72 MHz to 2.4 GHz RC Radio Conversion
Intro: 72 MHz to 2.4 GHz RC Radio Conversion
Radio: Airtronics VG6000
2.4 ghz DIY kit: Corona 2.4Ghz DIY Module & RX (DSSS)
This Instructable requires basic soldering knowledge, check out this instructable for some soldering help: How to Solder
Tools:
Screwdriver (Phillips)
Soldering iron and solder
Drill and drill bits
Helping hand for soldering assistance
Needle nose pliers
Voltmeter (or multimeter)
Hot glue gun
Oscilloscope (optional)
STEP 1: Step 1: Test Default Radio
Before modifying anything I recommend testing the 72/35 MHz connection with an existing RC model. Knowing the default radio/receiver configuration works can be helpful later on when troubleshooting any modifications you make to the radio.
Test all the channels and try some long range tests, this shouldn't be a problem if you have been flying already.
STEP 2: Step 2: Disassemble Radio
Remove the antenna, channel crystal, and front face of the radio if possible to more easily access the circuit boards.
Now remove the screws on the back, and unscrew the trainer port so that you can fully separate the front and back case sections.
STEP 3: Step 3: Identify Connections
There are three connections that you will need to identify:
1. Voltage, or V+
Use a voltmeter to find the voltage. Look near the battery or switch, and look for the larger solder connections.
2. Ground
Labeled in several places on my radio, you may need this to ground the voltmeter when measuring voltage.
3. PPM, which is the transmission signal sent through the crystal to the receiver.
If possible use an oscilloscope to find the PPM signal. I did not have one but did some searching online and found that someone already identified the connections.
Many radios have an entirely separate circuit board dedicated to 72/35 MHz transmission. If you can find this board the job is much easier since you can just find the wires connected to it. There should be at least three wires going to this board.
STEP 4: Step 4: Connect Module and Switch
First I would recommend drawing a rough circuit diagram so you have an idea of what connections to make.
Once you have a good idea of where your connections are, begin soldering the wires into the radio and switch connections.
You will also need to solder the antenna wire onto the 2.4 GHz module. Solder the inside portion of the antenna to one solder pad, and the outside section to the other solder pad.
For this project, I tried to completely isolate the power and PPM signals between each module frequency with the flip of a switch. I was not fully successful due to having to remove the crystal for 2.4 GHz mode. In the future I would like to figure out how to completely isolate the power from the 72 MHz mode to cut down on battery consumption when using the new module, and to allow the crystal to be installed when in 2.4 GHz mode.
STEP 5: Step 5: Test Modules
Before assembling anything or making permanent modifications to the radio I highly recommend testing everything first. This allows you to make changes or troubleshoot while everything is accessible.
Test all channels up close and at long range.
If everything checks out then move on to the next step!
STEP 6: Step 6: Mount Module and Hardware
Begin this step once you are sure both modules work.
Use the provided template to drill holes for the binding circuit in a good location. Use 5/32 or 11/64 inch drill bit for the LED and button holes, and use a 5/64 or 3/32 inch drill bit for the screw holes. This kit comes with six nuts and two screws. Use one nut on each screw to secure them to the radio case. Then use the other nut to adjust the height of the circuit board, install the circuit, and use the remaining nut to clamp the board to the previous nut. Tighten them together to hold the binding board in place.
Use a 1/4 inch drill bit for the switch and antenna holes.
Mount the module, wires, and antenna to the radio case or radio circuit board with hot glue or epoxy. This is a little tricky because the radio case must be partially closed due to the wires already being soldered on at this point. If mounting anything to the radio circuit board, make sure to use a thick piece of plastic to separate them before gluing.
STEP 7: Step 7: Double Check Before Re-assembly
Once everything is connected and mounted, test both modules again before final assembly.
STEP 8: Step 8: Reassemble Case
Close up the radio case (slowly) using a light to make sure nothing is being crushed or blocked by the newly installed module and wires. Glue or bend any remaining wires so they are out of the way. Check the stick movement to ensure nothing is blocking their range of motion.
Now install the screws on the back.
Before installing the original antenna, look into the hole to make sure no wires are blocking the passage.
Install both antennas, the transmitter crystal, and the battery (Leave it unplugged when not in use).
STEP 9: Step 9: Other Resources
I scoured the web for hours trying to find information specific to my model and found many great resources along the way. You may need a few more specifics than I can provide in my Instructable for your radio model. Here are some resources I found that will hopefully make this process easier and save you some time.
Converting old transmitters to 2.4GHz using 'hack' modules
Futaba T6X upgrade to 2.4Ghz with the Corona 2.4Ghz DIY Module (DSSS) CT8Z
Airtronics VG6000 2.4 ghz conversion
Help with Frsky into Airtronics please
Adding a Corona 2.4gHs system to a old 72mHz JR TX
Sanwa RD6000 Super Conversion to Frsky 2.4GHz
STEP 10: Optional Upgrades
If using an older radio, I highly recommend upgrading the battery to a Lithium Iron (LiFe). At 9.9 volts, it is designed for radios, but you need to make sure that your charger is able to charge these. Also, don't try charging this new battery with the default wall charger that comes with the radio.
All done!
7 Comments
Invetor Emma 2 years ago
Samuel SatyaK 7 years ago
i am impressed.steps are easy to follow even for a non specialist.
Salman Naveed 9 years ago
This is impressive work! I did not know if converting frequencies was possible, but it is! Thank you, this was a great help!
Daedalus62 9 years ago
Excellent and well detailed 'ible... I have an old 35mhz Futaba SkySport 4 just crying for this. To the to-do-list. Thanks!
florlayamp 9 years ago
Great instructable! so what is the benefits of converting it up to 2.4ghz over the <100mhz? Is the range better at that frequency?
Cheezwedge 9 years ago
seamster 9 years ago
Wow, this is really impressive stuff. Thank you for taking the time to put this all together to share here. Great work!
