iImage Information
This instructable will show you how to make a glowing "playing card" so you can look just like the Ragin' Cajun himself! This is the first in a series of projects I will (eventually) be uploading in my continuing efforts to at least look like a superhero.
Materials:
Card Stock
Pencil and Sketch Pens
Plexiglas
Red LED
3V Lithium Battery
100 ohm Resistor
A length of wire
A small momentary switch
Hot glue
Electrical Tape (optional)
Step 1Start Sketching
iImage Information
If you want, you can just cut up some old playing cards, but I like to customize things. Take your cardstock and sketch out your design. Feel free to use references (I did!), but try to put a little of yourself into it. You need two cards of equal size, one for the design of the spade (or whatever card/suit you choose), and one to be overlaid and cutout later. When you've finalized the design, go over it with your sketch pens and, if you want it to really have staying power, go over it with an acrylic fixative or spray finish.
My design on the back incorporates the X-Men logo and Xavier School's name and motto; it'll be visible later in this Instructable.
http://i.picasion.com/pic39/ca509478dfc5beb42c9b4a7d833dd30a.gif (I would embed, but I don't think I can upload GIFs)
I attached the wire from my battery pack to 2 brass rings that I made (hammered out some brass tubing and bent them), and then by touching those rings to the exposed wires of the LED, we have light!
EDIT: I should mention, that my card is about 1/8th inch thick. I unfortunately don't have a side profile shot of it
I just wanted to say thanks for your instructable. I was able to modify and create what I call version 2.0.
I took 2 white leds and connected them in a serial circuit. I did not use a resitor because I figured that the led was rated for 6 volts. I used 3 3v batteries to equal 9 volts. and created a plexiglass encasement like you did with yours. I have to say it came out pretty good. You can use a Dremel engraving tool like a carbide cutter to make all the necessary grooves. It took some time but it cut really nice if you have the patience.
After everything was said and done the card lights up like a charm. Used 2 large print playing cards and cut out the spade with an x-acto knife. Then used minimal hot glue to put the card together. Its even visible during the day. I did not think of making a how too but this may give others a good idea on how to accomplish the same results. Awesome idea. Going to be great or my Halloween Gambit Costume.
Thanks.
I have seen some switches with 4 prongs and 2...
I think the description of the resistor in Step 2 is a little confusing.
The order of the color bands on a resistor is important because it tells you what resistance (in ohms) it provides, and you do look at the gold band (the tolerance) last when you read the color bands from left to right.
But, a resistor does not have a positive or negative side. It can be installed in either direction.
