✔ WATER TUBE LEVEL (from Scraps) ✔
Intro: ✔ WATER TUBE LEVEL (from Scraps) ✔
This is a super easy and fast to make tool and it is 100 % recycled.
This water level is really useful for example when you need to paint a room of two different color horizontally, or you need to find the same level of two things far apart from each over, like two shelfs, or two paintings.
STEP 1: WHAT YOU NEED
You only need two small transparent plastic bottle, a used bike tire (without any holes) and a pair of scissors.
STEP 2: CUT THE BOTTLES
Cut the bottom part of the plastic bottles.
STEP 3: CUT THE INNERTUBE
Cut a piece of the inner tube, long as you need it.
STEP 4: ASSEMBLE IT
Place each open side of the inner tube in each neck of the bottles (like in the photos)
STEP 5: FILL IT WITH WATER
Fill one of the bottle with water, keeping the inner tube without any fold and the over bottle at the same level.
STEP 6: DONE
Is ready!
Is easier to use in two people (or otherwise you need to make an hole in one of the bottle and hang it up on a neil on the wall).
Hold them both FIRM on the wall for few second and mark the water level with a pencil.
The water level is always constant (communicating vessels principle).
27 Comments
VasantH2 4 years ago
nostradonus 10 years ago
Put 1 end in a bucket on the patio table. rubber banded other end to a pole. Placed the pole up against the doorjam such that the bottom of the pole rested where i wanted the top of the deck to rest and marked the water level location on the tube.
Walked the pole/tube to the location of each post. held the pole up until the water level met the mark on the tube. the distance between the bottom of the pole and the ground - that was the length of the post at that spot - minus the thickness of the deck board.
Worked perfectly. Beautifully, elegantly simple. Very inexpensive.
Dutchfreak 10 years ago
marcellahella 10 years ago
HelenaTroy 10 years ago
bpark1000 10 years ago
turtleman1 10 years ago
Royski 10 years ago
AJMansfield 10 years ago
Paul Riehl 10 years ago
Great principle, but for even occasional use it makes sense to simply buy a length of clear 1/4" or metric equivalent I.D. tubing, which can be as long as you like. It's a regular tool that I saw used by workman in Mexico, and now where I live in South America, and probably in much of the rest of the world as well. I've heard it's more accurate than a laser level.
It's revealing that this should be such a revelation to North Americans (presumably the dominant Instructables audience). While we (North Americans, or at least some North Americans) design and make and sell clever things (that require jumping in the Dodge pickup and heading off to Home Depot with credit card in hand), people in poorer countries are simply more clever.
Necessity is the mother of invention ;-)
Jugfet 10 years ago
This method can also be used to give you levels around corners, something you can't do quickly with a dumpy level or theodolite.
DDW_OR 10 years ago
will be made up of garden hose, T-post's, and clear tubing. the two lengths of tubing will have marks every inch. this way i can make the ground have a slight slope for rain run off. the T-Post will be used as support for the tubing. one T-post hammered into the ground, the other mobile, thus one man operation
tkamsker 10 years ago
The workers where fixing an Iron gate to make sure the hinges are in level they used that setup. And funny today at lunch i told my collegue (who is building a house ) about it
simply works
jabujavi 10 years ago
Congrats!
gomibakou 10 years ago
With the bottles it's going to be quite ... hard. A classical solution:
You can use a transparent hose (like used in acuariums or watering. Only that. Then tap an extreme with a finger and fill it with water; only an extreme will be fill until the top (just leave some air in the other extreme). Your water level is ready. The tube needs to be transparet if you want to see where the water level is.
The advantage of using only a tube like this, is you can use it really close to your ceil. It's often used for leveling ceils and walls only few centimetres far from the top of your room (or so close as your finger allows it).
As you said, the easier is being helped by other person. With the only-hose way it's almost a must, unless you attach the hose in some way to the wall that sometimes isn't easy. With your bottles it's much easier.
But I didn't tough about the tips of the ceil...Thanks!
Jobar007 10 years ago
Boat builders have used this technique for years to paint a waterline on a boat when it is being built. It involves using a clear hose though.
I like the story of the boat builders, I didn't know, but it really make sense they were using this method.
