Tips for choosing the correct soldering iron tip
 by ColorBomb
Featured
I will be discussing how the choose the correct tip for the project that you are soldering. There are many different tips by many different manufactureres, some are even patented by certain manufacturers such as the z wave tip by Pace. I will be using my home setup as reference.
Guidelines for choosing a tip
Choose a tip compatible with you iron
Determine the style of tip, some tips work better than others I explain a bit more below
Determine the correct size tip, too small and heat will not be transfered well too large and you could over hang the pad and damage the board.
Tips that I use
I am not a fan of conical tips especially for beginners. Most people, when learning to solder, think that applying pressure will help the solder flow and end up damaging the board. Also any tip with a point will have a shorter life due to the amount of metal at the tip, the sharper the point the shorter the lifespan.
I prefer chisel tips, the one pictured is over 3years old. I like them especially for surface mount applicationss. The idea is to have the tip be 60% the width of the pad, this will allow the soldering process to take place as quickly as possible with the least amount of thermal stress on the compoent. Chisel tips are thicker at the tip which will store more heat. I have differnt sized chisel tips for different applications
Chisel tips are ideal for:
Through hole
Surface mount
Wire
desoldering w/ solder braid
I also use a "Hoof" tip or gullwing tip. I use this for drag soldering multi lead SMT IC packages. Drag soldering is a thing of beauty. You can solder a 120 pin flat pack in minutes. This technique can be tricky because you need to have the right amount of solder applied to the tip or you will bridge the leads. I also use this tip for "blue wiring" circuits using small gauge wire.
Hoof Tips are ideal for:
Drag soldering
soldering small gauge wires
As I stated there are many styles and sizes of tips these are just a few that I use. I will conclude this instrucable with a few tips.
Always treat tips as thought they are hot, even if you know that it isn't
Do not use excessive preassure when soldering , you can damage your tip and your project.
when you are finished soldering apply a thin layer of solder to the tip, this will help prevent oxidation
Never use the tip as a pry bar or screwdriver
Use the lowest temperature possible, this will prevent premature wear tot he tip and damage to the components
Always use a tip appropriate for the application, you can use the advice in bold as a guideline.
Turn the system off when not in use, if you aren't going to be usin the iron in the next 10 minutes turn the station off.
Keep your tip clean, I wipe my tip on a damp sponge after every solder joint is completed.
I hope that you found this informative. If you should have any questions feel free to ask.
Jayefuu says: Jul 9, 2012. 1:09 PM
Nice writeup. I think the most common mistake people make is using the wrong size tip for the job. Soldering large wires? That tiny tip isn't going to get enough heat into it!!! I was as guilty as anyone of this at one point.
ColorBomb (author) in reply to JayefuuJul 9, 2012. 4:04 PM
yes soldering is quite easy when you have the right equipment.
pfred2 in reply to ColorBombJul 12, 2012. 9:51 AM
I can solder with a pair of pliers holding a rusty nail over a candle. It is all in the wrist!
ColorBomb (author) in reply to pfred2Jul 13, 2012. 4:42 AM
I prefer this method, surprisingly rusty nails tin very well. ;0)
diy_bloke says: Jul 9, 2012. 2:02 AM
isn't a hoof tip just a round chissel tip? if not then i don't know what one of them is
ColorBomb (author) in reply to diy_blokeJul 9, 2012. 4:11 AM
a hoof tip has a flat angled side like a hoof. this way you can apply solder and run it across leads and drag solder. see picture 3 above, it has solder on it so you can't see how flat it is.
diy_bloke in reply to ColorBombJul 9, 2012. 5:55 AM
Thanks I figured that, but is the chissel tip then just an angled square tip?
ColorBomb (author) in reply to diy_blokeJul 9, 2012. 4:03 PM
a chisel is more rounded than square, imagine a conical tip then imagine slicing an angle off two sides from the tip, see image number 2 above
diy_bloke in reply to ColorBombJul 9, 2012. 4:37 PM
ok now i fully understand. Thanks
killerjackalope says: Jul 8, 2012. 4:10 PM
Was using a butane iron with a wrecked tip for small gauge wires (repairing a damaged speedlite) and it was hell, not being able to pick up the solder easily made the work really tricky...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
