555 Timer Flashing Led
Intro: 555 Timer Flashing Led
This circuit uses the 555 timer in an astable operating mode which generates a continuous output via Pin 3 in the form of a square wave. This turns the LED (D1) on and off. The speed at which the LED (D1) is turned on and off is set by the values of R1 and R2.
STEP 1: Circuit 555 Timer Flashing Led and Pin 555
R1: 1K
R2: 470K
R3: 1K
D1: LED
C1: 1 uF
and 555 Timer
R2: 470K
R3: 1K
D1: LED
C1: 1 uF
and 555 Timer
STEP 2: Making!!
the first thing to do is take a 555 timer, and put it on the breadboard.
you should have 2 wires that can connect pin 2 and pin 6 with the second wire connecting pin 4 and pin 8th
After that put a resistor from 470K to pin 6 and pin 7th
Another resistor of 1K put on Pin 7 and Pin 8th
Capacitor of 1uF put a minus (-) to Pin 1 and the plus (+) to Pin 2nd
The third resistor of 1K put on Pin 3 and the other end to connect with the plus (+) to the LEDs.
Since LED (-) put the first pin
Now at the end of a 9V battery, connect the plus (+) to pin 8 and minus (-) to Pin 1st
STEP 3: Finished Making
In the end, you can turn your 555 timer Flashing LED.
I hope you like it. Leave COMM and VOTE
10 Comments
Sy333 7 years ago
can i use any value capacitor ?
also can i power it with 5v ?
alilovic007 7 years ago
1uF , 5-10 V
Sy333 7 years ago
ChristieK8 7 years ago
Great project!!!
nitishdash2010 9 years ago
I tried manipulating some values and i could evrn control the flashing rate by replacing the resistor in between pin 7 and pin 8 with an LDR.....
In the dark, led flased slower and in light it flashed very fast.....
audreyobscura 9 years ago
Nice job with your build - thanks for sharing it on instructables. What do you think you are going to publish next?
alilovic007 9 years ago
Now I make Inverter 12V to 220V, I do not know whether posted on Instructables
Mattchu 9 years ago
Going to try this, new to electronics so used circuit wizard to simulate a run with good results. Due to the schematic that is posted and the pin layout thought this may help other newbies. Will post working circuit once complete. Great tutorial.
PRO DR MR BOB 9 years ago
what program did u use to make this?
jconell1 9 years ago
