The return of the dead flatbed scanner
How a dead scanner can return as a printed circuit board UV lamp. Keep that cover closed !
Step 1Forewords
Forewords
I made this Ultra Violet bed to make printed circuit boards a few years ago without Instructables.com in mind, so rather than a step by step pictorial description of how I made it, I'll provide you with a few pictures of the finished work and hints on how you can do the same. Hope this will help anyways.
First of all, safety. Notice that this is a mains powered device so maximum care must be taken in the design to insure that for no reason someone may come into contact with live parts. If you are not sure about medium voltage (mains) electrical wiring practice ask a friend or someone else whom is.
30 comments
Feb 19, 2007. 1:57 PMmrgibby says:
good diagram, although where i come from green tends to mean ground, so i might've chosen a diff. color for circuit wiring. Otherwise though nice layout. Yes by all means ground every metal part that's not part of the conducting circuit.
Jul 29, 2011. 9:53 PMspylock says:
Are these the same lights that will kill algee in fish ponds?
Sep 7, 2009. 9:51 AMFoxtrot70 says:
Hi 5Volt, the all green wires remind me of a past employer of mine. In an attempt to "Spend a Penny to save a Pound" one of the geniuses in engineering sold the idea of changing color coded wire loom to all white with (you won't believe it) the connection info printed on both ends of the wire. One needed a magnifying glass to read this stuff 24 ga. wire makes for a very small type point regardless of font! The result of the 3 year exercise was "A Pound was spent including the Penny"! ARGH, management what would we do without them.
Jul 5, 2010. 5:16 AMhamstanz says:
i'm also quite confused as to which type of UV light i should be using. I take it that this is a Black light one, although i see this person (http://www.instructables.com/id/Pro-lichtbak-voor-weinig-geld-Pro-UV-lightbox-fo/step7/Eind-kosten-final-cost/) using tanning Bulbs. Which one will expose a board the fastest ? Which one is most suited to this application ? Thanks a lot in advance
Jul 5, 2010. 2:47 AMhamstanz says:
Was wondering if you could tell me the exposure times for this setup and the exact model of the bulbs thanks
May 19, 2009. 12:55 PM12V says:
why not fit a cutout switch(so lamps extinguish when cover is opened).
Jan 29, 2008. 9:29 AMjimwig says:
labtech you did think of it. sometimes you just feel as if you were there when the project became reality. eh? ideas float in the air and when someone moves on making one we all benefit or not. a connectiveness of sorts.
Jan 29, 2008. 9:25 AMjimwig says:
in the usa
green is ground
white or gray is neutral
black is hot leg or #1 in multiphase
red is " " #2 " " "
blue is #3 in 120?208 multiphase
orange is # in multiphase or a high leg in a Delta
brown is # in
hey its been so long that my brain is in the wrong phase. sorry look it up and be careful.
remember that if you are not grounded shock potential is minimized or eliminated BUT trickle currents can still shock the doggy doo out of you.
stand on a dry insulator if you MUST work on a live mains situation
try not to do work without another person close by
try to learn to give CPR as coronary arrest usually occurs in electrocution
And generally if in doubt DON'T $#% with live circuits.
BE CAREFUL and BE RESPECTFUL and be SAFE
Nov 9, 2007. 2:03 AMlabtech1952 says:
Great project. The only criticism I have is; Why didn't I think of this?
Mar 31, 2007. 12:23 PMDillyDog says:
This would be really cool by using a scanner with a transparency hood and having UV tubes in the hood as well. That way, you could expose 2-sided boards without the risk of accidental movement when turning the bord over to expose the second side. All the the ballasts and starters could be housed in the lower casing, while just having the tubes in the hood. I think I'll get that old scanner out of the attic and have a go! Thanks for the idea, it had never occurred to me before.
Oct 8, 2007. 8:38 PMdpocius says:
Or, if you had 2 identical scanners, you could take the covers off both and hinge them together, face-to-face (with UV tubes in both, of course.) Also, add an interlock switch to kill the UV when the cover is opened. Also, get a spring wound timer switch like on a bathroom heat lamp to set a repeatable exposure time.
Jun 11, 2007. 11:07 AMtxtsttoo says:
nice idea, yea. Can someone tell me if i can do this,in an non working scanner ? by using bulb's or floureocent tubes' if there is someone who likes to help, e- mail me : grrdmngn@yahoo.com thanks to you all Buddies. jerry.
Feb 20, 2007. 1:01 PMCoolbreaze says:
BTW you are confusing EEPROMS with EPROMS. You don't erase EEPROMS with UV Electronically Erasable Programmable Read-Only Memory You erase EPROMS with UV erasable programmable read-only memory For optimum erasure time UV light must have a wavelength of 235nm But I'm still 95% sure your box would erase EPROMS since you can leave em outside in the sun to erase em....just takes way more time!
Feb 14, 2007. 8:30 AMCoolbreaze says:
Very nice way of recycling an old scanner for photo resist etching purposes!
You could also use it to erase eproms =)
2 1/2 thumbs up! (where does the half come from? nobody knows!)
Feb 14, 2007. 7:50 PMsumguysr says:
im afraid it wouldn't work to erase eproms. eproms require near band ultraviolet light, which will not work for exposing photo resist. Who cares though, uv erasible eproms are ancient.
Feb 20, 2007. 12:56 PMCoolbreaze says:
I'm like 95% sure it would work since you can erase eproms using the sun light!...leave your eproms outside in the sun for 3 days and they are erased...so why wouldn't UV lights do the trick over a long period of time? Yes wouldn't be 15minutes like a normal UV eraser but still!
Feb 16, 2007. 3:17 AMradikaldesig says:
It is a very good idea.
That wavelength has the light of the tubes?
Thanks
radiakldesig.comradiakldesig.com
Feb 14, 2007. 6:09 PMT3h_Muffinator says:
It seems cool, but I'm not exactly sure how it works. Is there some kind of mask that you put on the board and then gets eaten away when exposed to UV?
Feb 14, 2007. 7:47 PMsumguysr says:
the photomask process for creating pcbs is basicaly as follows 1. you design a pcb on a computer 2. you print out a film of the pcb, usualy on a transparency or better yet on tracing paper 3. you coat a copper clad board with photoresist using a sprayer or a laminator and resist film, you can also buy pre-coated boards 4. you use the film to mask the board and expose it to UV light 5. you place the board in developer 6. you place the board in etchant, usualy ferric chloride, amonium persulphate, or cupric chloride.
Feb 15, 2007. 2:39 AMksjlkdjlddj says:
I bought a second hand face tanner at a flee market for 2€, and use it to expose my PCB's. It works just great and is dirt cheap! It has 4 UV-A tubes with their starters and ballasts, and even a crude timer (which I don't use). From my experience, it would indeed be better to have the UV light move around, this would eliminate shadowing at the edges of traces. I avoid this by moving the face tanner a bit after half of the exposure time. Make sure your artwork does not move in respect to the PCB you are exposing though. Summary: the cheapest source for UV-A tubes are second hand face tanners. www.steeman.be
Feb 14, 2007. 10:59 AMoskay says:
Brilliant!!!
By the way, I've had excellent luck exposing PCBs with regular fluorescent lamps-- so I don't think that you *need* to use the UV bulbs. (Although they do look *seriously* cool.) Do they significantly cut down on the exposure time that you need? I remember using about seven minutes per side with regular fluorescent bulbs.
Feb 14, 2007. 10:18 AMchaydgb says:
Cool idea, nice job! Shame I've recently chucked a scanner, and I just happen to be looking for a photoresist exposure box too :(
Feb 14, 2007. 9:29 AMSergiozal says:
I did almost the same with ordinary daylight lamps - six 20W bulbs - to use it as a light table to view negatives. Works quite nice.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:5Volt
