3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The New and Improved Brushless Electric Scooter Power System Guide
In 2008, I put together a guide on Instructables about upgrading the power system of your small personal electric vehicle . It was a primer on the basics of an electric vehicle power system and offered resources and tips specific to compact electric scooter conversion. As of right now, it has a solid 5 rating - I didn't know you could write that much on Instructables without telling anyone how to build anything and still receive perfect reviews.
I am delighted to report that in 2011, three years after the fact, that putting together a compact, powerful, and efficient electric vehicle drivetrain for local commutes (such as your campus, neighborhood, or urban area) using both R/C hobby hardware and specialized EV components is now cheaper and easier than ever. Price competition, new technologies, and just plain increased availability of fabrication and material resources means that building an electric personal transport device is now within the capabilities of just about everyone.
I will assume that you already know the fundamental parts of an EV or have built them before. If not, you're welcome to refer to my previous Instructable on this topic (linked above), or check out one of the many great Instructables on EV systems. This Instructable is intended as a conglomeration of resources, and so will discuss the pros and cons of component choices, specific vendors, design strategies, and other high-level considerations. It will also offer tips and tricks that I've found or had passed on to me pertaining to building small electric scooters. The guide will be overtly calibrated towards said scooters, since I favor them over electric bicycles, though much of the advice is just as pertinent to e-bikes. It should also be helpful for the occasional odd electric skateboard or other unconventional vehicle.
The format of the Instructable will primarily be a page or two on each primary component of an EV - such as the motor, controller, battery, and drivetrain (and associated mechanics).Then I'll present some designs that have emerged as being relatively easy to execute and fabrication advice for fully custom vehicles (i.e. not conversions).
Step 1R/C Hobby Parts: The Pros and Cons
The focus of my previous instructable was on repurposing R/C hobby, namely model aircraft, parts for vehicle propulsion. It will also make up a substantial portion of this one. Why on earth would you use parts designed for things which aren't technically supposed to be touching said earth when they're working correctly?
R/C aircraft components are the highest power-to-weight electric power systems easily available to the average consumer.
In the quest for ever-increasing flight durations, model sizes, and acrobatic performance, the R/C aircraft world has seen most components such as motors and motor controllers pushed to the limit of realizable power densities. The performance of the average brushless airplane motor greatly exceeds that of an average ferrite-magnet, DC brush scooter or bike motor - typically by three or four times. In the size and weight of a 500 watt electric scooter motor (about 3 inches diameter, 4 inches long, and weighing about 4 pounds), the example motor shown at the bottom can handle 2 - 3000 watts (i.e. 3 to 4 horsepower) of power throughput, and up to 6,000W peak.
The advent of mass produced, high performance lithium ion batteries is another factor. A modern lithium polymer (more on the distinction between different lithium flavors later!) battery the size of a U.S. house brick (about 1.3 liters) can store up to 300 watt hours, at the usual lithium polymer energy density of 240 Wh/L, and discharge at several kilowatts for a few minutes. No traditional lead-acid, or even nickel-chemistry battery system can come close to that. Granted, there are downsides to having such a dense energy source, and those will be addressed, but the truth is there in the numbers.
Part of my engineering interest is taking advantage of these increased power densities to create ever more compact but still practical vehicles. For instance, only with brushless technology is the miniature hub motor I've been working on a possibility...much less electric inline skates using them . Electric scooters are still imagined by most people to be large, low-performance, lead-acid battery powered monstrosities that are reserved for kids with back yards too big to run around efficiently in. While this may be true for most commercially sold ones due to cost reasons, if you're building one yourself, there's no reason to not expect better.
R/C aircraft components are the best power-to-price electric power systems, period .
You'd notice I left the fine print "commonly available" up there, because there are things which are more hardcore than a cheap brushless motor in terms of power density. The problem is, you can't buy them. Not easily, and definitely not cheaply. However, because R/C aeromodelling has become so prolific, parts are readily available over the internet and extremely cheap. Most R/C parts these days are manufactured in China and other East Asian countries and sold by dealers directly from those areas.
Even three years ago when I wrote my previous piece, this was not as true as it is now. The electric flight market, for the better part of the last decade, was dominated by high-market European manufacturers, and so was extremely expensive and also exclusive. The American market had two major motor manufacturers in this era which were well established: Astroflight and Aveox (which seems to have left the hobby market), and probably also Neu Motors . While the most hardcore of aeromodellers still stick with the highest performance European and American brands and companies, the majority run some inexpensive East Asian power system.
For a custom small vehicle, it's hard to find parts which have better price numbers. Depending on your power needs, a motor that has enough wattage to propel a vehicle will run between $40 to $100. A controller that can run the motor will be around $50 to $150. Batteries are the big cost breaker for EVs, still, but typical model aircraft lithium polymer packs price out to between $0.40 to $0.70 per watt-hour . A scooter may have around 150 to 200 watt hours of battery onboard, so expect about $70-100 in commonly available batteries. As I will show in more detail, you can assembly a roughly 1500 watt electric power system for something like $200 to $300 - and that is for everything , even including batteries, and a charger if you're good at shopping.
All of this might seem like cheap airplane parts are the way of the future. However, they also have their downsides.
Unfortunately, R/C aircraft components are usually very rudimentary and somewhat fragile .
Let's face it - airplanes are, in the purely mechanical sense, pretty easy loads to handle. The torque and power required increase directly with speed, so there's no static or locked-rotor (stall) conditions to worry about, unlike in vehicles where maximum torque is required at zero speed in order to accelerate from standstill. Airplanes are never supposed to hit things, bound over rocks and sidewalk cracks, or be jostled by suspension movements. What matters more in aeromodelling is light weight.
As a result, model motors are usually made as lightweight as possible, using thin metals and plastics, and undersized bearings and shafts. Substantard metal alloys (such as soft architectural aluminum) are common in "cheap" motor construction. R/C power controllers are usually single-PCB affairs which pack power semiconductors and logic right next to eachother using the minimum amount of support components possible by design, and only capable of reaching their ratings when placed in a constant airflow (such as, you know, the draft of a propeller), and are rated to just under the peak power handling capabilities of the semiconductors.  One of the major themes I'll hit on later is that you must derate everything . The ratings given for aircraft parts, especially cheap ones, are generally unrealistic for EV use.
Even worse is the fact that the average aircraft lithium ion pack doesn't have a hard shell. Lipo batteries are little squishy bags of volatile electrolytes and active alkali metals. I don't know who's great idea it was to make a battery without a shell, but the abuse of a vehicle dictates that batteries must be properly mounted and proofed from shock, impacts, and weather. It makes me cringe a little even recommending using lithium batteries to the public because of those reasons.
You've been warned.
Overall, though, I think my point is clear: R/C model aircraft components are a good economical choice for those looking to begin experimenting with electric vehicle technology . It may not be the best solution for someone looking for a reliable, maintenance-free, long-life commuting vehicle. Many R/C components are definitely not manufactured to vehicle specifications and may fail or become finicky over a period of time. There are definitely commercial EV solutions available which are even plug-and-play - but I'm assuming if you are reading this, you have a little sense of adventure.
15 comments
May 19, 2012. 3:30 AMNewbOzzi says:
Wow after reading this article now I'm building a scooter.
Bad influence I think..
Welding and machining I get but the electrics are not so much my thing :(
I bought 2 motors
KA63-18L
Constant: 259Kv
Battery: 10Cell Lipo
Operating Current: 25-60A
Peak Current: 72A(15sec)
Here is the problem.. Do I run one and have a spare or use them both?
If both what would be the best way?
Apr 20, 2012. 9:26 PMpurplewinter says:
Just wanted to say a quick thanks for this instructable. It's the detail all in the one place that i have been searching for, for years. Thanks for confirmation of R/C parts as well and the technical detail.
Nov 22, 2011. 3:36 PMkaiinstructables says:
Can you use the sensored kelly controllers with a sensorless motor?
Dec 16, 2011. 8:59 AMbratan says:
Great tips, especially about bore size changing! Thanks for taking time and explaining this!
Sep 7, 2011. 2:52 PMdrkurtsvanhassenphefer says:
If I'm going to use LiFePo4 batteries from HK, will I need to include a battery management system when discharging and/or charging? Great instructable, by the way.
Sep 6, 2011. 6:12 AMhgalindo says:
NIce Work!, do you have any video to see how it works?
Aug 7, 2011. 4:22 AMm0ng00se says:
http://endless-sphere.com/forums/viewtopic.php?f=2&t=6892&start=75#p119810
Is a good piece of software to calculate speed etc, I got the link from http://www.jeromedemers.com/
Aug 5, 2011. 8:33 PMSimonArthur says:
Double check your info on GT belts. They're made by Gates, who rate them for much higher load than HTD belts. The belts have round teeth and are compatible with HTD sprockets, but supposedly work better with GT sprockets.
I know this because I've been working on the belt drive system for you-know-what.
Aug 5, 2011. 2:52 AMm0ng00se says:
Great tutorial,
I'm in the process of building up my e-scooter I brought for $20 and was just wondering what are your thoughts on 3d printed parts for spurs and sprockets with chain for a scooter?
Cheers
Larry
Aug 4, 2011. 2:35 PMSpokehedz says:
WOW that is an absolute ton of information. THANK YOU!
Also, I find that for twisting the wires, it's better if you have a minimum of two people (three is better) and to twist all your wire up at once.
SETUP:
Two people have drills with the wires chucked into the ends. Both drills are in the same direction.
Ends of the wires not in the chucks are securely connected together. I use a ziptie with the wires doubled over.
The length of the wire is stretched out (This is where the third person helps) but not touching the ground and connected to something like an eyehook or something. The wires must be FREE to spin in the air and not touch anything.
Then you simply spin the drills at the same RPM (two identical drills set on 'low' is best) and you watch as the wire begins to twist itself into a neat little cable without any kinks. The third person can hold the wire where the twist is coming together to help it form nice and tight.
I have made bundles of CAT-5 cables over 25' long with this method and it only takes about 5mins to get the setup and everybody schooled in their job. With good quality silicone wire and good helpers, it can go even faster.
Aug 5, 2011. 9:46 AMAlexWillisson says:
I've done this on my own many times. Clamp one end, use a drill at the other end and have at it. Sometimes I'll use a heat gun to anneal the insulation, but sometimes I'll just let it sit for a minute or deal with it unraveling a little. A heat gun is easier if you have a second person, but I've used the weight of a drill to keep the wire tensioned while I run a heat gun over it.
Make sure you have plenty of slack to start with, the longer the wires the shorter the bundle you make will get (since the wires travel in spirals instead of straight lines)
Aug 5, 2011. 11:29 AMSpokehedz says:
By twisting both wires in the same direction, they will wrap themselves and stay wrapped--no heating required. They also don't want to coil up on one another. They lay flat, and coil just like a normal cable.
This is an ancient rope/twine making technique.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
104
Author:teamtestbot
lol robots
