Introduction: How to Make a Power Rangers Like Gun Sword
today we are going to make a power ranger like gun sword except with some creative flexability
Step 1: Gather Up Your Stuff
you will need
panel board ("but thin plywood works too")
tools to cut out the wood
styro foam ("optional" you could just sculpt more wood if wanted")
hot glue gun
a few screws("differrent sizes")
a drill and or a dremel
Step 2: Starting to Build the Main Body
cut out 2 shapes just like the piucture below and glue on a piece of panel woodcut in a rectangle to the length of the body
Step 3: Building the Next Part
cut a groove to make the sliding top and add a holding rail that looks some thing like in the picturegroove
Step 4: Build the Slide Rod
just cut a square board down to roughly about 1 and1/2 x 1 and 1/2 but it doesnt have to be exact length wise 7 to 8 inches depending on how big you want it
Step 5: Making the Handle
cut a piece of wood similar to the picture this will be you handle
Step 6: Making the Blade
i cut out and layered some card board but you can use wood to make a simple rectangle blade
Step 7: Putting More of the Gun Together
cut a groove near the front on the side of the gun. screw in your handle and slide device like in the picture
Step 8: Finishing Up
Seal up the blaster like in the picture and put a screw in the blade so it can slide and your almost there, just make sure it works.
Step 9: Polish Up and Finish Up
add your decorative touches and you are done... have fun
Toy Challenge 2
