Turn Your Cell Phone's "I Got Wet" Indicator from Red back to White
Turn Your Cell Phone\
Ever dunk your cellphone in water? After it is dry - how could some one tell that it ever got wet? Well my friend the "i got wet indicator" is a dead give away. This indicator is ucusally a white sticker located in the battery compartment of most cellphones. It turns red after it is gotten wet.
In my case i had my cellphone in my pocket in the rain and it got damp. This is BS in my opinion because water neveractually tocuhced the unit.
All that i suggest you do is put a drop of bleach on the indicator and it will turn from red back to good 'ole white. check out the pics!
Step 1Below you can see 2 razr phones
one got wet [red dot] one didnt [ white dot].
27 comments
Apr 28, 2009. 12:35 AMLunera says:
if its a nice phone, and you can get to ALL the stickers, of which I know my moto z3 has 3 of and the samsung a707 has 2, in addition to the batteries having them as well, you COULD go buy one of those $20 throwaway phones. Peel and replace.
Sep 28, 2011. 2:21 PMfejes says:
Someone took my phone at school and gave it back by putting it in the water fountain and now won't turn on. My Samsung Flight 2 dot turned to red. If I bleach it, will the phone turn on?
Nov 29, 2011. 6:22 PMbthacker3 says:
lol your special, your phones fubar no amount of bleach on the sticker will fix that you may need some more for your hair though......
Sep 28, 2011. 9:47 PMHelenaHanbaskett says:
Hi-
I had to send my phone back after they sent a replacement due to a back light problem I had. I HAD ZERO WATER DAMAGE, and the sticker was WHITE,
B U T... I am an idiot and did not pay attention when I took the old phone into the kitchen to clean it (it was not filthy but a little funky) and I used a spray mist to dampen the screen and wiped it off. The battery and back cover wasn't on it because I had already put them in/on the new phone and a tiny bit of the mist got on the back/white sticker somehow and it turned red on the edges!
I PANICKED!
I cannot afford to pay for the phone!
LUCKILY I found the stickers on ebay for 1.75, peeled the red edged one off and put on a new white one. I do not feel bad about doing it because the phone truly had no water damage. Those little stickers are hyper sensitive to moisture.
Aug 18, 2009. 12:30 PMmdog93 says:
dus this work as an indicator again or not, is it just to make it look like it hsn't got wet? just out of interest :) mdog
Aug 3, 2011. 3:02 PMkillbox says:
more likely its is due to the red being a water activated dye, and its pretty much done its job when it goes red. the bleach oxidizes the pigment,
be warned the phone often has 2 water indicator spots, so if you have to send it in, they will likely find the internal sticker is still red. and there is often one on the battery too.
Aug 19, 2009. 5:03 AMmdog93 says:
cool, lol i don't think i'll try it though :P mdog
Jul 25, 2011. 8:36 PMkjandrokovic says:
So I have NEVER gotten my phone wet in my life... & all of a sudden it turned purple! Yeah, I'm kind of confused! Does anyone know what could have happened?? I take great care of my phone.
Jul 25, 2011. 8:51 PMkjandrokovic says:
There's even one on my battery that had NO harm done to it.
Jun 26, 2011. 11:46 PMjlowe5 says:
it works =) Now i have a question? does this mean my phone is going to work now ?
Sep 16, 2009. 7:53 PMBBBower says:
Unfortunately the stickers that you are attempting to change back are not the only things that will show liquid or moisture damage to the device. The sticker is simple, a clear plastic film on top, a white permeable material next and a red dye on the bottom, once the moisture or liquid has seeped past the plastic and the material it mixes with the dye and the dye is left to dry out in that previously white material. Bleaching it white doesn't always do the trick as a lifting the edge of the sticker would normally show the red dye on the bottom and bleaching it of course removes that indication. Replacing the indicator can work, but usually if the phone has sustained that much moisture then there are surely signs on the inside of the device such as rust on the board and corrosion which are more visible that those red dots. Many cell phone companies offer replacement options now such as warranty exchanges, however they have wised up and are starting to charge customers back up to the full amount of the device if they feel they have been defrauded, so if you are planning on sending it back or trying to trick someone do so at your own risk, I work in a repair center and they have not only strict down on customers but on employees as well, if I don't detect a moisture damaged part or phone when someone returns it i'm out of my own pocket up to $300 for the mistake.
Mar 7, 2011. 5:42 PMsnallc09 says:
I think someone is blowing smoke up your rear or trying to scare you. I'm also in the commonwealth of VA and an employer, and you cannot fire someone for making a mistake. Make the same mistake after being warned and having written verification for that warning and then yes they can let you go, but they still cannot deduct the damages from your paycheck. They CANNOT monetarily charge you for a MISTAKE or you would have a lawsuit.
http://www.doli.virginia.gov/laborlaw/laborlaw_faqs_wagep2.html
Read #9
Jan 1, 2010. 8:58 PMmicobanff says:
If they take money out of your pocket or off your paycheque, I suggest you go to the labor board... that's against the law... if infact what you say is true.
Feb 26, 2010. 11:15 AMBBBower says:
Wish it was that easy, they can't legally take it but im in va a commonwealth state, they can say make it right or you dont have job, which is basically I pay for it or go to the unemployment office.
Feb 26, 2010. 1:18 PMBBBower says:
Once again they take the money, or i'm fired, I don't know where you live but i'm in a commonwealth state they can fire me if they don't the way my farts smell....  the only thing you can win in court here is your unemployment for a few months
Feb 26, 2010. 7:28 PMmicobanff says:
Yeah.... I live in Canada, once you have worked somewhere for 3 months, they need real cause to fire you (being late, with 3 written warnings, signed and dated by employee and employer) or something serious, sexual assault, harassment, stealing, etc... Otherwise one could sue for wrongful dismissal, and the company would not only owe you backpay, they would have to offer you your position back... then the labour board keeps an eye on them and makes sure said employee is treated fairly.
Aug 12, 2010. 10:50 PMdidgindjembe says:
@ vzw in nj, usa, at tech support, they only check the exterior labels, so this should work. stick it to those bastards! i was thinking of painting a lacquer or something on for future reference. anyone try this? is it noticable?
Mar 11, 2010. 9:51 PMgofast7 says:
White Dot on Phone issue.
When you first get the phone, take a piece of clear packing tape and cut a round piece about the size of a dime. Tape over the dot.  Make sure the tape is completely stuck down (no bubble tunnels in tape).
I have dropped 3 razors and a pantech in toilets and pools (razor kept slipping out of my back pants pocket in the ladies room....).
The second secret - grap out of the water FAST and just as quickly open the phone and dump the battery out. EVEN IF THE PHONE IS STILL ON.
Take the Sim (and storage card out if you have one) and dry with lint free cloth.
open all the ports on phone, then shake it as hard as you can to force water out as much as possible.  Then put opened phone in front of a hair dryer, on low heat for at least a day.
You may get condensation on the screen.  If you do, continue the hairdrying until it all burns out.
Do not put battery back in and turn on until you are absolutely sure it is dry.
In addition to my accidental drops, I actually 'soaked' my Pantech on purpose. I had spilled a full glass of soda on the phone and could see that liquid got inside the screen & in between keypad.  So again, removed the battery, sim/storage cards, put an extra layer of tape over the white dot and soaked the phone for a good 10 minutes in warm water.  Shook it around to loosen the sticky liquid. Then followed the steps listed above.
2 of the Razor phones were eventually turned in because the "flip" screw broke.
The Pantech was returned because one of the sliders broke.  Each time I was ask if phones had been exposed to water.....
Good as new!
Jan 12, 2010. 2:11 PMcknuts17 says:
This is by far the best way to save a cell phone from water damage:  http://www.ehow.com/how_5854392_save-cell-phone-got-wet.html
Apr 27, 2009. 9:20 PMEaglesNest says:
Did the dot ever turn completely white again?
Apr 27, 2009. 10:52 PMuncle_al_0 says:
If you were to try and warranty this you might have some problems. The reason being that there is another one of those stickers inside the case of the phone to prevent tampering. And I have a question for you, if the sticker gets wet again does it change back to red? I ask this because they might test the sticker to see if its been tampered with. Great ible tho! Al
Apr 27, 2009. 10:23 PMjeandeau says:
Now that is a useful instructable. Restore true justice in the world!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:MolecularSandwich
