I live in downstate Michigan and went to college in the UP met a whole crew of Finlanders and was introduced to the Sauna! and its pronounced SOuna not SAWNA but i still slip from time to time if you arnt a yooper it takes time.
I graduated and moved back downstate for work but my life was lacking because i no longer had access to the "poor mans medicine box" so naturally i want to fill that gap. Research began to see my options for having my own sauna. Student Loan debt is a mother sucker and takes up a large portion of my income so $$ was tight so building looked better than buying and of course is much more rewarding.
I searched the web and found a few things but nothing really helpful for building a finish style wood burning sauna. I am getting into woodworking its becoming my after work hobby and this was the largest project i have done and still have a few things ill get to at some point. So I winged it at times but at the end of the day the sucker works as intended.
Remove these ads by
Signing UpStep 1: The Stove
I wanted to keep the building small and fit 3-5 people so to save space I made the choice/mistake to have the tank sit upward. I went to the hardware store and purchased 8ft of 6" single wall stove pipe. Which i cut a hole smaller than the pipe in the tank using an angle grinder. Lots of sparks and loud but pretty fast work.
I made a door in the front and used steel banding and sheet metal screws to attach the strapping and door hinges. Because the tank was vertical not horizontal i had to create a baffle to keep the fire in the fire box and not in the stove pipe! So i used a piece of plate steel and some bolts so i could adjust the air gap to the optimize draw but still keep the fire in the box.
Note: in the picture u will see a piece of air duct on the tank this is galvanized and a big NO NO for a chimney end up with zinc poisoning but it is 6" and worked for a demo fit. I made a cage for the rocks using steel shelving.
I put on a section or 2 i believe of stove pipe and balanced it while i tested the baffle until i was happy. I was getting results i wanted and was ready to start building the frame for my sauna shed.
Visit Our Store »
Go Pro Today »
You might want to put some insulation in the walls and roof.
You might also want some draining for water on the floor.
Glass window is no problem in a sauna, it just has to be a double window.
Good you have plenty of snow there, nothing nicer than go rolling in the snow directly from sauna.
Look the "official Sauna-site": http://www.sauna.fi/in-english/the-finnish-sauna-society/welcome/
One thing I'd suppose you to do is to try warming up the sauna door(s) open. This way its not the actual sauna that is hot - its just the stove thats burning hot and it works much better in my opinion! It obviously takes more time to heat up, but as yours is one very tiny sauna I dont think that would be a problem for you.
Have a good time with your great looking sauna! Greetings from Finland.
I remember seeing people at my gym's sauna picking up the sauna stones and placing them on their body. I thought this was what people normally did, but when I tried picking up a stone to do it myself, it was the last time I ever touched one of those rocks again. Have you ever seen anyone do this?
Thanks for sharing!
GM
I have been thinking pretty much the same thing ! 8x4' floorplan.
I need the medicine and meditation. Well done mate - I'm inspired to make it a reality !
Thanks
Rich
U can see i didnt build a floor for it and it is sitting on patio pavers so what water does end up on the ground just makes its way out, but a drain would be nice then i could wash out the ash a little easier. The lack of floor deffiently takes some heat out of the building in the winter but an extra log 2 takes care of that
I have been playing around with saunas in more than few occasions, first wooden heater for a sauna I welded when I was around 16 years old( yes, I'm a Finn), so here's few thoughts on the heater:
Yes, the heat escapes from the smokestack, but you should not try to constrict it.
If you want to make the heater more efficient, you should figure out a way for the stones to cover the first portions of the smokestack, so the heat would transfer from the smokestack walls to the stones. Another trick would be to pull two extra pipes from the front to the bottom of the smokestack, so there would be more surface area for the heat to dissipate to the stones.
Also, by regulating the air intake for the stove you can adjust how hard the wood is burning. Easiest way is to cut a 4x10 inch slot to the bottom of the heater chamber, fabricate a heavy duty steel "grill" that sits on top of the hole and a "drawer" underneath it. pulling the drawer more open it will let more air in -> air circulation gets better and wood burns hotter. Close it and it works the opposite. Also, drawer works as a catcher for the ash: pull it out and just throw the ash out and put the drawer back, instead of shoveling the ash out.
And its pronounced SAUNA ;)
All this said, your sauna reminds me a bit of the sauna my father built out at the hunt camp - rustic and low budget, but functional. Thank you for a nice instructable.
From an old Finlander, now in Texas. PS: Down here in the summertime, you don't have to worry about a heater for your sauna - just build a corrugated galvanized shed and leave it in the sun!
70 saunas! I would take that job in a heart beat! Eventually i plan to build a Cord Wood Sauna any one ever done that??
Yes the window is just for a little light and doesn’t need to open. I have a battery powered LED light that i use at night. Toss a little peppermint or Eucalyptus on there mhmmm cleans you out and breathing deep.
Thanks!
I am half Finn (1/2 finished?) and was raised around authentic Finn saunas in Michigan. Grandfather's in Iron River, UP was log construction, custom welded stove with hot water via the stove - this was the primary way we took showers - sauna every night when visiting.
Also had a wood burner, stove-heated water at our cottage on Lake Orion, SE MI and later built one at my parent's home in Frankfort, MI on Lake Michigan. (Unfortunately the last one was electric, but with water on rocks due to zoning/permit issues. Did use rough cedar harvested from our property in a authentic attempt.)
I found 180 degrees was just right for a lots of water on the rocks, 20-30 minute sit on the top bench. Miss it very much and thanks to you, now dreaming of plans for a new sauna in the future. Thanks for showing yours!
Kooter
Happy Sauna,
Rocks are so important that some owners of self made saunas have their wood heaters outside the sauna itself where they heat rocks they bring into the room. Actually I never understood why as it must (to me) mean a loss of heat, but I saw it in different places !…
I've been playing around with the idea of building a rocket stove to heat the sauna, not sure if it will work for a sauna, but I'm going to try. (http://www.richsoil.com/rocket-stove-mass-heater.jsp)
Thumbs up ! I really like you sauna (albeit the mess on floor, but then … ).
Keep on sweating brother ! Sweat your blues away !!!…
Thank you for sharing !…
