3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tin Can Stirling Engine
How I built a hot air engine almost entirely from junk.  I've wanted to build one of these ever since discovering stirling engines in about 2003.  Spending the weekend making things in Steveastrouk's workshop gave me the opportunity to make the precision parts I'd need, and I knew most of the engine was going to be made of improvised materials, so decided to see if I could make the entire thing out of scrap or unwanted materials.
If you aren't familiar with how Stirling engines work, there are plenty of resources online- the Wikipedia page is a good place to start.
Step 1Design
Design
The "core" of a gamma stirling engine of this design is a large cylinder that holds the displacer, connected to a smaller power cylinder providing the power strokes.  I decided to follow Darryl Boyd's "walking beam" design, where the power cylinder sticks out of the side of the dis[placer cylinder, because it suited the materials I had and it looks cool  :)
I found that an aluminium drinks can would fit neatly inside a steel soup can, so decided to use that for the displacer on the grounds of being cheap, light and easy to work with. The steel soup can provides a sturdy body for the engine and also meant I could ake the bottom removable to allow maintenance.
I found some decking to use as the base, some 1" x 1/2" pine to use as supports for the moving parts, and a piece of 3/4" aluminium strip to use as the beam.  The engine is a messy combination of metric and imperial units- that's what happens when you use scrap materials!
104 comments
1-40 of 104next »
Jan 15, 2012. 4:15 AMdeep92 says:
I get that for the power piston to be able to move, it has to be smaller in diameter than the power cylinder, but the thing that i don't understand is that if the piston is smaller than the cylinder won't it cause air leakage??
thanks for ur response! This is the only thing thats bothering me, otherwise i'm really looking forward to making this!!!
Nov 24, 2011. 8:44 AMyokozuna says:
Nicely done sir, 5 stars.
Apr 26, 2011. 9:42 PMravenheart_tinkers says:
Very cool little project. Thanks. Oh, and Sterling engines have enormous real world application without any further development. They already work so they aren't just "curiosities". These engines are highly efficient (and they are also typically used with free or very cheap energy sources anyway) and very low maintenance & cheap to operate. Without any further development whatsoever, these engines are already available for purchase from numerous sources, especially relating to electricity producing solar concentrators and co-generation applications where new or existing heating furnaces & incinerators are fitted to also produce electricity. Co-generation engines are not only available for large commercial applications, but also for residential and small commercial applications, requiring as little as 500 degree Celsius to operate. Comparing petroleum diesel engine applications to sterling engine applications is utter nonsense. Diesel has absolutely no application where sterling engines are designed to be used. These applications are specific to producing very cheap electricity, so implying that diesel generators could somehow be used is ridiculous. I strongly suspect the poster makes his living from either petroleum or combustion engines and is making a feeble attempt to misinform. Now to be fair, algae generated diesel may be something to show enormous promise in the relatively near future with some further technological development, but petroleum based diesel is a non-argument. And even having given a nod to algae generated diesel, it doesn't appear that it will be cost effective enough to produce anytime soon to render sterling engines obsolete. Note: Hebinho posted some relevant links above in regards to this argument for anyone who missed them and would like to see just how advanced sterling engine technology already is and what it has to offer.
Nov 10, 2011. 2:06 AMRaven Destroyer says:
it's hard to make a sterling really work but when it works it shouldn't stop working
Jun 16, 2011. 6:26 AMBarfight76 says:
Excellent work! I want to build one using clear materials (i.e. glass, pvc, etc.), but I can't seem to find what kind of hot temperatures that are dealt with. The pvc specs I'm looking at have a max temp of around 150 deg F. My question really is, what kind of temperatures are you getting from your hot air portion?
May 29, 2011. 1:54 PMcharris7 says:
can someone please explain the power piston and cylinder to me? what do I need, and how do i position it to make it work???
Apr 4, 2011. 2:53 AMfuryy says:
That is soo cool!
Mar 23, 2011. 3:34 PMwiinick says:
What is that metal thing holding the cd, i see them in many of these projects and i cant seem to find one, help me.
Mar 19, 2011. 1:02 PMsteve-lane says:
you could use one of those sterno cans.
I picked up some at a camping store
Mar 18, 2011. 6:16 PMtzq33tdq says:
i want one!!!
Mar 17, 2011. 3:01 AMfail says:
Ive got 2 soup cans and there is a gap of half a centimetre between the middle can and the outer one, all of the way around. Is that too much?
Mar 18, 2011. 4:29 AMfail says:
Thanks!
I can't seem to find any drink cans around, so I'm going to use these cans instead, now that I know that it should work. I shall inform you on how well it runs.
Mar 15, 2011. 4:37 PMwiinick says:
Video pleeeeaaaassseeeee
Feb 27, 2011. 12:51 PMBiotele says:
video please. Can you calculate power and efficiency?
Feb 27, 2011. 2:14 PMalexsparrow says:
that thing runs hecka fast
Mar 10, 2011. 5:00 AMh3x_your_nightmare says:
you should put some oil on joints and on the pistons! you can minimise the friction in this way ;)
Feb 25, 2011. 7:29 AMpfred2 says:
I did a school report on these when I was in 7th grade back in the 70s. Since then I've always still been a bit intrigued by them. I've seen examples that can run on the warmth of the palm of someone's hand holding them! Yours is neat for different reasons of course.
Feb 27, 2011. 6:42 AMjuanvi says:
(removed by author or community request)
Feb 27, 2011. 7:35 AMHebinho says:
Hi juanvi,
just go to YouTube and search for KS90 and you will see some nice examples!
They also start running when the upper surface of the displacer cylinder is being heated by just letting the sun shine on it!
But they are a bit difficult to align and when building one, you have to avoid everthing which could cause some unneeded friction.
Feb 27, 2011. 8:13 AMpfred2 says:
When I was there they seemed to be rather commonplace items today. Stirling engines are at best a curiosity though.
Feb 27, 2011. 6:33 PMVengence says:
Wrong. Currently they're more efficient than solar cells. They can be up to 40% efficient(not the type in this instrucable though). The company Stirling Energy Systems Inc. has been contracted to build a solar farm in California...
Feb 28, 2011. 4:34 AMHebinho says:
First of all we should distinguish between "toy" or "demonstartion" stirling engines and real serious stirling engines! Scottsdale's Sterling Energy Systems Inc. is running the "Suncatcher" which has a mirror dish of 11.5 m diameter and produces 25 kW of eletric power at an efficiency of 31.25 % (world record in 2008), while solar cells rarely are getting beyond 15 %!
Europe has a lot of CHPs (Combined Heat and Power plants) installed, using biomass to generate heat and electrical energy in housing areas, based on stirling engines. Of course these engines by no way can be compared to the ones you will find at instructables.com, but these are real hitech products, running 30,000 hours and more needing only a small amount of maintenance.
There are small CHPs (15 kW heat and 3 kW electrical energy), just take a look at http://ec.europa.eu/environment/life/project/Projects/index.cfm?fuseaction=home.showFile&rep=laymanReport&fil=LIFE99_ENV_D_000452_LAYMAN.pdf
Hungary based FlexEnergy is builing a generator (38 kW output) running on landfill gas (methane) only.
Now you can continue to state "...Stirling engines are at best a curiosity though..."
Feb 28, 2011. 6:47 AMpfred2 says:
Thank you for allowing me to continue stating the obvious.  A few obscure projects referenced does not make you right. There is likely more steam piston engines still in operation than Stirling engines today.
A 40kW diesel generator isn't newsworthy, its a pallet item.
http://www.google.com/images?um=1&hl=en&safe=off&tbs=isch:1&&sa=X&ei=s7FrTY7PPIO88gaU4LyQCw&ved=0CC8QBSgA&q=40+kW+diesel+generator
About 153,000 results ...
I think we need to distinguish between fantasy and reality but that's just me.
Feb 28, 2011. 6:41 PMVengence says:
[pfred2: A few obscure projects referenced does not make you right.]
Yes, it most certainly does. It's called proof, and it's not an opinion. You have been proven wrong.
[pfred2: There is likely more steam piston engines still in operation than Stirling engines today.]
Of course there is. Steam is still one of the most efficient and most powerful systems there is. If there wasn't a problem with steam production and storage we'd still be using them in our cars. You're not making a case for yourself. How exactly do you think nuclear power plants work? That's right...steam...
[pfred2: I think we need to distinguish between fantasy and reality but that's just me.]
I guess the sources that Hebinho mentioned are fantasy and not reality? I don't think "we" need to distinquish between fantasy and reality, I think just "you" do.
You may now continue to post opinion...
Feb 28, 2011. 9:02 PMpfred2 says:
You just keep on believing that efficient equals practical. As an example fusion is amazingly efficient, just not very practical. Nuclear power plants do not use pistons except to raise and lower the control rods. But yes turbines are fairly efficient, and practical as well.
No I'm not making a case with you! Because you are an unreasonable individual.
I'm supposed to accept a few sources but it is OK for you to ignore the overwhelming number I present? At this point I really don't care what you think.
Feb 28, 2011. 11:30 PMVengence says:
[pfred2: As an example fusion is amazingly efficient, just not very practical.]
Fusion isn't even done at a stable level yet. Once fusion reactors are perfected it will be extremely practical and will take the place of current nuclear reactors. You're still wrong in your example.
[I'm supposed to accept a few sources but it is OK for you to ignore the overwhelming number I present?]
Overwhelming number of what? You have produced zero evidence that "stirling engines are at best a curiosity".
Mar 1, 2011. 4:24 AMpfred2 says:
Sure it is it, just takes more power to operate than can be gotten from it. If fusion reactor engineering impossibilities are ever overcome I'm sure it'll rain pennies from heaven on that day!
Here are 153,000 examples
That took all of a tenth of a second for our favorite search engine to cough up but you conveniently choose to ignore. Go argue something you've a chance with like extra terrestrials or the Easter Bunny. That ought to be a good one, least you'll have baskets pretty soon as proof!
Mar 4, 2011. 6:16 PMkomodoboyx5 says:
you're also ignoring the fact that diesel is a non-renewable resource. The sun will burn on for many, many, many, many, many, many, many more days. In fact, by the time the sun does burn out, we'll have found more suns to juice for energy.
& Don't argue the stupid position of proposing ethanol, that would require energy to make energy, wasting time & power.
Mar 5, 2011. 8:02 AMpfred2 says:
I'm not the one arguing.
Mar 3, 2011. 4:36 AMVengence says:
[pfred2: Sure it is it, just takes more power to operate than can be gotten from it.]
No, it's not. You're basically saying so in the latter part of your statement. Will you ever stop being wrong(Apparently not)? It's not supposed to take a continual energy feed to keep the reaction going. It's only supposed to take energy to start the reaction, and it should keep going for as long as it's stable. You understand what stable means right? ITER is expected to produce a minimum stable reaction of 480 seconds but could be as much as 1,000 seconds, producing 5(on the low end) to 10(on the high end) times as much energy as was needed to start the reaction.
[pfred2: That took all of a tenth of a second for our favorite search engine to cough up but you conveniently choose to ignore.]
You posted the same exact useless link again? That's proving that stirling engines are a curiosity how?(I'll give you a hint: it's not) With the national average for diesel being $3.716 per gallon and some places as high as $3.964, tell me again which one you think is actually more practical? Do you have to keep paying the sun to receive and convert it's energy? A link to diesel generators proves nothing about stirling engines. You'd have to be delusional to think the diesel generator is more practical.
Mar 3, 2011. 5:05 PMpfred2 says:
What vessel besides magnetic do you propose plasma be contained in? It's not like you can put something a million degrees into your coffee cup you know?
You just choose not to see the relationship. They pointed out one example of a 37kW generator I pointed out 153,000 of similar in just one other technology. Now if diesel wasn't more practical then how come there are so many more examples?
Mar 6, 2011. 6:01 PMSydAndy says:
pointing out existing examples means nothing about the future.
By the same example 100 years ago you would be saying coal powered steam engines were the only solution earth ever needs, claiming petrol engines were a fad.
100 years before that, you would be mocking anyone even thinking anything but a horse could move a cart.
You would probably also be saying that since 90% of carts were drawn by horses, that those carrying heavier loads which required bullocks to pull them should be regarded as imaginary?
Mar 6, 2011. 8:37 PMpfred2 says:
Maybe what you say would be true if Stirling engines hadn't been around almost 200 years already.
Mar 7, 2011. 4:05 AMHebinho says:
And for how long the wheel has been around before becoming ball bearings ....?
1-40 of 104next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
148
Author:PKM
