3D Print Ball Bearing in One Shot
Intro: 3D Print Ball Bearing in One Shot
This instructable will show you how to make a 3D printing looking ball bearing in one shot.
This bearing consists of 3 parts, the inner race, the outer race, and the balls. Most ball bearings have cage that is pressed in to hold the balls in, in order to print with high success rate, I could not make that.
Modeling Software: 123D Design Desktop
3D Printer: Up! Plus 2
Filament: ABS
Radius Clearance: 0.2mm
STEP 1: Define the Aperture and Outer Diameter
123D Design Desktop is a free, easy to use, 3D modeling program for beginners. If you have not already downloaded and installed it, do so from here: http://www.123dapp.com/design.
Launch 123D Design Desktop, create a circle sketch, diameter was 50mm, extrude this circle to be a cylinder with height = 6mm.
Then, create a small circle sketch diameter was 30mm, extrude it to cut the big cylinder.
STEP 2: Rolled Groove
1. Select the out race circle sketch, click 'Edit Dimension' then edit the diameter from 50mm to 43mm.
2. Repeat the above steps to edit the inner race circle sketch, change the diameter from 30mm to 37mm.
3. Extrude the profile between these two circle sketch to cut the object, it will be split into two pieces.
4. Place a torus still in the same center, major radius was 20mm, minor radius was 2.7mm.
5. Copy and paste the torus in same place.
6. Boolean -> Subtract the torus from out race, then subtract the torus from inner race.
STEP 3: Add the One Slipper
1. Place one sphere at point ( 40, 0 ), radius was 2.5mm.
2. Then select and move the sphere upward in the Front viewpoint with 0.2mm.
STEP 4: Circle Pattern to Add All the Slippers
Select the sphere, circle pattern to layout 20 balls along the groove.
STEP 5: Export to Print Out
Select all the objects, click the information icon in the Attributes Manager display bounding box to you for selected objects, this will be helpful for 3D Printing.
Then, export to STL file and print out.
STEP 6: Upgrade the Bearing
After printed the simple bearing successfully, you also can upgrade the bearing like this and more.
10 Comments
oonnllyy 8 years ago
What material / method was used to print the ball bearings? Thanks
2269678977 9 years ago
Ally Zhao 9 years ago
masprotech 9 years ago
I have seen where someone used a dual extruding 3d printer like a replicator 2x and used a water soluble 2nd media to hold the balls in place while printing then you simply wash it away and are left with a nice looking ball bearing.. Much like this one ... These are great results..I'm going to try it myself
capsulecorp 9 years ago
fronters 9 years ago
very original idea!
Kafukai 9 years ago
Nice.
This is not good for heavy machinery or important auto parts. But for home things mechanism this can be useful.
bartworker 9 years ago
Looks like you just reached the last frontier in 3D printing, great work!
tomatoskins 9 years ago
So Cool! I love all the odd uses of 3d printers you can find here!
rimar2000 9 years ago
Awesome!
