3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wind Turbine
Wind Turbine
I'm very interested in freedom,  and anything you do not have to pay for.
The wind is free ,  but turbines cost a lot ,  so here is how to build a ten foot diameter wind turbine on the cheap.
Step 1Your tower needs an anchor
Do not under any circumstances dig a hole more than 3 feet deep unless you have been trained to do so.  Small hole collapses kill more people every year and if you do not know what to look for you could be taking a chance with your life.  Respect the threat and if you are unsure find some one that understands the risks and can help.
You don't want your tower to fall over,  so you will need an anchor.  I used over a thousand pounds of concrete that I set five feet deep in the ground.
I started by digging a five foot deep hole.
54 comments
1-40 of 54next »
Mar 28, 2012. 5:42 AMrowdy-outfitters says:
Was looking up bicycle motors. Came across one that I would like ideas about. Do you think it would work?
36 Volt 600 Watt Planetary Gear Motor With Cooling Fan
36VDC 600W 21.3 AMP motor with built-in planetary gear reduction transmission and cooling fan. Gear ratio: 60:9 (6.67). Output shaft speed: 550 RPM. Shaft diameter where sprocket seats into is 8mm x 13mm with a dual-d bore. Includes 10 tooth sprocket for #40 or #420 chain. Powerful four brush permanent magnet electric motor design with 100% ball bearing construction. 12 gauge power leads. Shaft rotation reversible by reversing power leads. Mounting bracket measures 5-1/2" x 4-1/2" with 4 mounting holes. Mounting holes are spaced 4" center to center across by 2-1/2" center to center across. Weight 17 lbs.
Thanks.
Dec 2, 2010. 9:43 AMcarpe_noctem says:
I haven't waded through the comments, so excuse me if this has been said before, but in step 3 you mention using a bike's "down tube". I'm 99% sure this should be head tube.
Nov 16, 2010. 5:25 AMRandomj59 says:
Great instructable,
If you live in a turblulent wind area have you considered making a verticle helix wind turbine, it catches wind from all directions and shouldn't be too challenging to make?
Nov 7, 2010. 7:20 PMnowuknowjack says:
Good observation on the number of blades. In industry they use as little material as possible to keep costs down, especially if mass producing hundreds/thousands of turbines. Example of this is the Altamont Pass East of San Francisco. Hundreds of turbines most of them use three blades. Of course they also use a lot of high tech stuff to trim the blades etc. Best of luck getting a job. I was on unemployment for 1 1/2 years. Got a job a year ago. I feel for you.
Oct 14, 2010. 8:25 PMkarossii says:
In step 4 you mention, "I've read in a few places that this is a really great motor to use and I found it on my first try digging at the dump : )" - but you don't mention anything about the motor, what it comes from, or its specs... Could you elaborate on that just a bit?
Otherwise, this is a great 'ible! I've gone through a few dozen on various turbines and windmills, and intend to make my own some day; when I have the free time. Yours is definitely a good one!
Nov 7, 2010. 9:29 AMnowuknowjack says:
Concerning the blades, have you thought about the number of blades. After doing some research on wind turbines and watching students at my son's school perform in a Science Olympiad it seems that ONE blade with a counterweight is the most efficient configuration for small generators. Try googling pico turbine and efficient wind turbine blades.
Oct 30, 2010. 7:49 PMreddnekk says:
Could not see how you drove the generator/alternator. Belt drive? Chain drive? Surely you did not mount the propellor directly on the generator shaft, so that its bearings would take the full load. Please tell us.
Oct 19, 2010. 7:54 AMdimtick says:
Looking at the photo's it appears that your turbine has a lot of neighboring trees. Trees create a lot of turbulance with ground wind. if at all possible you should raise your turbine so that it's above the trees and can get clean air.
Oct 25, 2010. 7:24 AMdimtick says:
I think if you go taller, you may be easier to use a round steel pipe with diagonaly cable braces. you can get the height you needing a new heavy timber. just bolt the extention pipe to the timber frame that you've already built.
keep us posted on your progress!
Oct 20, 2010. 3:21 PMmagickaldan says:
Your tail doesn't look like it has enough surface area. Which would cause the wobble you mentioned.
Apr 26, 2011. 10:07 AMscampbell2 says:
you cant believe you dont have a job!!!! maybe you ought to change your attitude, thinking you know evrything and walking off the jobsite and maybe youd still be getting a paychevk for doing nuthing
Oct 23, 2010. 7:34 AMbeehard44 says:
when i heard 5 foot deep hole i first thought about Holes by louis sachar
Oct 18, 2010. 8:42 PMNachoMahma says:
.  That half second or so closeup in the video of how power is transferred from the turbine to the generator didn't provide many details. :)   How about a few close up pics? TIA.
Oct 18, 2010. 6:17 AMmasoon says:
what kind/ size / make is the generator. I rent an industrial building downtown and have been thinking about setting a turbine up on the roof. I've seen an electric connection that allowed rotation without cords winding up, two rings one with two contact rings and the other with two sprung "brushes" if you will. Maybe that connection can't conduct the amount of current needed?
Oct 19, 2010. 7:24 AMFirestorm_101 says:
A thought occurs to me! Say one owned a large warehouse. The roof of such is a lot of surface area.... TO CATCH RAIN! It hits the roof, it runs to the large industrially piped gutters, you funnel all gutters into one, and down. Most warehouse roofs are what? 6 stories high? Several flows diverging into one from 6 stories high, a lot of pressure, mini rotational water wheel turning a turbine!!!! BAM! BLOWN YOUR MIND! Yea, its cool. I know I'm pretty epic xD. Tell me what you think.
Oct 19, 2010. 7:29 AMFirestorm_101 says:
NEVER MIND! Apparently its already been brought up before. :( I thought it was original too!
Oct 18, 2010. 6:40 AMNachoMahma says:
.  Fantastic!
.  I would like to know what your costs were. How much for lumber, concrete, pipe for blades, &c.
.  Please keep us up-to-date on your findings about how much power the rig puts out.
Oct 15, 2010. 1:28 PMdombeef says:
What do you power with this?
Oct 17, 2010. 9:25 PMdrbill says:
A one direction electron thingie is a good idea. Rectifier.
Ya might try 2 to 4 batteries with an inverter. 30's kinda over kill.
A charge controller would be goo thing too.
Outside of that ..........
Very good i'ble.
I always like to see how people do their turbine blades.
Oct 17, 2010. 5:10 PMjj.inc says:
where do you get 30 car batteries, thats like 3000 dollars average and at least 2000, do you just have money to blow or special connections.
Oct 15, 2010. 6:08 PMdombeef says:
Cool! if you are in the usa radioshack should have what your looking for, good luck!
Oct 17, 2010. 9:27 PMdrbill says:
Only question I have is how do you attach the blades to the hub ?
Oct 17, 2010. 9:28 PMdrbill says:
I like the tilt tower too.
Oct 17, 2010. 3:54 PMjj.inc says:
Does your cord ever get twisted up
Oct 17, 2010. 10:09 AMScottWeeks says:
Nice man! that wind turbine is looking sweet! so what kind of current ans sutch are you getting from it?
Oct 15, 2010. 7:59 AMcpotoso says:
And, btw, how did you do your electrical connection so that the cable does not twist over and end-up breaking as the windmill turns around?
Oct 16, 2010. 3:05 PM3DMHuff says:
You talked about using bicycles, why don't you use a gyro that comes off the "trick" bikes? You could just reverse engineer one and bulk it up a little. With that it will turn forever and no need to unplug.
1-40 of 54next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:00MrNotWrong00
