Ten Green Coffee Table - from reclaimed timber and glass bottles
Ten Green is a shelving and table system, constructed simply from local recyclates. This range started with shelving/table modules and continued into small shelving units, big shelving units and now coffee tables.
This document will tell you how to construct a Ten Green coffee table. You can use any four bottles of similar height and any found timber, adapting the dimensions to suit the wood you are working with.
I will happily make up kits to order for UK customers.
If you have bought a kit go straight to step 2.
Design is released under a share alike/attribution CC license by Zero-waste Design.
Step 1Get the hardware
Get the hardware
For one table you will need:
Four hook and eye strainers / turnbuckles as they are sometimes called. I used the smallest I could find, which are 14mm OD at the buckle and 5mm OD at the threads. Such as these from Screwfix .
Four screw eyes and four screw hooks, of a gauge to match the turnbuckles.
Depending on the height of your bottles, you may need some ess hooks too to help the strainer reach between the upper and lower hooks.
Two pieces of reclaimed wood at least 25mm thick. Here I used some small pallets provided by the customer. Ensure the timber is rot free. Trim the boards square and to the dimensions required and sand to a smooth finish. If the board is constructed out of many pieces joined together, as in the example, ensure all joints are well secured as the board will be subjected to bending and shear forces.
Drill four holes and attach the hardware as described in the layout image (also in .pdf and sketchup format). I can not emphasise enough how great Forstner bits are for this job! (pictured).
UPDATE 28/01/11: I have added some proper engineering drawings in .pdf format below. Also the source file packs in Solidworks 2004 and .stl formats.
Ensure that the screw eyes and screw hooks are securely held into the timber as they may be subjected to anticlockwise twisting - you may require pliers or a similar tool to fully screw in the hardware. If the timber does not allow a secure fixing, consider gluing in the fixings using a two part resin or using bolt through fixings.
22 comments
Dec 22, 2011. 4:00 AMslysimon says:
Really very nice tables. Great idea and instructable.
Dec 15, 2011. 10:05 AMdvanbeck says:
My sister and her boyfriend moved recently and they don't have a lot of the essential living room furniture yet. Being that they are wine enthusiasts, I decided to make them a coffee table like this for Christmas. I just finished the table today - here are some pictures.
I used 4" and 6" wide boards from Menards, cut to 4' lengths to make the top and bottom and then stained them with a dark polystain (satin finish). I think it really made the boards look more vintage/reclaimed.
This is my first time making any sort of furniture, and now I want to make more!
-Danielle
Nov 11, 2011. 5:14 AMzipperboy says:
The filling the bottles with concrete is a good idea for both looks and strength. It would be just as strong and as good looking to use the cable and screw eye bolt system as per the coffee table. If you used 2 cable loops in a square shape, one per side, you could fasten them together by unwinding the cable ends and creating loops, The trick to getting the loops to turn out nice is to get a good clean cut on the cable end. Hammering the cable over the blade of an old axe works well. Once you have your loops, loop eyed together you can then use pre-stretched rope to tension it up giving you a hour glass sort of shape to the cables on each side.
Make a small loop at one end of the rope, then around outside of one or both cable sides, then pass the other end of the rope thru the loop and pull back using the loop like a pulley. Rubbing the rope with ordinary wax will let it slide tight easily without breaking on you. With a strong cord you could likely get enough tension on the cables to pluck them for a note or too.
The beauty of using this idea is you cut the cost in half or more for the parts needed, as large turnbuckles are your most expensive part in that build. to stop the cables from cutting the rope place a small piece of strong fabric or rounded piece of scrap metal sheet etc. under the rope where it passed over the cable. These scraps can be removed later.  small copper elbows would work well and might look nice too.
Cheers, Phil aka zipperboy
Sep 22, 2011. 2:43 AMdigitworld says:
WELL DONE!!!
Aug 19, 2011. 10:00 AMBrutalMastodon says:
If you were worrying about the bottles breaking, couldn't you fill them with a quick-setting concrete?
It would give the table a more "industrial" look, also.
Jun 14, 2011. 10:27 PMmcraghead says:
Very cool. I wonder if just one big beefy turnbuckle in the middle would work?
May 29, 2011. 9:07 AMmedalhead says:
I have been so impressed, i just rebuild the table!
Mine looks like this :)
May 29, 2011. 9:13 AMmedalhead says:
Edit: I put some wheels onto it, so if you want to put the table beside a little, the load to the table is less.
And also i used smaller ones of these metal things to tighten the 2 plates and some ropes. the big ones were much too expensive...
Aug 8, 2010. 7:14 AMdbbd says:
Can the bottles break if you tighten too much?
Aug 5, 2010. 3:56 PMBoowiggins says:
Art
Aug 5, 2010. 12:37 PMdoctoral says:
I know of some ice tea bottles that would be perfect, I also have some plastic half gallon sizes in mind . and different shapes. oh the possibilitie are endless .
Aug 5, 2010. 9:18 AMhammer9876 says:
There are some very nice looking wine and booze bottles out there that would look great for this. You could also fill the bottles with colored water, sand, sea shells, buttons, photographs, anything small enough to get in the neck of the bottle, including ships! This is a very interesting idea that could be endlessly personalized. Thank you.
Aug 2, 2010. 5:56 PMluvit says:
after i made this i talked to it.
Aug 2, 2010. 2:44 AMKiteman says:
That is an excellent, and visually attractive, piece of furniture.
Is it my imagination, or do your projects show that you have a lot of bottles of booze that need recycling? ;-)
Aug 2, 2010. 10:22 AMoctopuscabbage says:
Im sure you could ask your local bar to hold onto some bottles for you.
Aug 2, 2010. 5:45 AMThe Art of Airsoft says:
i like the idea of using the screw top bottles as feet for the table that just seems to work for me
Aug 2, 2010. 4:59 AMoctopusses says:
Your design is absolutely gorgeous! Simple, elegant, functional. Thanks for sharing.
Aug 1, 2010. 9:13 PMCulturespy says:
Have you made these with more than four bottles? Maybe a round table or a long one?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:royshearer
I am a freelance design engineer and drummer. My business site is at http://www.zero-waste.co.uk and is often concerned with appropriate technologies, open source design and design for sustainability.
