A few months ago a friend gave me an EL Wire dog leash but had pretty much striped it down to the bare EL Wire and battery box. So for months I was unable to think of any thing to use it with until I saw the EL Wire contest and finally figured out I could use it with my oxygen mask.
This instuctable should be easy enough for any one to do.
Also I would like to thank ever one who viewed and voted for my last submission for the usb contest
Remove these ads by
Signing UpStep 1: Lets get started, gather your supplys
You'll need some sort of oxygen mask with a tube, just mask sure there are enough air hole in the mask since you will be plugging up the tube.
One EL Wire dog leash, or you can purchase EL Wire from http://thatscoolwire.com/ along with a battery pack.
TOOLS
scissors
marker (if you want)
ruler or tape measure (if you want)
hot glue gun
also you will need some epoxy with / instead of the hot glue (edit)
Now if you couldn't find the dog leash el wire you will need to contruct your own el wire with battery pack set up, but you should be able to find the dog leach for under $20.
One important note make sure the el wire is as long or shorter than the tube because its alot easier to cut the tube.
Visit Our Store »
Go Pro Today »
Here is how:
1) Cut a piece of string about 3 inches longer then you need to run.
2) Tie one end to the wire you are running.
3) Place the end of the string in the tube
4) use compressed air to "blow" the string through the tube.
You may also get it to work with a vacuum on the opposing end!
