A Cajon is a south american drum made completely out of wood. It is played by slapping the front face with your hand and it's perfect for unplugged sessions because it could substitute a whole drumset.
This instructable shows you how to build a perfect Cajon for about 25.- Euros and only a few hours of work.
It is perfect for schools as the steps themself are short. They only take 30-60min. each but you have to wait each time for a day to let the glue dry.
And you don't need many tools, an electrical drill is essential, all other steps might also be done with manual tools (jigsaw, screwing...)
The result is an individual Cajon that meets even high standards. I chose the size so that it will also fit in any commercial bag, which you might want to buy.
Remove these ads by
Signing UpStep 1You need
Tools:
an electric drill with 2mm drill bit, can also use a cordless screwdriver for this job
a jigsaw (electric or manually operated)
a screwdriver (electric or manually operated)
some wood glue
a tape measure or ruler (30cm is enough)
4 clamps or something heavy like a set of filled water bottles
Materials:
You need six pieces of wood to built the box. The best and most common wood that you can take for this job is birch multiplex. Every hardware store should have this and they could also cut it for you to the right size.
For one Cajon we need:
2 pieces of 300 x 300 x 12 mm (bottom and top)
2 pieces of 300 x 476 x 12 mm (side parts)
2 pieces of 300 x 500 x 4 mm (front and back)
4 pieces of 290 x 12 x 12 (not multiplex, I used pine, because it is rather cheap, this can be made from a rectangular block of wood, doesn't have to be birch, also the size doesn't have to be exact 12, can also be 10 or 14)
some screws of 2.5 x 16mm and 2.5 x 20mm
some knobs for the foot.
and optionally: a set of snare wires, the longer the better, 35cm or 14" is ok.
Cost:
wood: < 20.- ( I got mine for 16.-)
snare wires: ~ 5.- (I paid 7.- (optionally)
screws and glue: 2.- (had it at home already)
knobs: 4pieces 1.- (also had it at home)
Total: 23.- to 30.- Euros
![WORLDS CHEAPEST VIRTUAL DRUM at $10 [ Rs.500] - using pc ( no drum module required )](http://img.instructables.com/files/deriv/FA7/71UR/GUI0ZWAC/FA771URGUI0ZWAC.SQUARE.jpg)
What gldx03 meant was the main frame of the box. I used 12mm wood and he suggested 8mm. Then you really need corned shafts! The front part could also be thinner like 3mm or so, but that is hard to find.
I have played a few Cajon drums, and I really liked how versatile they can be. The only thing that has kept me from buying one myself is that it seems to always bee overpriced. I guess also.... my lower back would start to ache if I played too long. It would be nice to be able to sit more upright when played.
Because of that it is much better to glue the parts first and then screw them together. It's the difference between enough and too much that is difficult for beginners, this is why I wrote these notes.
In an earlier version I had a short description, but that somehow got lost. Obviously...
Thanks to edbro, g2yeux and jacob13 to set this clear!
The similarity to a stool is not wrong. It is also a very comfortable seat during outdoor sessions...
