things you will need
liquid latex ( i use brand X)
card stock
Q-tip
trace hand on card stock , if it helps make little tabs to help hold the card in place. cut them out and place in between your finger. the latex really just cover it on there , you are going to have to go over your hand a few times let it dry and go over it again ( try not to let it touch itself it will stick and then your going to have to start over, when it is a little dry but some baby powder or makeup sealer on it this will help so it wont stick to itself .once done you can paint over it with face/body paints .the paints with oil in them gives a better look, the water based ones dry better .
thansk again
you can try curing the latex once applied with diluted acetic acid or vinegar..(spraying works best, i used an old windex bottle)
the latex hardens and will become waterproof and wont tear that easily..
you could infact remove your webbed glove like a glove..
id also suggest adding another layer of latex on to the cured glove to strengthen it.
nice work.. brings back memories
Would it work better if you use some latex rubber gloves that are skin tight like surgical gloves ?
You can get those most anywhere.
For the webbing, a person could use small scraps of rubber roofing membrane to be glued between the fingers either with the latex or perhaps some silicone sealer.
Just be sure to scrub the coating off of the rubber very well or it won't stick at all .
I'm not sure about the material compatibility between the silicone and the latex materials though or perhaps the silicone based latex sealer would be better.
If done right they could even be water proof depending on how they are sealed to the forearms or wrists.
