3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Super macro photography with a coupling ring
Today is super macro photo day ! Or how to achieve 16x magnification with your DSLR and 'regular' lenses...
I have been trying and doing macro photography for quite some time now and I recently had acceptable results I thought I could share.
The idea is to combine your usual lenses using a reverse coupling ring to obtain high magnification power (16+ times). I took me several attempts to get it right so hopefully this tutorial will save you some time !
I used:
- a DSLR camera (Canon 450D)
- a fancy tripod (MTL 9351B from Giottos)
- a focusing rail ( 20$ on ebay http://www.ebay.com/sch/i.html?_nkw=Macro+Focusing+Rail )
- a coupling ring ( 5$ on ebay http://www.ebay.com/sch/i.html?_nkw=Reverse+Coupling+Ring )
- a 18-55 zoom lens (the one that came with the camera)
- a 70-300 zoom lens (Sigma)
- a quick-and-dirty remote control cable (carved out of old earphones)
Of course you can use other focal length lenses. What matters here is the ratio between your longest and your shortest focal length. In my case 300 / 18 = 16.67 : the strongest magnification power I can achieve with this setup is 16 times+.
Step 1Prepare the camera
Prepare the camera
The purpose of a camera lens is to make the image of a subject smaller (for example you want to shrink the Eiffel Tower to 24x36mm which is the size of your captor if you have a standard camera, or even smaller if you have a camera like mine).
If you flip your lens around then it will act as a magnifier. The idea is to take a picture of this magnified image.
The reverse coupling ring makes it possible to attach the two lenses face-to-face.
The lens attached to the camera must be the long focal length one. The magnification power is the ratio of the 2 focal lengths. In my case I use the longest possible focal length on the primary lens (i.e. 300) and the smallest possible focal length on the secondary lens (i.e. 18). The ratio is 300 / 18 = 16.67
4 comments
Jan 6, 2012. 12:37 PMoracle_clr says:
I put my 50mm f1.7 on the end of my 300mm macro lense and it worked great but if was very hard to focus wothout using a rail
Dec 12, 2011. 11:08 PMmeowludo says:
I think this is actually called a pen.
Good instructable!
Nov 1, 2011. 10:29 PMtylercard says:
Wow, never thought of doing this. I use a Micro-Nikkor 50 mm, with a PB-6 Bellows and SunPak Ring-flash for my micro photography. Check some out here:
http://www.flickr.com/photos/tylercard/sets/72157628033745256/
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:nicoo
