$30 IKEA Camera Slider
Intro: $30 IKEA Camera Slider
A $30 camera slider, no way!
You better believe it.
Here is a way to build a simple. effective, and wildly inexpensive camera slider in about an hour. This slider is simple to build with basic tools and has a weight capacity of 11lbs!
Lets get to it!
STEP 1: Tools
Countersink bit
Vise or clamp
1/4 20 tap
Another smaller tap, I used 2.5mm
And a saw.
You can you hand drills and saws but if you can use a drill press you will find drilling the small bits a lot easier.
STEP 2: Supplies
From IKEA
LEGITIM Chopping board $1.49
KVARTAL Glider and hook $2.00
KVARTAL Triple curtain rail $19.99
KVARTAL Ceiling fixture $2.50
You will also need 2 1/4 20 machine screws about 1/2 long plus a 1/4 or 3/8 machine screw to attach a tripod head or camera directly to the slider cart. Make sure these screws have a tapered as they need to be countersunk completely.
I used 8 3mm cap head screws that were 8mm long to attach the gliders to the cart. Whatever little screws you get for this you should also get a tap for that thread, you may be able to cut the thread with the screws them selves but a tap is only a couples of bucks and will work better.
STEP 3: Assembling the Rail
STEP 4: Building the Cart
This is the hardest part and does require some accurate measuring and drilling, it is simple but don't rush it.
It's time to cut the cutting board. I made my cart 3" x 4" but you may want to alter this to fit your needs.
First mark the center of the cart and the proper sized hole for what you are going to mount on it, I drilled a 1/4" hole. You will need to use a taper head screw to affix your camera or head and you must countersink the screw so that it doesn't touch the rail, if it does touch the rail you will have a bad time.Next we mark and drill the holes for the gliders.
Measure the distance between the slots of the track and mark that on the bottom of the cart, use the center hole you drilled as your center line location. This is the part that needs to be pretty much perfect, If one of the gliders is out of line it will drag too much and make the dolly hard to use, measure three times. After you are absolutely sure your holes are marked where they need to be go ahead and drill them. I chose 3m 8mm cap screws because they are small enough to fit in the holes we will drill in the gliders and I had a bunch of them. I drilled the appropriate sized holes for the screws then used a second drill bit to make the tops of the holes big enough for the caps to recess and sit flush, if you do this be careful not to drill too deep or you will ruin your hole.
Time to alter the gliders. You will need to cut off the little loops, try to cut them as flush as possible that way there will be less sanding to do. You will need to sand these so that they are flat on top, just wrap a piece of sandpaper around a scrap of wood and rub the glider on it, it doesn't take much so be careful so that you don't over sand it. Now drill a hole through them the appropriate size for the tap that you will use to affix them to the cart, tap these by hand and then screw them on. Don't tighten them up just yet, leave them a little loose. now see if it will fit onto the rail. If it goes on GREAT! Tighten the gliders down and try again, you may need to fiddle around with them a bit to get them all aligned but it should be quick.
One more step to go.
STEP 5: Lets Give It Some Feet.
Cut two more pieces about the same size as the cart, maybe a little bigger, out of whats left of the cutting board. Mark and drill 1/4 holes in the centers and countersink the bottoms, push a 1/4 20 tapered screw though and attach them to the fixtures on the bottom of the rail.
That's it! Time for some sliding!
27 Comments
CMParro 4 years ago
All designs are to slide the board over the rail, and this makes a little lack of movement. The skates with this are useful if you hang side down the rail, but is not our case. We need to made a slipper like bearinged ones, correct?
If you cut the bottom of the skates and put a 3mm nut over it, among the skate and the board, the "car" will slip over the rail without any contact.
It will be a softer movement.
Keep u in "contact" (lol).
dj_nme 7 years ago
Minor update is that this track seems to have been discontinued and replaced with VIDGA triple track in the Ikea catalogue.
I'm guessing that the rest of this Instructable would have to altered slightly to fit, but the premise is unchanged.
SayntCigol 8 years ago
This could also be modified to make a decent X/Y Axis for a CNC Bed.
mau85nam 8 years ago
BartholomewH 8 years ago
I am about to purchase a 5d canon mark iii soon and this will sure come in handy!
lovely tip! thank you!
ChristianS4 8 years ago
Great idea! You could motorize it for almost no money just like I did: https://youtu.be/lzpZOZXCGbo
roger.roger.18488169 9 years ago
Control it remotely with this
https://www.kickstarter.com/projects/969220052/cam...
847MicRoss 9 years ago
I wish he made the motorized dolly as well.
If I have to buy the dolly, I will just buy the track with it for $30 or less.
(Time lapse while slowly moving.)
Ultimate Warrior 9 years ago
After looking closely, I saw some jogging of the camera as it slid. WATCH the video closely.
JanaMarie 9 years ago
Good idea!! i have to try it!
focamonca 10 years ago
DerekMellott 10 years ago
The groves are 15mm apart center to center.
please
mabreu francescoli 10 years ago
thank you, i never imagine that, wonderfull and easy to make, very usefull to my works!
Yes sir, It works but only at 16mm and the edges are just a bit off. I have since sold the lens and bought a Rokinon 14mm.
melknoy 10 years ago
Good design and well presented.
Geeks with lasers 10 years ago
I have only one problem with this...
Youre using a cannon ;)
Yes, I'm a nikon user. But brand rivalry jokes asside. I like it, and will be making myself a camera slider like this for my home studio :D thanks for the howto :)
dim162 10 years ago
Great & thank you! I saw there is also a curved rail...
SolidWorksMagi 10 years ago
You can build a camera slider without any drilling, printing etc... just by the Actobotics parts from ServoCity.com ... they even have programmable control systems to control the length of the slide, the speed of the slide and exactly when to start and stop the slide etc...
