Wine Barrel Wardrobe
1,261
27
5
Published
Introduction: Wine Barrel Wardrobe
This is a wine barrel I turned into a wardrobe, but when making this you can use and turn the inside into whatever you want. Have fun with your creativity. I had a good time making this. I think it turned out really great.
Tools
Water Hose
Tape measure
Drill
1/4 in Metal drilling bit
Skill-saw
Hand-saw
Hack-saw
Grinder with
Pliers
1/4 Socket wrench
Safety goggles
Chalkline
Sander
60 grit sandpaper
small rags
Philips screwing bit
Pencil
Materials
1 barrel
1 1/2 cup of Clorox Bleach
24 1/4 in straight bolts w/ 24 nuts
2 Simpson metal straps
24 3/4 inch screws
1 small can of chosen wood stain and sealer
4 hinges
2 handles
1 lock
Step 1: Preperation
First, you’re going to want to start with obtaining a wine barrel. I poured 1 ½ cups of Clorox Bleach. I grabbed my hose and ran the water for about 30 seconds inside the barrel, and placed a plug back in the hole ( you can use anything that will cover all of the holes). After that, I started pushing/rolling the barrel back and forth.
Step 2: Outline #1
To begin making the outline for my first cuts, I used the stave joints as a guide for my cuts. I made a mark with my pencil (about 3 ½ inches from the hole) and threw a chalk line 1 in from the edge of the quarter hoop on each end of the barrel.
Note: Don’t forget to throw a line on the back side of the barrel too. I counted 9 staves from where I did my first chalk line.
Step 3: Securing the Braces
I made 2 mark on each side of the chalk line on the bilge hoop about 1 inch away from the line and evenly spaced out ( I later realized that making a template for the bolts was easier than measuring each one by one). Then I used a 1/4 inch metal drill bit to pre-drill hole, and put the bolts in on
Step 4: First Cut
When making the first cut, being very careful, i used the quarter hoop as a guide for cutting an even line. I placed the left part of the skill-saw against the quarter hoop. this allowed me to get a clean even cut on both end of the barrel *Try not to get to close the the chalk line mark to assure u don’t cut more than u should*. After making my first two cuts, use i used my hand saw to cut all the way through to the line on all sides.
Step 5: Cutting the Braces
I took my grinder and cut along all of the four of the lines on the bilge hoops. * Pretty simple step, but very dangerous, wear protection; sparks will fly, trust me*.
Step 6: Fastening Part 1
After making those cuts with my grinder, the top came out very easily. So I just screwed on the nuts and tightened them fairly tight. I grabbed my grinder once again and cut off the remaining length go the bolt.
Step 7: Outline # 2
Now in order to keep the top lid from swinging down into the barrel, I measured 1/2 more than the sidecut for the top lid * In most cases 1 inch ( side cut) so 1 1/2 inch (new cut) *, counted down 4 staves and threw a chalk line. This created a little notch that will act as a stop/rest for the lid. I did this on both sides. Then I just found the middle of the barrel and threw a chalk line down the middle.
Step 8: Bolt Templet
This was when I realized a tempted would help keep my bolts evenly spaced out better. Having the templet made making the mark, drilling the holes, and putting the bolts in much easier.
Step 9: Fastening Part 2
Once again I fastened the nuts on the bolts and cut off the extra. * See I told u… sparks! They hurt, trust me. * Use protection.
Step 10: Cutting Notch
Using my hack-saw this time, I cut down the side notch lines almost all the way down. Then I used my hand saw to cut down the last of the 4 staves.
Step 11: Fastening the Pieces
I grabbed all the pieces/parts to the barrel and put the nuts on the bolts. I tightened them and cut all the bolts.
Step 12: Straps
Using the 2 Simpson metal straps I bought, I bent them so the curvature would match the inside of the barrel part. Then I drew a line down the middle. Once I placed then about 1 inch from the line I screwed them on with 3/4 inch wood screws.
Step 13: Skill-Saw
When I finished screwing all of my wood screws in, I used my skill-saw to cut down the middle.
Step 14: Sanding Down
I took my sander with a low 60 grit sandpaper and sanded all the cut edges down. I also sanded down all the residue left inside my barrel.
Step 15: Staining
With a small rag, I dip it in my stain and started staining everything. I use it thick because I like I nice dark color. I also put a stain on hoops too, just to give it a nice bordered look to the metal.
Step 16: Hardware
First, I put my barrel back together. then I predrilled all the holes with a 1/8 inch wood bit and made marks on my barrel to know where to put them. I centered one of the hinges on each of the two side doors. Then I did the top.
For the top, I found the center between the two-quarter hoops and made a mark. once I made the mark I measured 1 1/2 inches on each side of the line and made about a 4-inch line to guide my hinges. Then I just screwed them in
When putting on my handles I really just eyeballed it and screwed them in. Then I just put my lock on. Easy.
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    5 Comments
    Well done and what a great unique idea. I have made furniture out of wine barrels in the past so I know what a pain they are to keep stable. How have you supported the wine barrel underneath to stop it from rolling around.
    This is a really cute idea for people who just want a little bit of closet storage space! I would definitely be very shocked if I saw something like this amongst the items that my removals company handles when people are moving homes! It is most definitely very unique for sure!
    Excellent instructable and a great completed project. Looks great.
    Clever project, I really like the idea!
