make a manual vacuum pump for under $20 by converting a bicycle pump by drcrash
Featured
A vacuum pump is just an air pump that you use for sucking rather than blowing. You can convert an old-fashioned "floor pump" ("bike pump") into a vacuum pump that can take over 75 percent of the air out of something. That's several times as strong as a vacuum cleaner's pull, and three quarters as strong as the best possible vacuum pump.
The net atmospheric force on whatever you evacuate will be over 11 pounds per square inch (or over 1500 pounds per square foot), which is enough for many tasks requiring vacuum.
(For those of you who are not metrically impaired like most of us in the U.S., that's over 7700 kilograms per square meter.)
Some examples:
(1) Vacuum pumps made this way are in use around the world, in non-industrialized areas, for vacuum packing food. (Especially to save seeds for the next year's planting, by killing bugs and preventing germination. See http://www.plenty.org/soy/vacuumpump.html )
(2) A manual vacuum pump can used to make a "vacuum press" to clamp laminates together with a ton or more of force while the glue sets. (A smaller manual pump, designed for evacuating wine bottles, is often used for laminating skateboard decks, using a commercial vacuum bagging kit from Roarockit called the "Thin Air Press". Our bigger pump pulls about as hard, but requires considerably less pumping.) It can also be used for vacuum bagging composites like fiberglass, to squeeze out excess resin and make stronger, lighter parts.
(3) You can use it with a vacuum former, to form thicker plastic sheets than you could with just a vacuum cleaner. (Doug Walsh shows how to apply this to vacuum forming in his book "Do It Yourself Vacuum Forming for the Hobbyist," available from http://www.build-stuff.com )
(4) You can implode various things with it, or attach it to a vacuum chamber and expand or explode things in the chamber; that's often fun and/or instructive. (Try Peeps.)
The vacuum generated is not strong enough for some tasks, like evacuating refrigerant systems or degassing difficult-to-degas liquids. For those tasks you need a pump with more leverage, that takes almost all of the air out.
A plain bike pump is just a piston pump rather like a syringe, with a rubbery disk sliding in a cylinder. Drawing back the disk sucks air into the cylinder, and pushing it in pushes air out.
To make this syringe-like thing work as a pump, sucking from one place and blowing to another, two "check valves" (one-way valves) are used. One lets it suck in from an air intake, but not blow out the intake. The other lets it blow out the exhaust, but not suck in from the exhaust.
Unlike most piston pumps, a bike pump uses the rubbery disk both as a piston and as one of the check valves. When you pull back on the pump, the disk flexes inward and allows air around it, into the cylinder ahead of the piston. When you push inward, the disk is stopped from flexing the other way by a metal disk (like a big washer); its edge seals against the inside of the cylinder, so that when you push it down, it compresses the air in the cylinder and forces it out the exhaust.
(There's a normal check valve at the exhaust, to keep it from sucking the air right back in on the upstroke, and more air flows in behind the piston through a hole in the cylinder top.)
To convert the pump, we'll need to do two things:
(1) Reverse the piston disk and the metal disk that backs it up, so that it seals on the upstroke (to create vacuum) and flexes on the downstroke (to let air around it and out of the cylinder).
(2) "Reverse" the exhaust check valve, so that it lets air in but not back out, and we can use the old exhaust connection as the new air intake. Actually, it's usually easier just to remove the check valve, and replace it with one that does the right thing, so that's what we'll do.
To make it easy to do both of these things, we'll want a simple, cheap, old-fashioned bike pump with no frills (like a pressure gauge) to complicate things.
(If you want a small electric vacuum pump, have a look at my other instructable on converting a 12V "tire inflator" air compressor: http://www.instructables.com/id/E791HNXF23Z39P6/ )
Step 1: Get the right pump, and a few other cheap things
The crucial first step is to get the right pump---a simple old-fashioned one of what used to be the standard design. I got a Slime brand 2060-A at Auto Zone (an auto parts chain store) for $10, and it's perfect.
You want a simple cheap pump with:
(1) a shaft that's a metal rod about a 1/4" or so in diameter, not a 1/2" plastic tube
(2) a cylinder top that unscrews, or can be released by unscrewing a few small screws
(3) a rubber disk and metal plate that are held onto to the end of the rod (opposite the handle) with a nut, so that you can just take them off and reverse them
(4) a metal fitting where the hose attaches, with a six-sided base, which unscrews like a nut. This is both a hose barb for attaching the hose, and a check valve we'll need to gut
(5) reasonably long throw and reasonably large diameter (for a bike pump); a skinny pump will be slower, and
(6) no pressure gauge. Pumps with pressure gauges often use a different kind of check valve, and have air space around where the gauge attaches that may affect how much vacuum you can pull once the conversion is done. (You can fix those things, and I have, but it's easier just to get a no-frills pump.)
If you have an Auto Zone nearby, go look for a Slime 2060-A "Floor Pump"; it's cheap and you'll be all set. Otherwise, look at the pictures in this instructable, and try to find a very similar pump.
(I have no connection to Auto Zone or Slime, and no reason to think that other brands aren't just as good, but if you use exactly the same pump, you should have zero difficulty following the directions.)
Looking for a "floor pump" at an auto parts store is a better bet than looking for a "bike pump" at a bike shop.
You'll also need:
(1) Three or four feet of 1/4" I.D. braided PVC hose. (Lowe's sells it by the foot in the plumbing department, for about 30 cents a foot, so you'll want a dollar or so's worth.) That's a kind clear flexible tubing with braided reinforcement; small diameters stand up very well to vacuum, unlike some other small hoses.
(2) A check valve with hose barb ends to fit 1/4" I.D. tubing. McMaster-Carr sells these online. Mine cost about $4.00. (Part number 6079T53 from http://www.mcmaster.com )
(Some people use an aquarium check valve, which costs about $2 at a pet shop. I tried that and mine leaked, as well as restricting flow a little more than I like, but some people are happy with them. If you go that route, you'll need to use smaller-diameter hose to connect it; let me know how it works out for you.)
(3) A small hose clamp. I got mine for 25 cents at a local tool place, but you'll likely have to buy a 2- or 4-pack at most hardware or auto parts stores, and pay a dollar or two.
You'll also need few tools:
(1) An adjustable wrench, or a non-adjustable one that fits the hose fitting on your pump.
(2) Something that can cut thin metal, such as tin snips, a nipper, a hacksaw, or a rotary tool. (You might be able to get by with a file and a pair of pliers, or even just some needle-nosed pliers.)
(3) (maybe) a power drill with a 1/8" drill bit suited for drilling a little bit of metal, or for the 2060-A, a screw and a screwdriver.
Rags or paper towels are good, because you'll be dealing with greasy things.
1-40 of 65Next »
suresh060979 says: Feb 24, 2013. 10:25 AM
can anyone help me build a vacuum pump using a foot air pump with pressure gauge?
WazIt says: Feb 11, 2013. 6:14 PM
Thanks, I'm going to try it, but I'm going to use a tire valve stem with my vacuum chamber so I can use the hose that comes with the pump
wily70 says: Dec 18, 2012. 2:59 PM
Hello, how much Hg or bar can I expect from such a vacuum pump?
thanks
xfrench says: Oct 21, 2012. 10:14 PM
Hi. Thanks for the inspiration. Any advice for how to use a found pump that does have a gauge? It's the first one I've found thrifting, and would be nice to put to use...
Geoluhread says: Feb 18, 2012. 3:44 AM
Will this effective for a physics experiment? I would want to use this for a Bell in a Jar experiment for our project. I've tried this already I don't know if there is something wrong but the air sucked is very little. I used an aquarium check valve because its hard to find a check valve like yours in our place. I've searched for every autosupply and hardware store and they don't have it.
gatan says: Aug 19, 2008. 2:35 AM
hellooo all
question -0,6bar=....."mercury
help me, how to convert :) thank..
Esmagamus says: May 7, 2011. 10:57 AM
onlineconversion.com does all you need.
Derin says: Apr 26, 2010. 9:25 AM
-17 in Hg
arisecute says: Nov 24, 2009. 7:22 AM
Please go to - http://joshmadison.com/software/convert-for-windows/ - you would get a free conversion software for download. Madison is a great man doing a great job.
romedeiros1970 says: Jan 6, 2009. 1:14 PM
Use Google. Type: "-0.6 bar in mercury" and press "enter". That works for most conversions, such as "3 feet in meters", "5 pounds in kilos", etc.
oli-explosion says: Nov 5, 2010. 4:41 PM
Hi, i recently discovered a how-to on building a kitesurf board. It requires vacuming to (i guess) squash the fibreglass cloth onto the core, ans seal it all nicely. I was a little put off by this as i have no means to do it, (conventional vacuums are too expensive to buy just to make a board) but now im wondering if it is possible. Would the vacuming capabilities of this pump do the job and pull all the layers in enough to hold it together strongly?? any help on this would be awesome and much appreciated
Esmagamus says: May 7, 2011. 10:56 AM
Find an old refrigerator thrown in the trash.
Take the compressor with control box out by cutting all the tubing. Fit a power cord on it and you'll have one side sucking air, other blowing. There's your vacuum pump.
Eddie_T says: Feb 16, 2011. 9:24 PM
I confess I am somewhat of a nut, my wife has been hospitalized on occasion and I collect the oxygen and IV tubing when it is changed. Just for kicks I made a small vacuum pump using the tubing, two of the locks that permit injections into the IV line and a syringe. It might be used to take the air out of a wine bottle or one of those 2.5 inch cylinder thingies.
CHRISPB says: Jan 26, 2009. 10:04 AM
Does anyone have a suggestion on makeing a manual pump that could, after several priming pumps, begin to generate a constant airflow of say 10-15 L/minute? Would you use a flywheel or double valves?
Goedjn says: Nov 9, 2010. 1:28 PM
Build a double-action bellows, or two sets of foot-bellows, feed the output into a big sack, and put an appropriately sized rock on the sack. This is essentially how a pump organ works.
The SYNer says: Oct 6, 2009. 5:58 PM
would this pump work for a particle accelerator
spaceman12 says: Sep 3, 2010. 12:52 PM
no a particle accelerator needs a near perfect vacuum something no simple hand pump can get near. to make a a vacuum for a particle accelerator you need a cooling system near absolute zero to literally freeze the air solid on the cooling pipe making it a better vacuum than space.
Wafflicious says: Jan 4, 2009. 7:50 AM
My cup imploded(I think that's a word..)
valleycrosser says: Aug 23, 2010. 9:14 AM
Yes, it is a word and means according to the built in dictionary on my Mac, "verb, to collapse or cause to collapse violently inward"
MadMonso says: Aug 23, 2010. 4:26 AM
Hey, although McMaster doesn't seem like you can do direct links you can, just do "#"{PartNumer} no "" or {} so Check valve: http://www.mcmaster.com/#6079t53 That one specifically just does a highlight on a page so I'd still include the part number in your description. Nice job.
wenui says: Apr 21, 2010. 4:59 PM
Hi,
How do you use like valve?
Thanks
vernonen says: Feb 9, 2010. 12:44 AM
G'day all,
I am about to build a vcuum bubble to use as a VTOL transport  and OH hoist. I needed an economical vavuum pump which would pull out 80% of the air. Has anyone tried this? I will keep posted.
ElectricUmbrella says: Apr 17, 2009. 5:17 PM
Will this work well for making neon lamps and other such devices?
Derin says: Jul 22, 2008. 8:09 AM
lol,"if the pvc hose gets off you are hosed",oh the irony
tradergordo says: Jun 10, 2008. 5:38 AM
I was about to build one of these, thanks for the instructible, but I just discovered that Harbor Freight now sells a vacuum pump for just $10.99 that pulls 28.3" mercury! I can't build one for that cheap, and it creates a very strong vacuum all with standard fittings so you can easily attach whatever you want to it. Can also be used to service any time of air conditioner. Anyway, just thought others reading this thread might be interested. It does require an air compressor so its only for people who already have an air compressor.
HF vacuum pump
They have two other models which are very similar but have different fittings.
tradergordo says: Jun 10, 2008. 5:42 AM
Come to think of it - I wonder if someone without an air compressor could just hook a normal (NOT reverse flow) bicycle pump to the air inlet of this HF vac pump and create the vacuum manually, this should be a very easy mod. But I guess it would basically just be the equivalent of using the thing as a giant check valve :) I guess if you live close to a harbor freight store it might be worth trying.
gaiatechnician says: Feb 2, 2008. 11:17 PM
I did the same thing several times many years ago. I cannot remember where the check valve was. Anyway, I removed it and either reversed it or I put in an ordinary bicycle valve in the line. There was a type at the time with a tiny rubber piston in it and it was awesome for the task. Perhaps it is still around in bike shops. You will find that it takes quite a lot of effort to make vacuum. Warning! An implosion is also dangerous. Stuff can hit you from the far side of an implosion. Anyway, if you are lucky enough to have water falling 10 or 15 ft or more (absolutely no point in going more than 35 ft) on your land, you can make a setup with water flowing into a vertical pipe. Lets say 3/4 inch pipe. Lets say 15 liters per minute flowing into a cistern at the top (You have a cistern like in a toilet system) except that the valve is upside down and lets water OUT instead of into the cistern. Right after the valve is a Y-joint to let air in from wherever you want suction. The max amount of suction depends on the length of your vertical pipe. The great thing about this is it provides variable suction! Say you are sucking all the air out of a 5 gallon plastic can. Well, this little sucker will suck really fast at the start and probably crush the can way before a fancy lab sucker (capable of much greater vacuum) could. My explaination probably sucks a bit too. (I did a lot of stuff with suction before I hit on the pulser pump concept).
mutantferret says: Nov 27, 2007. 10:55 PM
Thanks for the hard work. I've learned alot.
shortshift says: Sep 24, 2007. 10:57 AM
Thank you for posting this recipe! I was able to draft a vacuum pump quite simply and with the bagging equipment found at Aerospace Composites, I put together a pretty good system for some fiberglass layups that I'm working on for my motorcycle project.
Here's a fuel tank prototype that I've been working on. I used a check valve from what appears to be a fish tank setup (ACP was the supplier). 1/4" neoprene tubing.
drcrash (author) says: Sep 24, 2007. 5:37 PM
Very nice. Keep us posted. Maybe you should do an Instructible on low-end vacuum bagging. I think a lot of people would be interested.
shortshift says: Sep 24, 2007. 6:01 PM
ya mean that hasn't been done yet? wowzers. I'll see about putting something together. Of course I'd cite your vacuum solution as a means to the end :)
Little Dreamer says: Aug 24, 2007. 6:33 PM
Mine made a scraping noise,is that a prolem? Also I don't reccomend an aquarium check valve.
drcrash (author) says: Aug 24, 2007. 9:44 PM
About the aquarium check valve... did you try it and get disappointing results? (Just looking for another clear data point... that didn't work for me, but I was wondering if I just got unlucky and had a bad valve.)
Little Dreamer says: Aug 25, 2007. 1:37 PM
It was a ittle leaky with some backflow. I'm ordering a better one and will post on whether or not it was just my setup.
Little Dreamer says: Sep 7, 2007. 12:18 PM
Yes, a quality check valve improves the setup many times over. $6 on ebay.
drcrash (author) says: Aug 24, 2007. 9:37 PM
Could you give me a little more detail... ? Did you use the same pump? Did it make the scraping noise right away, or after a while? Have you unscrewed the top and pulled out the plunger to see if there's anything obvious wrong?
Little Dreamer says: Aug 25, 2007. 1:39 PM
Same pump, and it made noise right from the start. A little WD40 helped, but I probably need a higher viscosity.
gaiatechnician says: Feb 3, 2008. 12:25 AM
We work in masonry and we now use pam (veggie oil) on our wet saws sliding tables to make them slide better. Pam is way better than wd40 and stays on way longer too. Might be good for the bike pump too!
Little Dreamer says: Aug 26, 2007. 2:37 PM
Actually I pulled the pump out and no scraping. I'll watch it.
1-40 of 65Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
