This Instructable is for testing a transistor after it has been removed from the circuit. When removing it from the circuit, always use a heat sink to protect the diode junctions from failure due to too much heat.
Pictured is an ordinary 2N2222 NPN low voltage bi-polar switching transistor. The order of pins from left to right is collector-base-emitter. The flat front provides the proper orientation for viewing the transistor. The order of the pins can vary, but the scheme used on this transistor is pretty common.
Remove these ads by
Signing UpStep 1Bias the transistor for testing
The red lead from the meter connects to the positive socket on the meter. The black lead connects to the negative or common socket on the meter.
Normally, I just hold the resistor in one hand with the leads bent so I can touch two legs of the transistor at the same time. But, I needed one hand to operate the camera, so I used a breadboard to set up these photos. One lead of the resistor connects to the collector. The other lead of the resistor connects to the base. The positive lead (red) from the meter is connected to the collector. The negative or common lead (black) is connected to the emitter.
If this were a PNP transistor, rather than an NPN transistor, the red and black leads from the meter would be reversed in their positions.
11
comments
Add Comment
Phil B (author)
says:
Phil B (author)
says:
Phil B (author)
says:
Phil B (author)
says:
Add Comment
