Introduction: Weld Tester
A jig designed to test welds by bending them.
Step 1: Cut Out All Pieces
Cut out
1 4x6x3/8 square
2 4x6x3/8 square with 2 1" inch holes spaced 2-2/4" apart center to center
2 1" diameter circles of 3/8" sheet metal
3 4" pieces of 1" succor rod
1 3" piece of 1" succor rod
1 3" piece of 3" tubing
1 3" diameter circle of 3/8" sheet metal
Step 2: Create Plunger
Weld the 3" circle plate to the bottom of the 3" tubing. Then weld a 4" piece of succor rod to to the bottom of the plate. Finally, weld 3" piece of succor rod perpendicular to the 4" rod.
Step 3: Create Base
Weld the 2 4"x6" plates ON TOP of the other plain 4"x6" plate.
Step 4: Create Rollers
Weld 1" circles to a side of 2 4" pieces of succor rod as handles.
Step 5: Use
Put the rollers through the holes in the base. Set the metal that is being bent on top of the rollers. Put plunger onto a hydrolic press and press the metal between the rollers.
