A Drafting Table Made From an IKEA Coffee Table
Intro: A Drafting Table Made From an IKEA Coffee Table
No laser cutter? No CNC machine? No 3-D printer? Fear not comrades, this is an instructable for the everyman.
This instructable is meant more to inspire than to copy, as I believe most instructables tend to do that anyway, not to mention the fact that is seems unlikely that you would buildĀ this table to these specs.
That being said, I'm a college student and I recently needed a better work surface, and fast. I had weather beatenĀ scrap wood and an IKEA coffee table top I found in my garage.
Here's how it goes.
Here's how it goes.
STEP 1: Lubricate
A handful of these'll do.
STEP 2: Pool Your Resources and Scheme
Now that the anxiety is gone we can concentrate. Now, what do we need, and what's on hand?
I used this IKEA/ Rubbermaid getup for about 6 months, not bad but definitely not preferable. Let's see what happens when we check our inventory.
Measure everything and break it down mentally and through notes; there won't be much wiggle room.
I think we can pull it off.
STEP 3: Getting Started: the Base
Begin with the base. It needs to be able to clear my office chair's armrests, about 31." The mechanism needs to clear 31," as you'll see shortly. Interestingly enough the base is almost a cube at around 32 x 31 1/2 x 31 (abouts). The table top is around 34 x 42.
Oh, and when working with wood like this Pre-drill everything. I pre-drill everything anyway. Also, you'll notice I'm not using wood glue, as I want to have the option to break it down readily.
STEP 4: The Table Top and Mechanism
So we've reached the juicy bit: how it works. Check it out.
STEP 5: Glory
Now it's time sit back, relax, lose your mind over deadlines at your new drafting table.
16 Comments
landru 9 years ago
very nice. my old man helped me make a similar design after i got an A in my high school drafting class. we used a pair of springs (one on each side) to help hold the notched parts in position. the idea was to make it a bit less likely that your knee might bump it out of place accidentally, causing the top to drop suddenly.
3x10EE8 6 years ago
lucky I would have killed to be able to take a drafting class in high school
connie46 9 years ago
666sebas999 9 years ago
Is there an instructable for the chair? I'm in love with that chair
plasticpopcorn4 9 years ago
thanks for this instructable!!!! almost done with mine. tried making a drafting table a few years back but didn't like my tilting mechanism. This gave the push/ how to to finally make it
crackHacker 11 years ago
edwardlarson 11 years ago
doppelgangerbot 11 years ago
Retro Correct 11 years ago
Penolopy Bulnick 11 years ago
profpat 11 years ago
andreaki 11 years ago
audreyobscura 11 years ago
scoochmaroo 11 years ago
