3D Chocolate Printer Made From LEGO
Intro: 3D Chocolate Printer Made From LEGO
Using lego and a few custom components a 3D printer for chocolate is possible. I did this project a long time ago so the documentation is incomplete, but hopefully it will inspire someone to rebuild it and fill in the blanks.
STEP 1: Make a Chocolate Extruder.
These were my first rough plans for a chocolate extruder. Powdered chocolate into a heated barrel, lego worm screws as the slurry pump through an ejection nozzle.
STEP 2: Cut Extrusion Chamber
bandsaw - 1" x 1" x 3" aluminum extrusion
STEP 3: Drill and Reem the Bore Hole for the Worm Screw.
I can't remember the diameter, but it was a close tolerance fit for the lego worm gear (close to 1/2in) Nice thing about lego is that it is super high tolerance!
STEP 4: Cartridge Heaters.
4 x 5W bar heaters to supply the heat to melt the chocolate. I think there are cheaper solutions, but there were convenient and fit nicely in 1/8in holes.
i got mine from watlow:
http://www.watlow.com/products/heaters/ht_cart.cfm
STEP 5: Interchangeable Nozzle and Set Screw
I put an interchangeable nozzle and set screw in the end of the chocolate extruder. the idea was this would make it easier to change the diameter of the chocolate bead being extruded as well as making it easier to clean out the chamber as necessary - like when chocolate melts solidly inside it...
STEP 6: Cartridge Heater Positions Around Extrusion Chamber.
i placed the cartridge heaters around the extrusion chamber like so. I need a jobbers drill bit to drill the 1/8in holes deep enough.
STEP 7: Fully Assembled Extrusion Chamber.
again, in theory the lego thermometer and programmable brick should be enough to do the chocolate control, but i used the PID and thermocouple because i was just interested in proving the concept and i had those lying around my lab.
STEP 8: Testing the Extrusion Chamber
Here i am testing the extrusion chamber.
STEP 9: Build a Lego Gantry
I can't remember all the details, but it's pretty simple. i used rack and pinions for the X and Y axis gantries.
there are lots of ways to do this. You really want z axis too. i hacked the Z axis by using a layer by layer increment ratchet that was mechanical. given the memory limits of the PCX bricks, one layer was about all you could program before having to upload a new layer code anyway.
STEP 10: Lets Build Some Chocolate Stuff!
Here's the finished (well, you know, in a rough prototype kind of way) printer.
there are only 3 controllable ports on the rcx brick i used, so one for x, one for y, and one for the extrusion control. you'd need to gang two rcx bricks to further control temperature and the z axis.
I did end up doing 5 layer builds of 3D things like the letter A. unfortunately without a release / support material the geometry is limited, but it was still cool.
hopefully someone will rebuild this and simplify it.
81 Comments
linda.johnson.3367174 9 years ago
Hello! We love Lego's and we also have a small chocolate business. I'd love to discuss a collaborative project. Contact me. linda@chocologyunlimited.com
fluctuat 11 years ago
Greggers1 9 years ago
a year ago i know but..... pressurize the chocolate rater than melt it? i remember seeing a cool idea ages ago about putting chocolate through a plastic injection molding machine... the result chocolate is fluid a high pressure but sets quick. this was an idea to aid chocolate manufacture and de-molding times but might work in a 3d printer :)
RobertGoldring 9 years ago
i work with chocolate quite a bit and pressurized chocolate would be perfect for that.
hhmmmm, i feel my cnc router/plasma cutter project taking a side step. I think i can make a safe machine that can cut both metal and plastic with out setting the place on fire but the chocolate might have a few chips in it.....
Jacky P 10 years ago
maxiwatt 11 years ago
captain Jack 11 years ago
ProCactus 12 years ago
If someone makes a chocolate printer, You would think they had an example.
Maybe" Step 10 - Lets build some chocolate stuff!" is not finished?
geckomage 12 years ago
dscott4 12 years ago
I would love to see your project in the 3D print group I have just started!!!!
https://www.instructables.com/group/3Dprint/
bgepp1 12 years ago
darthpotato1 13 years ago
scistone 12 years ago
:D
njolley 13 years ago
twighahn 13 years ago
I am a doofus 16 years ago
TacoTormentor 13 years ago
kiamokh 14 years ago
