$100 Super Bright Flashlight for Under $10!
Intro: $100 Super Bright Flashlight for Under $10!
Let me say right up front that inspiration for this Instructable is credited to dchall8 for his Tactical Flashlight Instructable. I thought there had to be an easier way to mod a smaller flashlight with less hardware and one that took less time. I put this one to the test against my Surefire E2 that cost $95.
Watch the video for Test Results! You will be suprised!
STEP 1: Here Is All You Need...
1. Eveready Contractor Industrial Flashlight
Model #IN215WB-S. These are impact-resistant with a heavy-duty casing that withstands a 5-foot drop test on concrete. Resistant to grease, oil, gasoline and solvents. Shock- and corrosion-resistant.
STEP 2: Item #2
STEP 3: Item #3
One (1) Radio Shack KPR112 Krypton Flashlight Bulb
STEP 4: Last Item
5/8" Drill Bit or file.
STEP 5: EZ Steps...
1. Disassemble the flashlight, removing the AA batteries (if installed) and factory lamp. Unscrew the top and then unscrew the small lamp housing to get to the lamp.
2. Install the Radio Shack lamp and re-assemble the housing
3. Drill or file down the ridges inside the flashlight to make room for the 123 batteries
4. Install the 3 Lithium Ion batteries and screw on the bottom.
5. Turn it on!
(Optional: I painted mine black satin to make it look like the real thing...and it IS!)
Here is the video of the whole project along with Test Results! Enjoy!
5. Turn it on!
181 Comments
ReCreate 15 years ago
Shagglepuff 14 years ago
ReCreate 14 years ago
ajax517 14 years ago
@ReCreate: How is changing parts not a mod? If you change the OEM parts on your car is it not referred to as MOD-ified? And not that it matters but who cares if KipKay makes money from his videos? No one is forced to pay and watch them.
jdayer 8 years ago
ajax517, I made this with a maglite 6 cell Krypton replacement bulb (LWSA601) and it melted the flashlight just as quickly as over powering a 6v bulb. Now I use a 3watt 4.5v-9v bulb and 2 14500 batteries. Really easy, and in good flashlights the heat disipation is okay.
Agreed with the second part, though.
TarzanJr 14 years ago
lolzertank 14 years ago
fight4gipper1 13 years ago
I built this, though during the process I destroyed the piece of metal that runs along the flashlight to connect the negative to the bulb.
Is this an easy fix??? Any help??
jdayer 8 years ago
Use 2 3.7v 14500 Lithium batteries and you won't need the drill. Yeah, you lose 1.6v, but, really, is the difference between a 5 cell bulb and a 6 cell bulb really that big a deal? I use a 3watt 4.5v to 6v LED.
ilpug 12 years ago
tiredlumens 9 years ago
ShaunHill 12 years ago
