pocket abacus
pocket abacus
The abacus is a calculation tool that works by sliding beads along columns to represent numbers and to compute arithmetic. Almost any sliding tool used to record calculations can be called an abacus, and over the years there has been many iterations and adaptations of this classic calculator.
For centuries the abacus ruled as the calculator for traders and merchants the world over. Today, much of the world now embraces new technology and the once mighty abacus has been replaced with solar-powered calculators and excel spreadsheets. Yet in some places, the abacus is still used as a learning tool for elementary school students and as a method of calculation for traders.
Though many cultures have used the abacus throughout the years, the two most common types that exist today are the Japanese abacus (called soroban) and the Chinese abacus (called suanpan). The main difference between the two is the Japanese abacus has one row of beads on the top deck where the Chinese has two rows, allowing the suanpan to compute to hexadecimal.
This abacus is modeled after the suanpan.
If you're in the mood to nerd it up, check out some of the other types of abaci used over the years.
The simplicity of this 'computer' belies the complexity of computations achievable. Word on the street is there are techniques to solve for square and even cube root using the abacus!
(this instructable also covers elementary arithmetic, jump to step 7 to see.)
This instructable is entered in the Dadcando Family Fun Contest
Remember to vote for your favourites!
enough talk, let's abacus!
Step 1A brief introduction
a brief introduction
The abacus is placed flat on a table with the columns of 5 beads towards you. The abacus is 'reset' when all beads are pushed away from the center bar.
The upper deck of 2 rows of beads are called heavenly beads
The lower deck of 5 rows of beads are called earthly beads
The beads are counted by moving them up or down towards the centre bar, the abacus is read from left to right and each column corresponds as a zero placeholder (each column can represent a factor of 10). The decimal location is defined by use, or can be marked on the frame (a low-tech option would be an elastic around the frame to indicate your decimal).
The earthly beads (lower deck) are counted up to reach 5, to continue counting one heavenly bead (upper deck) is pushed down to represent 5 and the remaining earthly beads are pushed back down and counted up once again to reach 10. The process is continued on to the next column.
(using the second row of beads in the upper deck is covered in step10).
18 comments
Dec 6, 2010. 3:29 PMTerivia says:
X-mas gift for my Dad!!, don't tell him though.
Dec 2, 2010. 4:53 PMrotarygap says:
What is the plural of abacus?
Dec 2, 2010. 7:09 PMrotarygap says:
I prefer abaci. It has a certain je nais quois.
Nov 29, 2010. 9:22 AMGreth206 says:
Would it be possible to use heavy string/shoelace instead of wire; and string it through, tennis racket style?
Nov 28, 2010. 4:54 AMAnthony312 says:
I can imagine walking up to one of my nerdy friends and say,
"You've got a pocket calculator? WELL I HAVE A POCKET ABACUS!!! You just got served."
Nov 26, 2010. 10:31 AMWicken says:
This is awesome. I have a brass pocket-sized abacus, but I never knew what to do with it. This is a great idea, though
Somehow, I'll figure out how to make this into a baby toy (maybe by altering those pop-chain beads)... since the two geekiest people I know are having a baby. I'm smart, I'll work it out.
Nov 26, 2010. 10:21 AMWhite_Wolf says:
Thank you!
For years I've wondered how this thing worked. Never got around to looking it up online. Never dawned on me that it was like counting in binary numbers. I do that all the time. Like the words....
Thank you!
In binary would look like this.
01010100 01101000 01100001 01101110
01101011 00100000 01111001 011 01111
01110101 00100001 00000000 00000000
:0)
Nov 23, 2010. 4:29 PMHoudinipeter says:
you might want to add the youtube videos of people setting records with these!
Oct 31, 2010. 6:13 AMslava varenya says:
This is calculator of future :) .
Jul 17, 2010. 8:11 AMWasagi says:
Waaaaaaaaaaay cooler than carrying a calculator. Nice!!
Jul 6, 2010. 8:12 AMjolshefsky says:
In step 7, 218.25 is represented on the bottom and the sum, 248.37 is on the top. I think you meant for the images to be swapped so the addition looks right. I read a short book on abacus operation and you might want to mention that digit-wise operations are often learned through rote memorization. For instance, 3+4 is a matter of two quick flicks that yield the result 7. You can increment by 1's to accomplish the same thing, but you'll learn to memorize quick enough.
Jul 5, 2010. 5:08 PMbythenumbers says:
might be a good idea to include a slider to keep track of the decimal point. Still an excellent 'ible.
Jul 5, 2010. 9:01 PMnickodemus says:
The ancient version of the calculator watch :D
Jul 5, 2010. 2:13 PMkcls says:
Cool idea! Great job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
615
Author:mikeasaurus(michaelsaurus.com)
Editor and Community Manager at Instructables, here to help you make fun and inspiring projects! I like mixing old ideas with new and reusing things not for their intended purpose; the results are s...
more »
