Thanks for watching splatt116! Refilling the torches is easy, just pull the rocks back to one side (exposing the torch) and pull it out! I used the metal duct work to keep the rocks from falling in the hole. Glad you like it and I hope this helps.
Depends on use rain/ weather but for us every couple of years or so.
Just pull your rocks back to uncover the torches, the metal duct work keeps the rocks from falling in the holes when you remove the torch for refilling or replacement. Hope this helps! Thanks for watching
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
If you build one, email me a pic so I can share on the site!
Thanks for watching!
done and done!
how long before need to replace tiki torch?....how do you replace tiki torch?
