Introduction: Diy 5.8Ghz Fpv
this is an 5.8ghz wireless camera. it can go 2km far in the air
Step 1: What Do You Need?
the first step I did was looking for the datasheet of the 5.8ghz tx module
Step 2: Put Tin on Each Pin
Step 3: Soldering the Parts
first you put on the dipswitch you need to cut off one pin and the other 3 solder them on and as gnd u use the metal plate
Step 4:
now you put the other cables and the antenna on. i bought an normal 5.8ghz one and cut the end off striped it and you ready you can see on the chip were to solder evrything.
Step 5: Parts List
1. Boscam FPV 5.8G 200mW Wireless Audio Video Transmitter Module TX5823
http://www.banggood.com/FPV-5_8G-200mW-Wireless-Au...
2. 2 x JST Connector Plug With Connect Cable For RC BEC ESC Battery
http://www.banggood.com/Wholesale-2-Pairs-15cm-JST...
3. Boscam FPV 5.8G 8CH AV Wireless Receiver RC805
http://www.banggood.com/FPV-5_8G-8CH-200mW-AV-Wire...
4. 5.8G 4 Leaves Omnidirectional Gain Antenna For Receiver
http://www.banggood.com/5_8G-4-Leaves-Omnidirectio...
5. FPV 1/3 Inch HD Color CMOS 600TVL Mini Camera PA
http://www.banggood.com/FPV-1-or-3-inch-HD-Color-C...
6. WLtoys V959 V212 V222 RC Quadcopter Parts 3.7V 500mAh JST Battery
http://www.banggood.com/Wholesale-WLtoys-V959-V212...
7.3.7V 1S Lipo Battery USB charger JST plug 500ma output
http://www.banggood.com/3_7V-1S-Lipo-Battery-USB-charger-JST-plug-500ma-output-p-91269.html
Guerilla Design Contest
Small Spaces Contest
