3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Universal (theft) protection for electronic equipment or cars with invisible switch
I'll show how you can utilize a reed switch as a universal protection for electronic equipment or cars. All you need is a reed switch and a magnet. For cars you'll need a power relay to increase the switching capacity of the reed switch.
A pictorial and a video demonstrates how to build an invisible switch into a PC. A schematic is shown how to apply this technique for cars.
Step 1How to make an invisible switch in a PC step 1
I'll show how to protect a PC with a hidden switch. You'll be the only one who can turn it on and thieves will not directly be able to turn it on unless they take your pc apart and start 'fixing' it.
The first picture shows the reed switch which we will use. It's a glass tube with two contacts which are pulled towards each other making contact when a magnetic field is present. You can reed(read ;-) ) more details on wikipedia. http://en.wikipedia.org/wiki/Reed_switch
For the PC we'll use a read switch with a make contact.
The first step is to remove both side pannels from the pc housing by unscrewing the bolts shown in the picture. After that the front panel can be removed by pushing the front panel retainers together with your fingers to unlock them.
66 comments
1-40 of 66next »
Jul 25, 2008. 9:32 AMdaemonkrog says:
So you're putting a magnet.. by your hard drives...
Aug 4, 2011. 7:00 AMskylane says:
Hard drives have two extremely powerful magnets inside them.
WAY, WAY more powerful than the magnet in this instructible.
No one is ever concerned about getting their hard drives too close
to other magnetically sensitive materials.
Your concern is good, but flawed :-)
Dec 10, 2008. 8:30 AMTh3H4rRy says:
the magnet needed is no where near strong enough to damage the hard drives. Hard drives have surpassed the time now that near by magnetic waves damage them. Unless those of a very strong power
Dec 11, 2008. 12:52 AMdaemonkrog says:
Useful information. I was pretty skeptical about that answer.. but you're right. I stand corrected.
http://www.pcworld.com/article/116572/busting_the_biggest_pc_myths.html
Jul 29, 2008. 5:04 PMilldoyourdrugs says:
Ha ha ha Exactly! Not so smart.
Oct 27, 2009. 12:47 AManimal0307 says:
Very impressive. I like the idea. But I have a small suggestion to make. Forget the switch at all and just put in the reed switch. You could mystify your friends by just waving your hand over your computer case, (with a magnet concealed with a bit of slight of hand) and like magic it turns on. You are now a true master of technology.
Oct 9, 2009. 9:59 AMnolte919 says:
Your video was removed by Metacafe.  I don't suppose you'd make it available again.
Sep 20, 2009. 1:46 AMR3N3 says:
very nice. will use.
Jul 20, 2009. 7:40 PMixisuprflyixi says:
you could also mount a magnet in the table under the PC and the reed switch in the bottom of the PC, so it sits just above the magnet then hook the reed switch to an alarm in such a way so that if the PC is picked up or moved slightly it would sound an alarm. That is another theft prevention device.
Apr 24, 2008. 3:31 PMgannon12raiders says:
I've been looking all over online and I can't seem to find reed switches, and the local Radio Shack, Circuit City, Best Buy, Hobby Lobby, Fry's Electronics, and (of course) Wal*Mart ALL yielded nothing. Anybody got a suggestion?
Jul 28, 2008. 2:37 AMratgod says:
I got some cheap door alarms from Dollarama, they have a reed switch in the sounder side.
Apr 30, 2008. 9:44 PMyoyo123aj says:
1 word ebay, I bought 20 reed switches for 5 bucks.
Jul 23, 2008. 2:18 PMapburner says:
Mouser is where I go for most of my discrete components.
Here is the link to the page in there catalog for reed switches.
The bottom ones are truly tiny little things.
reed switches
Jul 5, 2008. 9:46 AMcraftsman says:
i lose stuff alot and am afraid of losing the magnet are there any other switches that might be like this like a finger sensor?
Jul 5, 2008. 7:37 AMlux4x4 says:
Very good ..i use it about 20 years!!!!!! in my cars i use a step-step switch, so i use the reed switch only for a second to pulse a + ! It works from 20 years!!
Apr 21, 2008. 8:49 AMArtificial Intelligence says:
Cool, however harddrives + magnets is not the best combination.
Jun 1, 2008. 2:47 AMDerin says:
a hd is shielded which means covered with metal and there are huge magnets in a hd
Jun 2, 2008. 5:31 AMArtificial Intelligence says:
Not all HDs are shielded and an external magnetic field would disturb the magnetic fields created by the magnets inside the HD. However this doesn't happen every time.
Mar 17, 2008. 2:04 PMwesie42 says:
if i am correct, as soon as you take your magnet off, the computer will turn off
May 22, 2008. 12:08 AMRob K says:
Nope power buttons on computers are momentary, Hanzablast could have just used the reed switch to turn it on,
Mar 27, 2008. 8:48 PMdusty.crockett says:
No, it won't. That wire isn't nearly big enough to provide the power to run the PC, just the switch to turn it on.
Mar 19, 2008. 9:46 PMdkfa says:
yea?? wont it turn off like wesie said?
Apr 5, 2008. 3:36 AMGo_Back_To_School says:
....wow... just wow.... NO it WONT turn it off. I wont even bother explaining why. Just live with it.
May 21, 2008. 10:39 PMdaemonkrog says:
problem is.. this wont protect your data at all, nor your pc from being stolen. More of a keep my friends and family from being able to turn my pc on type thing.
May 21, 2008. 8:03 PMcasey321b says:
try doing the same thing but with your mouse too. that would be super cool!!!
Mar 11, 2008. 7:52 PMYerboogieman says:
find a way to mount that magnet in your finger
May 21, 2008. 8:01 PMcasey321b says:
like they said a ring that is magnatized
May 21, 2008. 7:46 PMcasey321b says:
I would make a slot and put the magnet inside the key(probly your house key that would be good) so you would use the key and no one would suspect it was a magnet at all!!! and it would look cooler
Feb 23, 2008. 9:41 AMjdege says:
More fun with reed switches. How about this one: 1. Build a magnet into a ring. 2. Wire a reed switch into your TV remote control. 3. Irritate everyone you live with, when you're the only one who can change channels.
Apr 23, 2008. 8:35 PMgannon12raiders says:
That. Is. Amazing.
Feb 23, 2008. 12:38 PMDeusXMachina says:
ULTRA WIN! You could pretty much make all your stuff in your house, your car, etc based off of reed switches, if you were so inclined/paranoid.
Feb 23, 2008. 11:04 AMFrenchCrawler says:
I installed a momentary push switch into ours due to certain reasons. Now it'll only work if the battery cover is on (for some reason the battery cover would always get lost before, so I used that to incorporate the location of the switch).
Mar 10, 2008. 3:52 PMcooldog says:
where do you get the reed switch and are they water proof
Apr 21, 2008. 9:12 AMsolidacid says:
In an electronics store, most reed switches are waterproof.
Apr 6, 2008. 7:11 PMacewingman says:
The momentary switch that turns the ATX PC on just completes a short between two pins on the power supply. Inserting the reed switch is just like adding another momentary switch. Once the power supply is turned on it does not matter if the circuit has continuity and therefore the magnet being removed will not cause the PC to turn off.
Feb 29, 2008. 4:55 AMapburner says:
Also most case frames are steel. The magnetic field will not go though this to any great extent. I find that if I place magnets on my case I can use them to hold Small parts or other things on the computer while I work at my desk. I have a letter opener and TV remote both stuck to my computer with magnets that I have glues to the remote and opener. No problems with the hard drive. The only thing that might be bothered is the floppy drive and I haven't seen a floppy used in several years now.
Feb 26, 2008. 5:44 PMS1L3N7 SWAT says:
Sweet!! This would be good for laptops.
Feb 25, 2008. 9:04 PMmembrane says:
Neat trick I might try it on one of my cars though you might want to solder the connection vs just twist wires on the reed switch.
Feb 25, 2008. 5:42 PM23mcharlotte says:
Nice Ill do somthing like this in the future
1-40 of 66next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:hanzablast
