UPDATE: VOTE FOR MY INSTRUCTABLE PLEASE, MANY THANKS IN ADVANCE
YOU MAY ALSO LIKE TO VOTE FOR MY BEST FRIEND'S CONTEST ENTRIES AT
www.instructables.com/id/Zero-Cost-Laptop-Cooler-Stand-No-Glue-No-Drill/ AND
www.instructables.com/id/Zero-Cost-Aluminum-Furnace-No-Propane-No-Glue-/
NOTE: THIS SPOT WELDER CAN BE USED TO BUILD SHEET METAL GIFTS FOR ANY HOLIDAY!
This instructable is a how-to guide on transforming a spoilt microwave, a plank of wood, some 3-pin plugs, T-brackets and wiring into a Very Low Cost Sheet Metal Spot Welder that is also Portable & Convenient
Please note that as the label of the transformer in my picture states "DANGER, HIGH VOLTAGE", kindly take the necessary precautions and not electrocute yourself in due course of this instructable
Remove these ads by
Signing UpStep 1Materials
1. Very old or spoilt microwave X1
(junkyards are overflowing with these)
2. Plank of scrap wood X min 2m long
(bed frames are nice usable sources of wood)
3. T-brackets X 1pair
(L-brackets are fine too, but i just had T-brackets handy)
4. Screws X A LOT
(you'll never know when you need these little fellas)
5. 1cm diameter cable X min 1m long
(preferably solid core, however if it is multi-stranded, ensure each strand is min 1mm diameter)
6. Misc wood working tools and electrical connectors
7. 3-pin plugs X2 (optional)
8. PC PSU power connector X1 (optional)
9. Length of metal chain or the like X min 15cm (optional)
10. Terminal strip (1cm inner diameter) X 2pieces
you have room on the transformer board.
you should consider using a breaker, sized to whatever rating your transformer is designed for. Welding is dangerous enough(thought very very fun), no need to make it MORE so.
By placing your breaker on-board, you're no longer relying on the buildings breaker to do the work of protecting. you can set it to trip at 30 amp, instead of, well, one of my breakers in the house is a 500 amp(for the electric kiln)!
Plus, if you trip it, it's a lot easier to reach up, and throw the toggle, instead of having to go to the electric service panel to find the tripped breaker.
But come to think of it those breakers don't come cheap, as it stands i have only invested only 2 bucks into the above working model (most of the materials were salvaged), excluding the electricity consumed while in operation, but if you're willing to spend some money, a breaker is definitely a worthwhile investment.
In keeping with your "2 dollar spot welder" idea,
Unless the Fuse blew ini the microwave, leadinig to it's discard, it should still be good. You could salvage it, and slap it in-line wih one of the AC poles. Not as nice as a breaker, but the first time it blows(though it may never) you'll appreciate it.
But, i know those 3-pin plugs i salvaged the ground pins from for my electrodes, each have an in-built fuse rated for 5A, so if i'm looking for a 30A rating, i'll just rig 6 of these in parallel, solution found, cost nothing, what do you think ?
Can you weld galvanized sheet (iron sheet, coated with zinc ) with this spot welder?
If yes, what thickness max?
Make sure you have plenty of ventilation, and you are up wind of what you are welding.
Anyway, when I weld galvanized sheet I will consider your suggestion
Personally i haven't tried any stock material over 1mm thick, but from my experience this spot welder should be able to handle stock material up to 2mm, you may want to push it to about 3mm, but i am certain i won't do more than that.
Welding galvanized requires higher amperage than welding carbon steel. The main variables in spot welding are weld current, weld time, tip diameter, and tip pressure. The weld current doesn't appear to be adjustable. The weld time and tip pressure are dependent on how hard and how long you hold the tips down. The tip diameter is adjustable only by modifying the tips.
If you are getting cold welds, you could try using a smaller tip. This will concentrate the current through a smaller area and produce more heat.
I would also recommend some sort of handle on this to multiply your torque to provide more pressure at the tips.
Based on the size of the transformer, I would suspect that 1mm would be the limit for this machine. Do you know how many watts or amps it is rated for?
1 mm is enough for me! I want make an dehydrator for fruits, vegetables and foods in general.
As for the mixture of zinc and steel, I meant something like
BTW vote for me thanks
I speak Spanish, and use on line translators. Sometimes I forget to review the outcome...
i used a angle grinder and accidentially cut one wire on the primary and messed it up, long story short there ant no fixen it, i wound up finding out a good sharp chisel will cut through it like a hot knife through butter. I used a bunch of small wire and made my own primary. It has bout 140 to 160 windings on it. I used 4 gauge for the secondary and got bout 4 turns on it. I like your design. Its all neat and organized. Im 15 and built one, no problem.
Some time ago I was excited with the possibility of constructing a spot welder, but here in my city there is no way to get an used microwave transformer: nobody throws away something as that.
Then I tried with my 220-volt electric welder, but I could hardly weak solder some iron wires of 2 mm, even though I was a good time trying.
Today I decided to uncover my welding machine, and found that in the secondary winding there is no place to put even a loop of thin wire. But in the primary, yes!
I think I can easily add several turns of thick wire, by way of a "bis" secondary winding. Now come the doubts, and related questions: whether the primary winding has 248 turns (more or less, it is what I could count), and get 220 volts, it is assumed that each round of "my" coil will produce 220 / 248 = 0,887 volts. What for me? Put only one or two turns, or try to reach five or six? A more laps, more volts but less amps. I suppose that losses play an important role in the case of small voltages, and who knows what is best.
Maybe you has an answer and save me the work of trial and error, which can become very tedious. Thanks in advance!
This is really good welding machine.
Can it weld two 5 mm mild steel rods together?
I need a small welding machine to weld only 5 mm or less then 5 mm MS wires.
I could not find a small spot welder in my town.
Please Help.
But come to think of it, what benefit does a dual tipped soldering iron provide?
Either way, thanks for your comment and kindly reply.
However, if somehow you're able to make them more cost-effective and usable, i wouldn't mind building one and giving it a go, in summary give your idea a go!
Either way i know its kinda late, but good job photozz (the author of the linked instructable), and stephenniall if you could build it better or build upon to improve it, go ahead cos tools are a staple for any DIY-er and the soldering iron could be the most important yet.
Cold heat soldering irons, like spot welders make use of the inherent resistance in materials (in this case the graphite tips), coupled with extremely high currents to generate lots of heat, the trade of being a very low voltage
In short, a stun gun has the total opposite operating characteristic to cold heat soldering iron or a spot weld, thus will never switch jobs
