WokFi - Parabolic Cookware WiFi Antenna!
Intro: WokFi - Parabolic Cookware WiFi Antenna!
We've reached an age when internet access & email should be available for everyone AS A RIGHT. Aside from obvious educational benefits, the ability to port audio, phone calls,messages & even video helps banish the tyranny of isolation & ignorance. Better informed people make for a happier world...
In regions without a wired LAN infrastructure, 2.4GHz IEEE802.11b/g "WiFi" increasingly allows a attractive datacomms pathway at modest end user & setup cost. However (given successful WiFi links are still rather a black art!) it'll be the boring things which will limit success,blow budgets & frustrate. And by boring we mean costly copper cables, specialised connectors, aluminium sections & plates, plastic housings, sturdy fasteners,mount poles etc. Allow $$$ ...
As part of an altruistic 2004 NZ student project,it was realised cheap USB WiFi adapters, in conjunction with reflective parabolic cookware, could offer a cost effective workaround. The USB approach appealed since -
- All the microwave-data decoding is done right in the USB "key", so no cable losses occur.
- Regular cheap USB extension cables (to some 5m) & connectors can be used to locate signal localised sweet spots, perhaps with auditing software such as Netstumbler.
- USB "keys" are cheap (~US$10),although their power output may be low (~40mW).
- Easy swap outs for testing assorted reflectors & adaptors results.
- The USB keys can readily be mounted at the focal point of suitable parabolic reflectors, yielding gains of ~12dB at little cost with just cookware,sieves,woks or the like. Such gains can extend line of site (LOS) ranges to several km.
STEP 1: Inbuilt Laptop WiFi May Only Be Useful With Strong Nearby APs
Laptop inbuilt WiFi may be "screened"- roving USB adapters help find "sweet spots"
STEP 2: Parabolic Asian Cookware!
Reflective devices for 2.4 GHz WiFi abound- pot lids,sieves,lamp shades etc! Asian cookware is sturdy,cheap & easily modified
STEP 3: High School Level Parabolic Maths & a Tape Measure IDs Prospective Cookware !
STEP 4: The Profile of Promising Parabolic Reflectors Can Be Matched to a Hanging Chain
The profile of promising parabolic reflectors can be matched to a hanging chain
STEP 5: Reflecting Sunshine to the Parabolic "hotspot" Also Helps Locate the Focal Point
Reflecting sunshine to the parabolic "hotspot" also helps locate the focal point
STEP 6: Support the USB WiFi Adapter & Lead With a Cheap Garden Hose Connector!
Support the USB WiFi adapter & lead with a cheap garden hose connector!
STEP 7: Suits Site Survey Auditing!
Done- suits site survey auditing!
STEP 8: Portable or Indoor Use- Simple Supports.
Portable or indoor use- simple supports.
STEP 9: Boutique Version- Flexible Lamp Stand. (Netstumbler Shows ~12dB Gain = 4x Range!)
Boutique version- flexible lamp stand. (Netstumbler shows ~12dB gain = 4x range!)
STEP 10: Long Range Work (wok?) May Now Be Possible- Typically Maxing at 3-5km Line of Sight (LOS)
STEP 11: Weather Proofing? Perhaps a Wide Mouth Baby's Bottle?!
Weather proofing? Perhaps a wide mouth baby's bottle?!
STEP 12: Smartphone Based Site Surveying?
With today's smartphone abundance, perhaps use a free app. like "WiFi Analyzer" to survey signal coverage and monitor dish enhancements.
40 Comments
manuka 8 years ago
After some 12 years hosting by Orcon ( a NZ ISP), the original "WokFi" site at => www.usbwifi.orconhosting.net.nz has now closed. Things have moved on since that era, & both 3G cellular & WiFi now seem almost everywhere.
sal876 14 years ago
http://wireless.comxa.com/index.php/wireless-repeater
sn00ze 13 years ago
rovasapyan 13 years ago
..I don't know about you guys, but for me UAWIFI UA3 usb adapter is the BEST.
No other adapter can compare to this baby, it is VERY powerful.
There are few people sell them on ebay, but I got mine directly from mft. website www.uawifi.com price is same.
I also know that it is Made in USA, so at least by buying it I am supporting US workers.
manuka 13 years ago
Muzhik 13 years ago
manuka 13 years ago
!Andrew_Modder! 16 years ago
squirrl para 15 years ago
_soapy_ 13 years ago
sn00ze 13 years ago
tinkertoymania 13 years ago
wgrube 13 years ago
Some suggestions to this topic:
You can easily build your own parabolic dish with cardboard with glued tin foil on it. There's a diagram somewhere on the web, you only have to print it on a A4 paper, cut the cardboard following the lines, glue the tin foil and mount it on the router's antenna. It works nice, but I would use a wok for better durability. Also I would connect the ground wire from the usb cable to the dish. This improves the shielding.
Modifying the laptop's antenna is also an option like in:
https://www.instructables.com/id/Dell-Laptop-WI-FI-High-Gain-Antenna-Mod-Increase--1/
I'm looking for a circuit to measure signal strangth in the WiFi range, this would be nice to adjust the correct bearing of the dish. I'll let you know...
JTomM129 13 years ago
diannagail 13 years ago
uranus_b_hurtin 14 years ago
It really is necessary, I swear!
Just becuz I'm a nice guy!
Goalie1 13 years ago
thecensor 13 years ago
Thanks
Danny
chrism82d 14 years ago
