10 Reasons Why You May Be Having Problems Growing a String of Pearls Plant Indoors
Intro: 10 Reasons Why You May Be Having Problems Growing a String of Pearls Plant Indoors
Many gardeners struggle with growing String Of Pearls as a houseplant. Here are 10 reasons why you could be having problems growing a String Of Pearls plant indoors. We want you to be able to grow this fascinating succulent successfully.
STEP 1: Reasons You May Be Having Problems Growing a String of Pearls Plant Indoors:
The soil is too heavy which makes it stay too wet.
Succulents need excellent drainage. Some growers use the same potting soil straight across the board for all their plants or perhaps you’ve planted it yourself. When I repot my String Of Pearls, I use a local succulent & cactus mix which is good & chunky allowing the water to easily drain out. If you’re using a store bought a succulent & cactus mix like this one, you might consider adding some pumice or perlite to further up the ante on the aeration & lightness factor.
Too much fertilizer (too often; too heavy on the ratio) or the wrong fertilizer.
This can cause root burn. I’ve found that succulents don’t need a lot of feeding – just once in the spring & maybe a repeat application if necessary in the mid-summer. I fed mine indoors with the usual: a 1/2″ layer of worm compost topped with a 1/2″ layer of compost in the early spring. Worm compost is my favorite amendment, which I use sparingly because it’s rich. I’m currently using Worm Gold Plus. I use Tank’s local organic compost.
Give Dr. Earth’s a try if you can’t find anywhere you live. Both enrich the soil naturally & slowly so the roots are healthy & the plants grow stronger. If you have any liquid kelp or fish emulsion, those work fine too. There are fertilizers formulated for succulents & cactus but I’ve never tried those. Whatever you use, easy does it as succulents don’t require much feeding.
Frequent misting.
Save that for the air plants. Your String Of Pearls doesn’t need it. Misting leads to rot.
Your plant is in hot, direct sun.
Don’t keep it hanging in a south or west window. The glass gets hot & causes burn. It can be in the room with these exposures, just 5-10′ away from the window, depending on your climate. I live in the Arizona desert with lots of strong sun so my String Of Pearls would have to be at least 10′ away from south or west (even east when it’s hotter) windows. No adjustment for the darker, cooler months. This is true of all houseplants as they rest at this time.
You may have to move your String Of Pearls to a brighter location in your home. And, back off on the watering. If you water your plant every 7-10 days in the summer, then every 14-21 days in the winter will be better. It’s planted in a pot that’s too big. A String of Pearls plant doesn’t have a big root system. A pot that’s too big can cause the mix to stay too wet. The majority of the stems will rest on the mix which can also lead to rot.
STEP 2: These Last 4 Reasons Are What I Believe to Be the Most Important:
Not enough light.
Outdoors String Of Pearls need filtered light or bright shade. Indoors they need strong natural light – a medium to high light exposure to grow successfully. Not enough light + too much water = bye bye sweet succulent.
Planted too deep inside the pot.
I’ve seen this many times where the crown of the plant has sunken down 1″ or more. This can cause the crown & stems to rot out because they stay too wet & the aeration is decreased. It’s best if the crown is only 1/2-1″ below the top of the pot. This, along with too much water, also = bye bye.
Too much water.
This happens much more often than under watering. Simply put, ease up on the liquid love. You want the plant to go nearly or completely dry before watering again. It’s hard to for me to tell you often to water your String Of Pearls because there are many variables which come into play. This post and video on houseplant watering 101 will shed some light on this. You don’t want to keep the plant wet but you don’t want it to go dry for days because those thin stems don’t hold as much water as other succulents do.
The plant was wet when you bought it.
The plant was soaked when you bought it (some big box stores & nurseries water their plants every day) & it never got the chance to dry out. My friend lost a pothos because of this. Most pots have at least 1 drainage hole, so check to make sure yours does otherwise the water won’t flow out. Every now & then, a drainage hole gets blocked. You can open it back up with a chopstick, toothpick, knitting needle, etc
STEP 3: A Young, Healthy String of Pearls. the Top Pearls Are Plentiful & Plump & the Plant’s Starting to Trail.
String Of Pearls is definitely a plant with character and seems to be loved here, there and everywhere. I hope this helps keep yours healthy, happy and looking good!
Happy Gardening!
Nell Foster
3 Comments
Jadem52 6 years ago
I love these plants, Great Instructables!
JoyUsGarden 5 years ago
Me too - & Thank you! Nell
JoyUsGarden 6 years ago
Thank you! I love them too. Mine growing outdoors is blooming again. Nell
