5 Minute Electric Bicycle
Intro: 5 Minute Electric Bicycle
* Since you asked, here is a link to a video of the bike in action.
http://www.youtube.com/watch?v=mJ98oZ8h4HQ
this is my first instructable so please point out any mistakes.
For this Instructable you will need the following materials
-a bicycle
-a cordless drill (any voltage will work but the bigger the better. I got mine from harbor freight for $15.)
-lots of zipties (how many you will use depends on your type of bike and/or drill)
-a piece of small wood ( this will support the drills' battery)
-a bicycle hand brake ( this is for the throttle system)
-bicycle cable ( this also for the throttle system and goes into the hand brake)
That's It!!!
STEP 1: Adding the Drill
STEP 2: Ziptieing the Drill Down
Step 2
Now begin to ziptie the drill onto the bicycle frame. Make sure that the drills' chuck always stays on the side of the tire. Try to keep the drill in line with the tire. Get the drill as snug AS POSSIBLE against the side of the tire. The more friction you have the better the drill will grip the tire.
STEP 3: Adding the Throttle System
STEP 3
Combine the hand brake an the cable and the slide the hand brake on to the handlebars of the bicycle. This will probably require removing the handlebar grips. Finally, tighten down the hand brake.
STEP 4: Attaching the Throttle Cable
Step 4
Beware this is the hardest part of the instructable. Take the bicycle cable and lead it down to the side of the drill where the trigger is. Ziptie the end of the black part of the cable to the SIDE of the drill. Wrap the metal part of the cable around the trigger and back to the side of the drill. Ziptie the black part of the cable and the end of the metal section of the cable together. Make sure that the cable does not pull on the trigger. It should only pull on it when you pull on the brake handle. You can skip this step and just pull the drills trigger with your hand. however you have to drive with one hand.
STEP 5: You Are Done!!!!!
You are done!!!!!!!! Hooray!!!!!! However there is one big declining factor in this instructable, You cannot COAST. This bike also doesn't have a whole lot of economical value it only goes about as fast as a rather drained barbie jeep. It is more just for fun. Or it can be used for riding around the block and laughing maniacally and scaring little children all at the same time!! Or looking cool while trick or treating. Maybe it does have some economical value. Just remember to use a drill that you don't use a lot. I got mine from harbor freight for $15. Here is a link to the video of my electric bike. http://www.youtube.com/watch?v=mJ98oZ8h4HQ
59 Comments
ManuelP41 8 years ago
DamascusSword247 3 years ago
liammccayy 5 years ago
Sedgseb123 7 years ago
I can't get enough friction between the drill and the tier
Classybro 8 years ago
what is the speed of your bicy
alfianyudi 9 years ago
nice instructables,maybe you can use a box for housing the drill
griffenjoy1277 9 years ago
milesnorth 10 years ago
Papydom 10 years ago
Bremer1281 12 years ago
jackjackboom 11 years ago
jackjackboom 12 years ago
killerjackalope 11 years ago
best use of $15 ever.
mikecraghead 12 years ago
I'm doing something similar (an 'ible is in the works, of course), using two of those exact same cheap HF drills, but with lawnmower wheels stuck to them... Here's the vid that got me going on that idea: http://www.youtube.com/watch?v=grcskPrbsvI
Mine will be completely removable (so I can pull it off the bike while I'm at work, for recharging & security), plus I'll be able to engage it on the fly so it's just power assist; can still coast and pedal. Only cost is $50 in drills and wheels, the rest is free, scavenged...
abstracted 12 years ago
tell me when you get it posted!
rocketlauncher 12 years ago
RL
