I used computer's fan to cool the wireless, attach the fan to the wireless and will use the same power source of the wireless (wireless NO fan ON, wireless OFF fan OFF)
Maybe you will ask me why should I cool my wireless network router?
The answer is: by cooling your router you are avoiding slowing down (especially while downloading big files) because if you are using the router too much (such as downloading big files. you can notice that by seeing the LED's in the router) it will get hot, and you know that Electronic devices will not be efficient if it's not working in the right temperature.
Also because I live in a hot country and I am noticing that the heat is affecting the wireless.
Remove these ads by
Signing UpStep 1Things you will need
1. Fan (I used Desktop PC's fan).
2. Male jack that is similar to your wireless jack(I found it in an old adapter).
3. Female jack that is similar to your wireless jack.
4. Some glue.
5. you will need to solder some wires.
But try to keep the fan as close as much to make it as efficient as much.
Please comment your impression after testing it for some time. Cheers
ive been using it for a week now and its been keeping quiet and cool.
Im planning on making a modular design to fit the modem/router's and the case fans that is easy to move around. Nothing a trip to the hardware store can't fix for a budget of 20$.
The answer is: the electronic components will not work properly in a high temperature.
This post should have a title that reflects the end result.
By preventing it from slowing down, you are not effectively speeding it up in comparison to default settings.
This is a useful Instructable but should have a title closer to "Prevent router lag due to overheating" or the likes.
Otherwise great Instructable :)
Way to think outside the router :)
I put it in a plastic bag and wrapped frozen peas around it whenever I needed to transfer large files.
Worked surprisingly well. Should have used it to defrost dinner more often.
