Use Arduino with TIP120 transistor to control motors and high power devices
 by techbitar
Hello again.
So you have a DC motor or lamp but no matter how you connect them to your Arduino they just won't work? Guess what, the Arduino is a brain that comes with small muscles. It can control LEDs and other low power nicknacks but not those power motors or lights you need for your next project. The Arduino is good at thinking but not for heavy lifting. Lazy lad.
There are a few add-ons out there that you can buy such as power and motor shields for your Arduino. They have all the muscles in one nice package. Slap those shields on your Arduino and you are ready to control motors and other high power stuff (some soldering may be required.)
Or you can do it yourself for a fraction of the cost and double the pleasure. Enter the TIP120 and its sidekicks.
THE TIP120 DARLINGTON TRANSISTOR
The TIP120 is an NPN Power Darlington Transistor. It can be used with an Arduino to drive motors, turn lights on, and drive other high power gadgets.
The TIP120 acts as a power broker or gatekeeper between the Arduino realm and the high power realm composed of the PC fan and its battery pack. The Arduino can tell the TIP120 how much power to pass from the external battery pack to the PC fan but the Arduino does not share any of its power or share pins with the PC fan or its batteries. The TIP120 is the go in between.
The TIP120 has three pins. One is called Base, which we will connect to any of the Arduino PWM pins. Through the Base pin, the Arduino can tell the TIP120 how much power to supply to the motor from the external battery pack. That's it. The TIP120 does the heavy lifting while Arduino sits back and gives orders through one of its PWM pins to the TIP120 Base pin telling it how much power to pass to the motor. The poor TIP120 has to then pass the requested power from the external power to the motor based on Arduino's request.
THE PROJECT
In this tutorial, I will build a basic circuit in which I use an Arduino to control the speed of PC fan via the TIP120. You can take this basic circuit and replace the fan with other devices.
If you want to know more about Darlington transistors you can spend some time at Wikipedia http://en.wikipedia.org/wiki/Darlington_transistor It's an interesting read but you don't really need to understand it to use the TIP120. Heck I don't know what most of this stuff means.
THE SIDEKICKS
ENTER THE 1K RESISTOR & 1N4004 DIODE & 1UF CAPACITOR!
The TIP120 is a very robust item. It can handle lots of power (see specs) but the Arduino can't. So we must protect the Arduino from potential party crashers. For starters, we use a 1K Ohm resistor between the Arduino pins and the TIP120 Base pin. This is insurance against electric shorts. The TIP120 can handle 60V and 5A but I assure you the Arduino won't.
Then we have those DC motors. The internal brushes on toy/hobby DC motors generate lots of potentially harmful sparks and stray electricity that needs to be blocked. Instead of guessing which motor is safe and which is not, we simply add a $0.20 diode and $0.10 1uF ceramic capacitor to our circuit. Some electromechanical devices such as solenoids may require different capacitors.
Placing the ceramic capacitor on the + & - poles of the motor will act as suppressor of sparks and surges generated by motor brushes, which can be harmful to your circuit.
A small ceramic capacitor in the range of .01 to 0.1 uF is probably sufficient to offer protection from hobby DC motors. But If you are using brushless motors, such as the PC fan I am using in this tutorial, don't use a capacitor.
As for the 1N4004 diode, it allows current to pass in one direction from positive to negative but will block any stray current that tries to go in the opposite direction, which might have undesirable effects on your circuit.
Unlike resistors which allow current to flow in both directions, diodes were designed to let current pass from positive into negative, not the other way around. When you look closely at those small diodes we use in our projects, you will see a ring on one end of the diode cylinder. This tough guy can block high voltage (400V) with high current (1A). Again, no need to understand all this stuff so long as you connect the circuit properly.
I am a picture person so I have lots of pictures to help me explain my point.
PARTS
- TIP120 transistor (datasheet: http://www.futurlec.com/Transistors/TIP120.shtml ) $0.70
- Diode 1N4004 (datasheet: http://www.futurlec.com/Diodes/1N4004.shtml ) $0.20
- 1K Resistor (Brown, Black, Red, Gold) $0.10
- 1uF ceramic capacitor to be used with hobby DC motors $0.10
- Arduino UNO with IDE
- Breadboard
- PC fan or hobby DC motor
- 9V Alkaline or 7.2V NiMh batteries (6 X AA)
- Wires.
NOTE: I don't get commission or any perks from linking to Futurlec.com. I just like their service and prices so far.
TEST SKETCH
// Define which pin to be used to communicate with Base pin of TIP120 transistor
int TIP120pin = 11; //for this project, I pick Arduino's PMW pin 11
void setup()
pinMode(TIP120pin, OUTPUT); // Set pin for output to control TIP120 Base pin
analogWrite(TIP120pin, 255); // By changing values from 0 to 255 you can control motor speed
void loop()
CREDITS
I must thank http://luckylarry.co.uk for his super blog.
TIP120: THE MOVIE
1-40 of 45Next »
Ozzie_G says: Jun 12, 2013. 1:57 AM
bluetech7 and Belleye
With the relay you would be able to ON/OFF the 24VAC.
But be aware that the relay wont switch at the PWM frequency and you will have no control over the effective current on the AC side.
bluetech7 says: May 29, 2013. 7:37 AM
if you use a relay with a DC coil you can control 24VAC :)
Belleye says: May 26, 2013. 4:10 AM
Could I control 24vac with this circuit?
malk4vi4n says: May 15, 2013. 8:30 PM
Thank you very much. Great instructable, it worked well on my UNO R3 for controlling a 12V 0.17A PC fan. The only downside is the noise now generated by the fan, is there anything to do about it?
bluetech7 says: May 14, 2013. 8:17 AM
Almost, but you'd have to add a resistor in series with your DC motor.  Because as you stated, your motor is 3v and not 9v (like the battery source you wanna use).
You said your motor was 3v 95mA, so do this... Take 9v (your battery) - .7v (the drop across the collector/emitter junction) - 3v (you want to drop across your motor) = 5.3v (remaining voltage you'll need to drop across a resistor).
What size resistor depends how much current you want to run through the circuit.  You said your motor can handle .095A (95mA), sooo take the 5.3v (you need to drop across the resistor) / .095A (the current you wanna run through your motor) = 55.79ohms.  Doing a quick google search for standard resistor values I find this nifty chart ( http://ecee.colorado.edu/~mcclurel/resistorsandcaps.pdf ) to see that a 56ohm resistor is pretty darn close to what you need.
What power rating should your resistor be?  Remember that P = I x V so, P= .095A (current through the resistor) x 5.3v (voltage across the resistor) = .5035 watts.  So a 1/2 watt 56ohm resistor is what you need.
Can't find a 1/2watt 56ohm resistor?  Well, two 120ohm in parallel to each other will probably work too.  Here's why... remember 2 equal value resistors in parallel = half the value of one of the resistors.  So, half of 120ohms is 60ohms which is close to the 56ohm resistor you need.  The 5.3v across these 2 resistors in parallel (60ohms) will limit the current to .088A ( 88mA ).  Each resistor will have half this current flowing through them, so .044A x 5.3v = .2332watts.  So two 1/4 watt 120ohm resistors in parallel will also work for you.
Thinking a little further, using a 9v battery & the resistor is kinda a waste of energy.  Here's why... you need the resistor to limit the current (through your motor).  The resistor also is a place to drop some voltage (5.3v) to limit the voltage drop across your motor to be 3v.  But remember the resistor is burning up .5035 watts of power, basically a heater wasting energy (do you need to heat something?).
Another way to go is to use two AA batteries (3V) and no resistor.  3V battery - .7v (the drop across the collector/emitter junction) leaves you 2.3v to drop across your motor.  This might just get the job done for ya, and not waste .5035 watts of power to heat up a resistor!
In some cases, you'll need to limit current/ reduce the voltage drop across  something by adding a resistor in series (lets say in another part of your circuit you really needed the 9v), aaand you don't feel like have 2 power supplies.  In other cases, if you re-think your circuit based on your needs and trying to design a very efficient circuit, you might find you can save energy by changing your power supply to be closer to what the load (your motor) requires.
mkoerner says: May 12, 2013. 7:13 PM
Great explanation! Will I be able to use this set up to control a single 3v 95mA motor using a single 9v battery as the dedicated power source?
bluetech7 says: May 3, 2013. 1:19 PM
1. when diodes are connected with reverse polarity they appear as an 'open' with no current flowing thru (from end to end) of the diode.
2. in this case, notice that the diode is connected in parallel to the collector/emitter junction with cathode to collector (not emitter) so when the TIP120 NPN transistor is ON (via some base current) current will flow thru collector/emitter (and to the DC motor), but no current will flow thru the diode (remember, it is reverse polarity because the collector is more positive (facing the +5volt supply) than the emitter (facing GND)).
3. the purpose of connecting the diode this way is so that when power to the DC motor is removed (switched off) the big reverse polarity spike (from the DC motor's magnet field collapsing) doesn't hurt the transistor.
4. at the moment the power to the DC motor is removed and the big reverse polarity spike occurs, the diode will then be forward-biased (pretend you reversed the +5volts and GND for a moment) and detour all the reverse magnetic field generated current thru the diode (and not thru the transistor's collector/emitter junction) since current will take the path of least resistance. This reverse-polarity condition only lasts a second while the magnetic field collapses and the energy dissapates.  But it has enough potential sometimes to damage sensitive parts, if some protection isn't designed into the circuit.
5. to understand a diode's function, sometimes it helps to think of it as a wire (zero-ohms) when forward-biased and an 'open-circuit' (infinite-ohms) when reverse-biased.  But more precisely, when forward-biased it will drop .7volts.
I probably used toooo many words to explain this, but I hope it helps.
jobigoud says: May 1, 2013. 2:43 AM
Very nice article. The pics are very helpful.
In similar circuits, I have seen a resistor between the external power and the motor, to limit the current sent to the motor. Are you sure it is not needed here ?
jpettit says: Mar 5, 2013. 8:27 PM
I understand the need for the diode, I just don't understand its placement. Could you explain how reverse flow is stopped opposed to bypassing the diode? Thanks.
krischristian says: Feb 19, 2013. 2:50 AM
why is the negative side of the diode connected the collector and not to the emitter??? plsss reply....
hsteve says: Feb 18, 2013. 5:58 PM
Hi there,
I'm finding it hard to get discrete components (and I'm not an electronics buff).
I have an old motor speed control kit (as yet unassembled) that contains two transistors
BC639, BC640
Are either of these a substitute for the T1P120 listed here ?
dtallon says: Feb 2, 2013. 4:15 PM
My Uno R3 works perfectly from a 12V, 1A power supply...
Elac. says: Sep 20, 2012. 2:06 AM
Nice write up, very useful.
For TIP120 Taydaelectronics stocks them for $0.24 a piece.
matt.e.jenkins in reply to Elac.Jan 28, 2013. 2:32 PM
i was going to say the same thing.
recwap says: Dec 6, 2012. 5:29 AM
HI, nice work!
i made somethink like this but using an optoucupler, look here: PWM Arduino
leeseibert says: Nov 26, 2012. 9:44 AM
I used this method in my project. Thanks for the explanation! See video of my project here: https://www.youtube.com/watch?v=aM2c6G9CHhY
studiofla says: Jul 29, 2012. 1:34 PM
Hey there,
many thanks for the tutorial!
I have the arduino controlling a fan (DC12V 0.14A).
the fan is being powered by a 12V 0.5A adapter.
I now need to have the Arduino run without my laptop, can I use another 12V 0.5A adapter to do this or do you have a b etter suggestion?
Many many thanks
Best
rwouters in reply to studioflaSep 30, 2012. 2:30 AM
Don't use a 12v adapter, it won't be so good for your arduino(or at least the voltage regulator) I would reccomend using a 9 v power supply of any kind.
kailash174 says: Jun 14, 2012. 3:36 PM
Hi,
I am planning to build a circuit which senses my moments(i'll use a sensor) and activates the solenoid(24v).. So can I drive this solenoid by connecting 2 9v batteries in series? And about the secuirty portion of my circuit, I am using a 1N4007 diode and NTE261 transistor along with a 2.2kOhm resistor. Is it necessary for me to use a capacitor just like you have mentioned for the above project? Kindly advice me on this. Thanks in advance!
Joe_M in reply to kailash174Jul 6, 2012. 6:29 AM
Solenoids are basically an electromagnet, and are composed of a coil of wire with a movable metal core. When the solenoid is actuated, it generates a magnetic field that pushes the metal core in one direction. The action of the solenoid can create spikes in voltage, and you would want to protect your delicate microcontroller from those spikes. I would use a diode to keep any voltage from feeding back to the controlling circuit. There is another tutorial on controlling solenoids here> www.instructables.com/id/Controlling-solenoids-with-arduino/
Joe
kailash174 in reply to Joe_MJul 6, 2012. 7:24 AM
Great! Now I have got this circuit working. But I'm using a PING Ultrasonic sensor and I'm having hard time controlling it with the code. Do you have any idea about how to control and make the readings precise for the Sensor? If you want, I can post my code here... Thanks for your previous reply!!!
Joe_M in reply to kailash174Jul 6, 2012. 10:19 AM
Try starting a new thread to change the topic.
kailash174 in reply to Joe_MJul 6, 2012. 11:06 AM
Ok!
lchristodoulides says: Jun 20, 2012. 4:15 PM
Would this work with a 24V, 120W brushed DC motor?
If not, what changes would need to be made?
If it does work, could I use a 2N3055H or TIP3055 transistor? as I cannot seem to find a TIP120 or TIP121.
Thanks.
Joe_M in reply to lchristodoulidesJul 6, 2012. 10:18 AM
Also, any type of transistor can be found via Google. The tip-121 can be bought for .39 from http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_32993_-1
Of course, you can use whatever power transistor you can get your hands on, just research it's ability to hande the power, and voltage you intend to use it with, and you should do well. A heat sink may be required for certain parts, or certain operating conditions.
Joe_M in reply to lchristodoulidesJul 6, 2012. 6:15 AM
Hi Chris, I believe you can use most big transistors, and yes the 2N3055, in most any case style, is one of the more commonly used pass transistors. They are called pass transistors because they are used as a way to pass high current voltage under the control of a less powerful circuit. One of the most common places to find the 2N3055 is in power supplies. It is very common to find two, or more 2N3055 transistors bolted to the back panel on many power supply designs. When a transistor is used as a pass device, most transistors will work. The differences become more restrictive when you move into amplification of frequencies, as in A/C. The typical way to control line voltage, 120 VAC, is with a Triac, but Triacs are for another discussion. The faster the frequency is, the more involved the use of transistors will be. DC is by far the easier of the two to work with. Ohms law will help you decide which parts are appropriate for any changes you would want to make to this excellent instruction. The title I would give this article is "How to use pass transistors to increase the muscle of your microcontroller."
conorowenbarry says: Apr 15, 2012. 7:45 AM
Very good tutorial,
Just what I needed to know.
I have found however that the batteries I use to power the motor are being drained very quickly.
I am using motors taken from a handheld fan and the battery pack of 2xAA that came with it. They can run for hours on end normally but when hacked to incorporate this circuit they only last a few minutes.
Would anyone have an idea why?
ms10 says: Apr 11, 2012. 2:59 PM
are there any other transister i could use
AntzyP says: Jan 8, 2012. 2:39 AM
Hi techbitar,
I am using TIP121 since I could not find TIP120. I have to run 3 motors with seperate PWM pins on arduino and seperate TIPs, but sharing the same battery source. Since a battery would not suffice powering 3 3v motors, i used a 12V 500mA wall wart.
It was going fine with 1 motor running at full RPM but as soon as the 2nd motor starts, the first one slows down and on the third one starting, all 3 are just about crawling. I tried using the circuit with just 1 TIP and motor with 9volt battery and the batter was drained in 5 minutes. I'm pretty sure the circuit is all correct. Can you please help me. Should I get a wall wart with higher amperage? Thanks!
buteman in reply to AntzyPApr 8, 2012. 4:08 PM
You will probably find that the wall wart is not able to supply enough current for the 3 motors. In fact from what you describe it cannot even supply enough for 2. If you have a wall wart which can supply 12 volt and 1 amp, or better still 2 amp you will likely find it works.
nbrown14 in reply to AntzyPApr 1, 2012. 1:41 PM
Hi AntzyP,
I saw this post, and I am trying to do a system you describe here with four motors. Do you mind sharing your schematic and the wall wart you had to use to resolve your power issue?
AntzyP in reply to nbrown14Apr 3, 2012. 9:53 AM
Hi nbrown14,
I used a schematic similar to the one shown here:
http://bildr.org/2011/03/high-power-control-with-arduino-and-tip120/
you can replicate this circuit for 4 motors. I was able to run 3 motors rated at 3v using a 5V 3A wall wart. The voltage and current rating of the wall wart will depend on the motors.
My motors took about 500mA while running. They need to delivered about twice the current(due to stall currents, i.e. extra current required for starting motors up). So I took about 1A for each motor. So for 3 motors, I estimated the wall wart with 3A rating should be fine. And it did work awesomely :)
Let me know if you need any more help...
-Antzy
techbitar (author) in reply to AntzyPJan 9, 2012. 12:07 AM
There are many possible issues with your circuit and without seeing a schematic and your motor specifications it would be difficult to pinpoint those issues that are causing the problem.
AntzyP in reply to techbitarMar 12, 2012. 9:12 PM
Thanks for your help. I found that the curent wasnt large enough. Using a higher current wall wart solved the problem.
Thermionic says: Jan 22, 2012. 8:50 PM
Great job man, I've wondering about interfacing Picaxes and motors for a while, this Instructable hit the spot!
techbitar (author) in reply to ThermionicJan 24, 2012. 9:13 AM
Thanks. I have a couple of PICAXE chips and I just love their versatility and ease of deployment. I have a couple of project ideas to put those ICs into action.
zanklob says: Jan 4, 2012. 7:45 PM
Hi,
i am trying to make a 4-pin intel pc fan to work with a temperature sensor(LM335A).the fan to act according to the temperature.
i was wonderding how the schematic would be..
cjensen25 says: Nov 28, 2011. 11:58 AM
If no voltage was applied to the Base then would fan not spin (because its NPN - and gate not open?) or am I thinking of PNP - please explain if I am completely wrong!
techbitar (author) in reply to cjensen25Nov 29, 2011. 12:49 AM
The TIP120 in this project is an NPN Darlington Transistor. It's effectively two transistors in one package. Check the datasheet below. And yes we bias the base to turn on the TIP120 "switch" so the fan will get the juice it needs to work. The fan needs more voltage and current than what the Arduino pins can provide. So we use the Arduino as a controller only.
Computothought says: Oct 26, 2011. 3:50 AM
I might add an opto isolator.
1-40 of 45Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
