3D Printed Lamps by Samuel Bernier, Project RE_
Intro: 3D Printed Lamps by Samuel Bernier, Project RE_
A few months ago, I started exploring the capacity of low cost 3D printing.
Using a small 3D UP! PP3DP http://www.up3dusa.com/
I started producing house products with a little design touch. I got to learn the capacities of this incredible technology and wanted to push the machine to it's limit. The goal was to produce a functionnal, yet aesthetic object that would use the entire UP! printing area , use a minimum of material, require no support and be mixed to existing standard objects (following the idea of Project RE_ https://www.instructables.com/id/Project-RE-by-Samuel-Bernier/)
I then designed this collection of lampshades that can be screwed unto any threaded suspension kit.
The materials used are ABS and PLA. A designer lamp like that cost hundreads of dollars. With open source design like Project RE_, you can produce them yourself for only 4$ a piece!
Printing time varies between 3 to 9 hours.
Have fun!
(sorry, I had to remove the 3D printing files for professional reasons)
Have fun!
STEP 1: What You Will Need
IKEA suspension kit : 5$
60w incandescent Light bulb or fluocompact
A 3D printer with minimum a 5.5 inch x 5.5 inch printing table
I work with an UP! PP3DP and I think it Does a WONDERFUL job for only 1 700$
STEP 2: Choose a Model
I already printed 5 different models, all with the same shape, but different patterns.
STEP 3: WIRES
This one is my favourite, but unfortunatly... the file is too big. You can find it on Thingiverse : http://www.thingiverse.com/samuel
STEP 4: DIAMONDS
STEP 5: DOTS
STEP 6: STRIPES
STEP 7: SQUARES
Some models may cause problems. The square lamps shade had some problems printing and skipped a few layers. Instead of trowing it away, I decided to re_glue the unfinished parts into an other design. See picture below.
STEP 8: Spiral
This one was never produced because of its complexity. If you want to try... go ahead!
STEP 9: ROOTS
Still working on that one.
10 Comments
kaju666 5 years ago
yeah nice lampshades, but if there is no stl files this instruction is uselesss
PatrickN8 8 years ago
wow i really love these lamps.. :) When the links got removed here where can i find them now ?
Looking forward to hear from you :)
fragor 10 years ago
The Green Gentleman 11 years ago
Lindie 11 years ago
Samuel Bernier 11 years ago
megaduty 11 years ago
amandaghassaei 11 years ago
randofo 11 years ago
