Introduction: Ultrasonic Distance Measurement NRF905 Wireless Transmission System Based on Arduino
ICStation Team introduce you this ultrasonic distance measurement NRF905 wireless transmission system with ICStation UNO and Mega 2560 compatible with Arduino. The working voltage is DC5V. It uses ultrasonic to measure distance and realizes wireless transmission with NRF905. The minimum accuracy of this design is one centimeter. The measuring effect is best between 3 and 100 centimeter. It can be used in the area where has no high demand of accuracy, such as the obstacle avoidance of robot and the distance detection alarm when reversing a car.
Functions
1.When start up, the hardware initializes. The ranging module displays the prompt characters. After the initialization of the ultrasonic module finishes, it begins to display the measuring distance and starts the wireless transmission.
2.When the transmitting module works, you will see the sending end of the development board flash, at the same time, the value displayed on the LCD1602 refreshes continually.
3.In the receiving end, when receives the data successfully, the LED on the development board flashes and data is sent to the upper computer to display.
4.When change the distance between the object under test and ranging module, observe the data displayed on the LCD1602 in the sending end and the upper computer in the receiving end. When to increase and decrease the measuring distance, the displayed data changes correspondingly and the response accuracy is 1centimeter.
Code for your reference
RX part:
http://www.icstation.com/newsletter/eMarketing/nRF905_wireless_transmission.txt
TX part:
http://www.icstation.com/newsletter/eMarketing/nRF905_TX4_17.txt
Step 1: Components List
Step 2: The Hardware Schematic Diagram of Receiving End
Step 3: The Schematic Diagram of Sending End
Step 4: Connect NRF905 Module to the ICStation UNO
Define the NRF905 module and ICStation UNO as following and connect the sending end and receiving end.
TXEN=5; TRX_CE=6;PWR=A0;CSN=4;AM=7;DR=3;CD=2; MOSI=11;MISO=12;SCK=13 ;
Step 5: Connect the Ultrasonic Ranging Module to the ICStation UNO
The definition of the pins of HC-SR04 module as the picture shows.
Define other functional pins as following:
TrigPin=8 EchoPin=9
Step 6: Connect the LCD 1602 to the ICStation UNO
RS=A1, E=A2,D4=A3,D5=A4,D6=A5,D7=10
Step 7: The Whole Effect of Sending End After Connection
Step 8: The Whole Effect of Receiving End
Step 9: Video to Show the Effect
Sensors Contest
