones), tracing paper (or inkjet transparencies) and tee lights. It's really easy!
You can change of design whenever wanted, or revert the glasses to their initial function.
How are the candles placed and lit? read on...
If you like this instructable, please vote for it! TiA.
UPDATE Jan 13, 2010: Runner-up position in the Homemade Holidays Contest!  A big thank you to all who voted for this entry!
Step 1: Needed Stuff
  • Tracing paper, or inkjet transparency sheets
  • Narrow and tall glasses (thick enough to contain a tea light), as straight as possible
  • Tea lights
  • Steel wire (1.2mm thick), or brass or copper wire (2.5mm thick)
  • Clear adhesive tape
  • Cutting mat
  • Utility knife
  • Pencil, cissors, ruler
  • Pliers
  • Laser printer (for tracing paper) or inkjet printer (for inkjet transparencies), and computer
Step 2: Make Candle Holder
Bend the wire as shown to hold the candle safely.
Optionally, add a bead at the top end, and stick it carefully with epoxy, reliability counts here!
Step 3: Measure Glass, Design and Print Tracing Paper Sheets
With a paper band, mark and measure the upper and lower diameters, and the height of the glass. Add 5mm to each length.
In your favorite drawing software (e.g. OpenOffice Draw), create a trapeze of measured sizes to mark the borders, and import a picture of your choice. Size it to fit into the trapeze.
Personally, since I only had tracing paper on hand, and after some trials, I choose some black/white Japaneses patterns:
  • tracing paper prints best with a laser printer (with inkjet, it will form a roll when still wet).
  • The contrast is maximum, with lots of black areas (which will give a more intimate atmosphere);
  • tracing paper is a great diffuser on white areas.
With inkjet overhead transparencies, you can use any colors you like. Instead of white areas, use light colors to serve as diffuser.
Step 4: Cut and Place Sheet
  1. Cut the bottom side, and one vertical side
  2. Stick tape on the inner side as shown (see image notes)
  3. Wrap the glass and stick the paper to the tape. The paper is sticked to itself, not to the glass. Align the paper to the bottom end of the glass
  4. Cut off excess paper on the top end of the glass
  5. Remove the glass, cut off excess paper, put back the glass into the paper
  6. (UPDATE 2009-12-27) When becoming warm, the tape might come off by itself. Apply one or two small drops of glue to fix it.
That's it!
Step 5: Done!
Use the holder to raise the candle and light it. Enjoy your lamps.
Candles are no toys, handle with caution
Never leave unattended
Thanks for reading. If you like this instructable, make some and post your best ones!
  • Science of Cooking
    Science of Cooking
  • Pro Tips Challenge
    Pro Tips Challenge
  • Pocket-Sized Contest
hi, laxap
i totally dig your project. i went through the comments to see if anybody had inquired about using tissue paper and decoupage glue. i was surprised that they went as far back as six years. i made this other instructable https://www.instructables.com/id/How-to-make-a-uniq... a few years back, and was wondering how you felt it would work out with your project. this way you didn't have to worry about the tape coming loose.
congrats on a sweet ible!
is it possible to use wax paper or something like that?
I don't think that you can print on wax paper.
Maybe you can print on regular paper, and, as a very final step, carefully oil it to make it translucent. I don't know what will happen to the ink... I suggest you to try and tell us.
A no-printing variant (see picture below, and notice the spiral sign): you can use translucent decorative paper, possibly textured. If you want to make signs, you will need patience, an x-acto knife, and to glue the paper to the glass.
 Actually, you can very easily print with an inkjet printer on wax paper. I know many people use that for making transfers to go on fabric. I'd think if anything the concept might open even more decorating ideas.www.instructables.com/id/Inkjet-Printing-on-Fabric/
Jaie, if you are still watching this thread, thank you for the link. I might use it sometime to make transfers. But I think people should be let know that it is not wax paper that is used for that purpose. The site you link to uses freezer paper; the two are not the same. When I was a kid, before there was freezer paper (so far as I know), there was wax/waxed paper, and that was what mothers used to wrap kids' sandwiches. I've never tried, but think it would be too waxy to print on.
Would that be like parchment paper?
Yeah, I found some semi-transparent paper laying around. I was just looking for options that didn't involve spending 30+ dollars on 50+ sheets of clear plastic just to make 3. But I also came up with an alternative to buying 2.5 mm wire. (what gauge is that by the way?) But I had some somewhat fine copper wire that I folded over 4 times, and then put an end in an eye hook and then grabbed the other end with needlenose pliers, and i then put the eye hook in the drill and spun the wire to make a thicker wire, once again so I didn't need to go buy tons of wire for a small project, because I had the fine wire already. Great instructible, I will post pictures of my results when I am finished.
Another easy alternative if you don't care about the wire gauge is to use wire coat hangars. They are pretty thick but they still get the job done.
