3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
great looking, inexpensive computer desk
When looking for a computer desk for my home office, I couldn't find anything that was reasonably priced and met my needs. All of the nicer desks I was looking at were at least $1200 or more and weren't exactly what I was looking for. I also didn't see a lot of instructables for desks, so I decided to build one and set myself a budget of $300.
The desk consists of four pieces.
- table top
- 3 drawer cabinet (writing supplies, computer cables, etc)
- 2 drawer file cabinet (drawers are sized for hanging file folders)
- printer cabinet
I chose to build it this way because it is easy to transport, and it can easily be shifted around to a new room if I chose to move at a later time. I also chose a fairly simple construction, no crazy joinery, and tools that every basic wood shop would have.
Materials:
- 3 (4'x8') sheets of 5/8" mdf (I would have liked to use maple veneer plywood, but its about 3 times the price)
- 2 (4'x8') sheets of 1/8" mdf or hardboard
- 1" brad nails
- 5/8" brad nails
- wood glue
- wood filler (for nail holes)
- 5 pairs of roller tracks for the drawers
- 7 drawer handles
- 1 pair of cabinet door hinges
- 1 gallon of primer
- 1 gallon of paint
- brushes and rollers
Feel free to build as many or as few cabinets as you need to suit your application. And if you build one post some pictures!
Step 1Necessary Tools
Necessary Tools
  • last photo ←
I wanted to post this instructable using common tools. These tools are very common and for the most part inexpensive. Chances are if you don't have all of these tools, your neighbour will be able to help you out.
The tools I used were:
-drill
-table saw
-miter saw
-tape measure
-adjustable square
-paint brush and roller
-brad nailer
-cutting pliers
-drill bit and driver
-screwdrivers
-palm sander
39 comments
Feb 15, 2011. 1:42 PMphish814 says:
Using an old door would be convenient for a top. You could even use the old hole for the handle as a place to route the computer cables.
Nov 12, 2010. 7:16 AMDrojen says:
Thanks for the great plans! My wife and I built a variation of this desk this week and it turned out great with a few customizations.
We changed the dimensions a bit since we used 1/2" MDF instead of the 5/8". We also used a hollow core 24" x 80" interior door slab for the top and made two simple cabinets with hinged doors based on the printer cabinet plans you made. To those I drilled some holes on the inside for adjustable shelf brackets and cut some simple shelves for extra storage. I've attached some pics below.
Once again thanks!
Dec 10, 2010. 1:10 PMcharliejaime says:
Great variation. Since I've NEVER built anything before, I am going to try your version (since it doesnt have drawers, which I find intimidating). Could you tell me how you mounted the doors and shelves (hardware). Also, the doors, are they mounted directly on the frame of the cabinet? There seems to be another piece of wood in the picture that the hinges are bolted to... Finally, could you give provide the measurments of the cabinet...
Thanks for any answers/help you can provide a newbie.
CJ
Dec 18, 2010. 10:14 AMDrojen says:
Hey CJ. The doors are mounted with some of those European style hidden hinges 1/2" depth. They require a screw that is about an inch long to mount them to the cabinet box, so we had to install one more strip of 1/2" MDF which we cut to fit and glued to the sides. This allows the screw to go all the way in and anchor everything well.
On the door side, you have to use a forstner bit to drill out the hole to mount the hinge. The hinges come with handy little templates that make it easier. I got everything at Home Depot. They basically just sit inside the hole you just bored out and are anchored by a couple of screws. Just go slowly so you don't bore all the way through the door face.
For the shelves I just drilled some holes in a line and put in some of those little adjustable shelf brackets like you find in store bought bookshelves. They just pop in and out so we can adjust accordingly. Eyeball your drill bit and the side of the cabinet box and then put some tape around the bit to mark the depth so you know when to stop drilling so you don't pierce through. I put the holes about 1.5" apart. Just make sure the front ones are level with the back ones, mark everything out, and go to town.
The cabinets are 20" on the inside, 21" on the outside, and 22" where the trim pieces go on the top and bottom. They are 28" tall. The construction is the same as the printer cabinets in this instructable. Since I used 1/2" MDF, I used rounded off measurements to make it easier.
I hope this helps, good luck.
Jason
Dec 28, 2010. 9:26 AMcharliejaime says:
Jason,
Thanks for your detailed response, I greatly appreciate it. I will let you know how I make out.
Happy New Year!
CJ
Feb 18, 2010. 6:31 AMkyzla says:
do you think i can adjust the printer cabinet size?
my printer is very differently shaped :( but has a scanner and fax and printer all built in :)
i think i could, and then adjust the size in the plans and all, and adjust the top and such... i don't think it'd be too hard, do you?
also: GREAT job. i grew up watching my grandfather see a problem and fix it by building some custom piece of furniture. they were works of art, and easily replicable with plans and everything. yours is just wonderful. 5 stars!
Feb 6, 2010. 2:16 PMlooker1995 says:
I did roughly the same thing for my computer desk. However, for my top I chose a prefab Formica countertop from Home Depot. The 6 footers cost about $45-$60, but I got a chipped one for $30. I set things up so the chip is hidden behind some of my peripheral gear, so it's not a problem.
Jul 30, 2009. 9:37 PMclintiepoo says:
I'm thinking about doing this... my desk is really old and very modified and it would be nice to get a new, larger one. Could you post measurements of the overall dimensions of this desk? I know i could tweak it, but if I build it to print I need to know how big it will be.
Apr 29, 2009. 4:31 AMporcupinemamma says:
If I can't have a quick peek at Inst. before work, I am in withdrawal all day, so I clicked on and found your ible. Beautiful!!!! Just what I'm looking for. Tell me please, are those two filing cabinets side by side? I need four filing drawers desperately. Great looking desk!!! 5 stars :0)
Jan 10, 2009. 2:10 PMsilver912targa says:
This is the kind of cabinets I make all the time. After restoring about 6 houses, I'm happy to see that there are other people using the same techniques as I do. Also the kind of style you use is similar and primering with latex is o so easy, much better then these expensive primers. I got this cheap and easy technique from stage builders. Michel Portugal
Jan 8, 2009. 8:25 PMNymph says:
You've made a very professional looking desk. I think the handles give it a great look -well worth the money. Good job!
Dec 23, 2008. 7:13 PMjmthomas says:
I'm going to get my boyfriend to build me one.
Dec 19, 2008. 8:37 AMSpokehedz says:
You know, it might be cheaper to get pre-built cabinets from Home Depot or Lowes... Plus, save a lot of time and effort as well.
Dec 23, 2008. 5:37 PMSpokehedz says:
That is true, but that usually includes about 4" on the top and bottom that you could shave off. Also, the chair I have has a raise and lower adjustment level. 'bout time I used it for something.
Dec 18, 2008. 12:28 PMchoch says:
I did this years ago and it works great. I used bathroom cabinets, they already have a drawer and a door. Put one on each end, more if you have room. Put a standard laminate counter top on the cabinets and a brace on the wall at the back of the chair hole. Holes for electricity and cables as you like. The countertop is prefinished. I slid it in a window and dropped it into place for a wall to wall desk. Prefab is really cheap. Choch...
Dec 18, 2008. 2:29 PMblackturtle says:
Gorgeous! And it can be custom size to any space. Love it!
Dec 18, 2008. 3:40 PMjessandstavro says:
My computer desk is two two-drawer filing cabinets topped with a French door and a piece of glass on top. It looks almost identical to yours! Nicer and with more character than anything you'd find in a store. Great illustrations too. :)
Dec 18, 2008. 3:55 PMadamvan2000 says:
I've never built any of the projects on here, but this one, I will do. My wife's going to love her new sewing desk. :O) ~adamvan2000
Dec 20, 2008. 10:22 AMuncle frogy says:
very nice work would fit in to any house or apt. nice project. I have an unused bedroom that I converted to a lab workshop I added a second desk using 2 used two drawer Steelcase filling cabinets from a local office supply store and a piece of 3/4 plywood that I cut down to fit the space not very elegant but quick. I would have used a cheap hollow core slab door but did not have the length. still not very elegant.
Dec 14, 2008. 9:08 PMwest boyo says:
I like the plan, it looks very professional. one thing I don't know about though is the material. MDF is not the strongest choice. you can get maple veneer particle board for bearably cheap, and it is much stronger and infinitely more waterproof. it can also be stained, if you like the natural wood look. great plan, otherwise.
Dec 15, 2008. 9:17 AMaeray says:
And you'd have to edge-band it too.
Dec 13, 2008. 8:36 PMfacadeparade says:
It's gorgeous. A lot better than the ones I've seen in the store.
Dec 13, 2008. 8:43 PMdung0beetle says:
You make it look easy. Shame on you!
Dec 14, 2008. 11:57 AMfwjs28 says:
pretty cool....5*
Dec 14, 2008. 12:24 PMaeray says:
Excellent 'ible. Good instructions and illustrations, and good use of material. One tip-- If you drill two oversized holes in the drawer sub-front and then use two panhead screws with fender washers to attach the actual drawer front, the front can be easily adjusted for an even reveal once the assembly and installation is complete.
Dec 14, 2008. 1:21 PMjdege says:
I've never seen anyone nail and glue a drawer bottom on. They're usually set in a dado., and left free-floating. You're method has the advantage of simplicity. There are a number of ways of cutting dadoes, but all require tools and practice. The problem is that wood expands with changes in temperature and humidity, With a free-floating drawer bottom, that's not an issue. With the glued and nailed method you've used, your drawers will warp. It may be that with well-sealed MDF, you'll not see the problem. But if someone were to follow using these instructions using a different finish, or decided not to bother painting the drawer bottoms, they could have a problem.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:nickfarnell
