This prototype was built with the Coach House Trust in Glasgow, using bottles from their recycling centre, and wood from the maintenance of their own sites. You can use any found timber, and adapt the dimensions to suit the wood you are working with.
Some examples are for sale at our shop here.
Design is released under a share alike/attribution CC license by Zero-waste Design.
shelf assy.pdf42 KBStep 1: Get your bits n bobs.
Four bottles. All the same brand/height/shape preferable. Wash them thoroughly in hot soapy water.
Two hook and eye strainers / turnbuckles as they are sometimes called. I used the smallest I could find, which are 14mm OD at the buckle and 5mm OD at the threads. Such as these from Screwfix.
Two planks of wood, prepared as shown in the .pdf template - careful! there are two different hole diameters, and if you are leaving one rough edge as I did here, make sure you take your measurements from the straight datum edge.
*REVISION* I would now NOT drill the holes in the lower shelf (the 30mm ones) all the way through, but drill them from below to half depth, using a flat bit. They will then rest on the tops of the bottles of the module below, rather than allowing the necks to pass striaght through as was the case in this prototype. (See discussion in comments)
Screw in the cup hooks halfway between the holes on either side, as shown. Depending on the height of your bottles, you may need some ess hooks too to help the strainer reach between the upper and lower hooks.
Step 2: Place the bottles and top shelf
Step 3: Tense up!
Step 4: Assemble into a larger unit
Step 5: Experiment!
The tables are just the same as the shelving modules but flipped upside down, and without holes in the shelf at the base of the bottles (the table top).
More info at www.zero-waste.co.uk.
I would be up for trialling the new 'Collaborate' feature of instructables with someone on this project. Message me if you're interested.
Visit Our Store »
Go Pro Today »
Does that sound like a good idea?
Also I am assuming the eye hooks are to prevent sway from side to side as well?
any ways around this?
Thks
i used to work in a winery, and would walk on wine bottles all the time. never tried a glass, but the bottles never flinched. you could stack a lot of weight on a bottle.
scrabble cheat scrabble word cheat
http://www.rogiermartens.nl/2010/08/27/362/
Makes a nice clean display system.
Time to head over to my brothers for some wood.
Steve
http://scrabblecheat.com
Thanks!!!
Just drill a tiny hole into all the middle shelves and lead a wire through them. Put hooks into the top and bottom ones and connect it to the turnbuckle with the wire.
I used beer bottles and hung it on the wall www.facebook.com/photo.php
For my part, I used 250mm high beer bottles here, with approx. 30mm thick timber, each unit weighing approx. 8 kilos. The lowest unit would need to take 16 kilos before loading, so I tested it to my weight, about 55 kilos (yes, I'm real skinny!). That way I knew I could put on at least 39kg of stuff.
Hooray for empiricaldata!
