We are a team of second year Product Design Engineering students from Glasgow School of Art and Glasgow University.
Our aim was to produce the most efficient wind turbine out of the time and resources we had at our disposal. We researched many different designs and developed them until we reached our final solution.
Our design is based around a purpose built wind tunnel that we used to test our concepts and final design. The dimensions given could be scaled up or down depending on the application.
The following step-by-step guide will show you how you too can produce a cost-effective wind turbine.
Materials:
medium-density fibreboard (MDF)
sheet aluminium
extruded polystyrene foam
hardwood dowel
ball bearings
two bought-in gears
bought-in generator
Joining techniques:
panel pins
screws
PVA glue
hot glue sticks
Tools:
power drill
hand-held jigsaw
sand paper
hammer
metal file
tin snips
allen key
hot glue gun
bandsaw
sheet bender
guillotine
router
belt sander
hole punch
Remove these ads by
Signing UpStep 1: Fan Base
The MDF base is made of two 300mm diameter discs, with a 260mm diameter disc in between - all 18mm thick. These were roughly cut to shape using a bandsaw and then accurately sized using a belt sander. A hot glue gun and 30 x 1.6mm panel pins were used to attach the discs together.
The lower-most disc was cut to size the same way as the other discs. This disc had a 155mm outer diameter channel cut out using a router. The channel is for the ball bearings to run and its width was 6mm (chosen due to the ball bearings purchased).
Through all four discs is the hardwood dowel axle - 22mm in diameter - cut to 240mm in length using a bandsaw. A hole of the same diameter as the axle was cut through all the discs using a pillar drill. The axle was forced through and required no glue due to the accurate fit.
Visit Our Store »
Go Pro Today »
Another advantage that was claimed about this design is that in urban envirnments with buildings and trees that low level winds are very turbulant and constantly changing direction. traditional blade designs can't handle this low level turbilance which is why they're mounted up high on poles so they can catch clean air, but this design can be mounted at ground level with no loss of efficiency.
higher is better but there are lots of places where it's not possible like in urban or residential areas. vertical axis blade designs easily adapt to rapidly changing low level wind direction.
I did a quick google search for the turbine similar to this that i remembered. it appears that the company has gone under but here's the article.
http://www.greengeek.ca/magnetic-levitation-wind-turbines-now-available/
does that make sense?
sorry for the confusion.
Putting a heat insulator round the generator is a bad thing - keep it as cool as you can.
Was that large curve at the top just for looks or was there a tech reason for it?
We can get an amount of power from the windmill exactly in proportion to the wind force pushing against the blades. This means, if we recovered half the power it took to drive 60mph, the windmill would be creating exactly that much wind resistance for our poor motor to push through. What we gained through the windmill would have to be spent to keep the vehicle going at 60mph.
Realistically, we would lose several times more than we gained through inefficiencies, and at best break even with an additional time and material expense.
Perpetual motion is less important than being able to strap a harness to the forces all around you all the time. Even the best designs for perpetual motion machines only redirect another force to propagate the desired force.
Men tried an idea like this in the past and called it a sailboat, but it was not very effective in a headwind.
You could use it to charge your batteries. yes.
would it be free energy? no. not even close.
You lose all sorts of power in friction(every rotating part), heat(again, in rotating parts, and resistance in wires and circuits), circuitry losses(charge control circuit eats SOME power to operate), and that's all without talking about conversion losses, etc.
Best you could probably do is, very inefficiently, recharge your 12 volt lead-acid "utility battery" from the wind generator while driving, reducing, or eliminating the need for an alternator.
A belt drive alternator, or (and this is probably the MOST efficient) a DC-DC converter to charge the auxiliary battery straight from the main pack.
If you wanted to use wind power to charge your motive batteries... You'd be better off building a free-standing turbine that fits in your trunk.
when you stop, and there's wind, set it up, and plug it in.
It's no different to a solar-powered car (which I know works on a small scale, at least) and I can see no reason it wouldn't work.
I do understand why it looks like perpetuity - the car's forward motion would effectively create a wind over the blades, which may cause them to spin. But it's mainly the real wind rather than the relative wind which is driving the fan.
Somehow collecting and using the huge amount of energy wasted by internal combustion would be pretty cool, though. Years ago I gave a lot of thought about ways to collect and store some of the engine's lost heat radiated and blown away---no doubt a big chunk of the total energy released from the system.
I thought a lot about using tanks of phase-change material (Glauber's salt) to store heat that could then be released by exchangers into a domestic hot-water system--essential using it to preheat the cold-water side of the water heater. I got far enough to discover a few chemo-mechanical issues--some means of stirring and reconstituting the material would be needed to maintain its energy capacity. Also, losses from the additional vehicle weight would cancel out at least some of the salvaged energy. Oh, and who wants torpedo-like tubes of "heat batteries" strapped to the top of his car?
Alas, that was many years ago and I've given no more than a passing thought to the idea.
Todd
A typical case is for example to add a heavy wheel to absorb kinetic energy during braking, for release it later in the form of thrust when needed. Can you imagine how they would benefit cyclists with such a device? It would certainly be less accidents, because when you drive bicycle you try to avoid brake, in order to not having to make the effort to regain the lost speed. Conceptually the device is very simple and easy, but when it comes to implementing the idea, the sequence of problems is so great that it explains why no one uses it.
The problem with that statement is...it's just not true.
AT BEST, you'll THEORETICALLY be able to extract wind energy equal to wind speed.
60 MPH head wind plus 40MPH speed limit on your road = 60 mph energy available to your turbine.
Same 60MPH wind, and 65MPH speed limit = STILL 65MPH wind available, but now most of the observed wind energy at the blades comes first from the energy first delivered OUT by the batteries through the drive train.
To get a better idea of how LARGE a set of blades you'd need to BEGIN to notice the benefit... Goto the recent instructable http://www.instructables.com/id/Downwind-Faster-Than-The-Wind-Cart/
Notice how MASSIVE the blades are in proportion to the vehicle?
Also, note the extreme aerodynamics?
Same applies to the Solar Cars.
MASSIVE solar panels, and pre-charged batteries, with extreme aerodynamics.
That is because, to extract USEFUL levels of power from these methods, you have to redefine "useful".
Many of those vehicles would sprint along like lightning, using a tiny 5HP gas motor.
Probably the BIGGEST reason not to use a turbine to recharge your batteries, while driving is... you have to get that wind TO the turbine.
You'd be much better off spending your time and energy making your vehicle present a smaller aero profile to reduce coefficient of drag, instead of INCREASING your CD, and attempting to convert some of that into usable power through use of a turbine.
Also maybe some kind of tail on the part that catches the wind so it could turn into the wind.
This is a really neat idea!!
Also if you didn't want to use a motor you might get better results using thread bobbins with copper wire around and counter sunk into the wood base and neodine recycled from old hard drives to generate the electricity.
So many ideas....soooooo cool
Thanks for sharing !
Since there seem to be quite a few of you, it would be good if somebody (your lecturer or tutor?) created a Group, you all joined the group and added your projects to it. You could all then all include a link to the group in your instructables, so that members could find them all together.
(Click here to create a group)
L
Once we made the full turbine to this design we then tweaked different aspects to try and maximise efficiency.
Efficiency can be calculated based on diameter of the blades and the voltage and power output.
L
Suggestion: I know resistivity increases with temperature. Depending on the temperature levels experienced by your motor at full wind load, it might make a difference to loose the insulator around your motor, and allow the wind to cool it.
Or at the power levels you are dealing with the resistance of the motor windings is insignificantly increased.
Hope you get an A.
This value is heavily dependant on the gearing ratio; therefore a larger gear on the fan would increase the generator axle rpm which in turn would increase the output power.
What if you add a long tail with a windscreen at the front, to avoid or deflect the negative action of the wind on the right side of the turbine? I think that that would improve it.
