The OrangePi Lite
Published
Introduction: The OrangePi Lite
About: Just me!
I ordered a Raspberry Pi to be my MQTT server for my Home Automation project. I also ordered an Orange Pi Lite to experiment with it. To my surprise, the second arrived first!
A $12 Pi with built-in wireless among other options is very tempting - 3 for the price of one!
(update: this is the schematics V1.1)
Setting the board was a challenge to me; my UNIX/Lynx experience is ancient (early nineties!) so I preferred to get the RPI to start with a hassle-free setup then experiment with the OPI but "winds do not blow as the vessels wish"
So, I had to get the OPI to work!
Step 1: Preparing the Boot SD Card
Pi boards use an SD slot to boot.
SD Cards are not reliable, slow and its lifetime is not so good but this is how it works.
It is said that OPIs are not OK with slow SDs so a class 10 is recommended & that's what I already had, a 16G class 10 card.
I tried several disributions (OS's) for the OPI and ended up using Armbian which is Debian based which is a UNIX-like OS. I preferred to use Armbian Jessy Desktop (although I am intending to have a headless system but it is always good to have a remote desktop ready when needed)
There is also the very neat DietPi by Daniel Knight with a very small footprint and fast automated installation. There is distro for OrangePi One which is the wired version with no wireless module. I tested and it looks great but it has a minor issue with wlan0 after first reboot - I hope it will be fixed in the next version (v135).
[Update: It is almost fixed in v135 but needs some manual configurations for wifi to work]
We need to install the operating system for the OPI Lite using Win32 Disk Imager - just select the IMG file & press [Write], making sure that the right drive is selected.
In few minutes the SD will be ready for first boot.
Accessing Unix SD-cards it in Windows is not natively possible & since bad things happen, accessing the file system files on the SD if you can't boot Pi might save you from starting from scratch! - For that, I am using DietPi VirtualBox VM to have an easy way to brows, view & edit the files if needed.
Summary:
  1. Get an Orange Pi Lite from Aliexpress for $12.00 or from Amazon for $19.99
  2. Get a 16G class 10 SD-Card.
  3. Download the Image Writer Tool.
  4. Download Armbian Jessy Desktop.
  5. Write the Image to the SD.
  6. You may check the SD with DietPi VirtualBox VM.
  7. We are ready for first run.
Step 2: Wiring the Board
For proper Pi operation you need a good power supply to avoid any heck-ups - DC 5V @ 2A (4.0mm/1.7mm barrel plug - center positive) or you may power the board via GPIO header pins.
The OPI Lite is supposed to consume low power but it is getting hot even with almost nothing running - so I decided to stick a heat sink & connect a small fan. just in case!
I improvised a case with a matchbox just for fun & because I don't have an HDMI monitor on my workbench I just connected a USB2Serial (same that I use for ESP8266 programming - check my other Instructable)
There is a 3-pin header near the OTG USB (check the photo above) - plug it in your computer & make sure that the right driver is installed.
Summary:
  1. Get a DC 5V @ 2A (4.0mm/1.7mm barrel plug - center positive)
  2. Stick a heat sink on the processor chip (optional but recommended)
  3. Connect a fan over the processor chip (optional but recommended)
Step 3: First Run
Although the board has a wireless module, there is no wifi setup during the installation (DietPi has this to simplify the installation) so a terminal program such as KiTTY is needed to communicate with the headless board via the serial interface.
Run KiTTY & select the Serial connection type, set the COM port and set the speed to 115200.
Power the board & watch the boot process - do as in the photo sequence above.
Summary:
  1. Download a terminal program - KiTTYis recommended.
  2. Start KiTTY (Serial & 115200)
  3. Power the board
  4. Use root/1234 for first login.
  5. Follow the steps:
    • Change the password.
    • Enter a name for the user account (opi).
    • Press Enter for all other questions.
    • Answer [Y] whenever needed.
Step 4: Setting the WiFi Connectivity:
Console commands in UNIX machines are not fun at all, so without going into much details, I list how I setup the wireless connection:
1- Configure the wireless credentials
(My router is wpa2-personal security)
1- At the prompt type:
wpa_passphrase "YOUR_SSID" "YOUR_WIRELESS_KEY" > /etc/wpa_supplicant.conf
Replacing real values between quotes.
2- Check the output file just to make sure - type at the prompt:
root@orangepilite:~# cat /etc/wpa_supplicant.conf
You should get something like this:
network={
        ssid="YOUR_SSID"
        #psk="YOUR_WIRELESS_KEY"
        psk=dfe4026fdc1dc0fb38870a7a3a70b8082e756121fced55a33a7a6629c9e375f4
Step 5: Setting the WiFi Connectivity - Static IP:
(If you need DHCP setup, skip this step)
2- Setup the 'interfaces' file (Static):
1- Type at the prompt:
root@orangepilite:~# nano /etc/network/interfaces
2- Delete all the lines in the file & add at the bottom:
auto lo
auto wlan0
iface lo inet loopback
iface wlan0 inet static
address 192.168.1.100
netmask 255.255.255.0
gateway 192.168.1.1
pre-up sudo /sbin/wpa_supplicant -iwlan0 -c/etc/wpa_supplicant.conf -Dnl80211 -B
pre-up sleep 5
post-down sudo killall -q wpa_supplicant
Press then [ENTER] to save the changes.
Press to exit
Step 6: Setting the WiFi Connectivity - DHCP:
(These steps are for DHCP setting only)
2- Setup the 'interfaces' file (DHCP):
2- Remove all lines & add at the bottom:
auto lo
auto wlan0
iface wlan0 inet dhcp
wpa-ap-scan 1
pre-up sleep 5
Press to exit
Remove Network Manager packages:
In my case, for DHCP to work properly & run automatically at boot, I had to remove Network Manager components:
At the prompt type:
root@orangepilite:~# apt-get remove network-manager network-manager-gnome
Step 7: Setting the WiFi Connectivity - Verify
3- Reboot the board
root@orangepilite:~# reboot<br>
If all is OK then the wireless should be working after the reboot.
2- Check the wireless connectivity:
root@orangepilite:~# iwconfig
The output should be similar to:
 lo        no wireless extensions.
tunl0     no wireless extensions.
wlan0     IEEE 802.11bg  ESSID:"YOUR_ESSID"  Nickname:"<wifi@realtek>"
          Mode:Managed  Frequency:2.462 GHz  Access Point: MA:C_:AD:DR:ES:S_
          Bit Rate:54 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Power Management:off
          Link Quality=99/100  Signal level=69/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0</wifi@realtek>
(Note the YOUR_ESSID should be the one you have)
2- to verify the IP, type:
root@orangepilite:~# ip a show
1: lo:  mtu 16436 qdisc noqueue state UNKNOWN group default<br>    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
       valid_lft forever preferred_lft forever
2: tunl0:  mtu 1480 qdisc noop state DOWN group default
    link/ipip 0.0.0.0 brd 0.0.0.0
3: wlan0:  mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 00:e0:4c:e0:e9:1e brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.100/24 brd 192.168.1.255 scope global wlan0
    inet6 fe80::2e0:4cff:fee0:e91e/64 scope link
Step 8: Back-up & Upgrade
Now is the time to upgrade the installed package but before that it is better to back-up the SD Card first.
I like to keep a working configured image just in case I need to roll back to a know point.
Win32 Disk Imager will be used again for that - just select the file to write to (use a new file not an existing image - it will be over-written!) then click [Read] (not Write!)
Reboot again & we are ready to upgrade.
first we need to update the index file & update the list of installed packages:
root@orangepilite:~# apt-get update
This will take some time to finish, then do the actual upgrade:
root@orangepilite:~# apt-get upgrade
then:
root@orangepilite:~#apt-get dist-upgrade
These will take quite some time to finish so be patient & never turn off the power to reboot as it will render the SD Card unusable & you need to do everything from the beginning ... but we have a backup already, right?!
Step 9: Accessing the OPI Lite Wirelessly - SSH (Secure SHell)
Once the board boots with an IP address it may be accessed wirelessly via SSH (Secure SHell) connection using KiTTY also.
It looks exactly the same & you may use it just like the Serial console. Select SSH connection type & leave the default port = 22 & connect.
You may Also access the board using a mobile SSH client - JuiceSSH is very convenient & has lots of features. There are other SSH client such as ServerAuditor & ConnectBot among others ... chose what you like.
Step 10: Accessing the OPI Lite Wirelessly - SCP (Secure CoPy)
Another way to access the files on the SD Card by using FTP or SCP client.
SCP is supported by default & I use WinSCP portable. Download & unzip this archive to your tools folder.
Enter the OPI IP & username/password for the root. You better save the settings for easy reconnect.
With WinSCP you can brows, edit & even change permissions of any file.
Step 11: Accessing the OPI Lite Wirelessly - VNC (Virtual Network Computing)
If you are accustomed to GUI then remote desktop using VNC is the way to do it.
We need to install a server on the OPI & a viewer on the PC.
I am using TightVNCserver but there are many other - I appreciate if you share your experience in the comments.
To install the server:
root@orangepilite:~# aptitude install tightvncserver
Here I am using aptitude, a Debian utility that wrap the apt-get installer.
After installation you run the server - we need to add that user 'opi' (created during the installation) to the sudo group (to be able to run root commands without root login)
root@orangepilite:~# gpasswd -a opi sudo
root@orangepilite:~# su - opi
then run the server:
opi@orangepilite:~# vncserver
Enter the password and the server is ready.
Step 12: UltraVNC Client
You need to install a VNC client on the PC to access the OPI desktop - I am using UltraVNC - you connect to port 5901.
If you want more security, you better have VNC over SSH tunnel session. To do this you need to change the way you start the server & the way you run UltraVNC - you will need KiTTY for this.
    Create a SSH secure tunnel using KiTTY:
    1. In Session enter the IP & port as we did before.
    2. In SSH/Tunnels enter Source port = 5901 & Destination = localhost:5901 press [Add]
    3. If you want to automate the login in Connection/Data enter username & password - also enter the Command that we use to start the VNC Server: vncserver -localhost.
    Now when you connect with this setup it will login & issue the needed command to start the server - ready for PC remote desktop.
    On the PC, run UltraVNC
      • Oil Contest
        Oil Contest
      • Water Contest
        Water Contest
      • Creative Misuse Contest
      Awesome!
      Been fighting trying to get armbian to start the driver...they had 8189fs in /etc/modules (dietpi commented it out then used a script to modprobe cfg80122 driver then run wpa_supplicant with -D nl80211,wext ) and I think your setup might just work...will be working on this ASAP!
      Worked like a CHAMP!!!
      I did have to add one line to /etc/network/interfaces though
      You must have static DNS assigned...add this below the gateway address
      dns-nameservers 192.168.0.1 8.8.8.8
      this way it uses your router dns first, if that fails falls back to google dns servers
      Thanks a ton for this walkthru!
