A New Workbench
Intro: A New Workbench
The Getting Started In Woodworking (GSIW) Workbench is cheap and easy to build. If you have a circular saw, drill, router and a need for a decent bench I would highly recommend giving this one a shot.
Detailed instructions (including video) can be found over at finewoodworking.com, so I won't go through it step by step. I'm just going to point out the more clever stuff.
http://www.finewoodworking.com/item/18985/still-dont-have-a-workbench-this-one-is-easy
STEP 1: Routing Channels for the Allthread
This GSIW bench is held together with allthread laying in channels. Here's the set up they recommend for holding the 2x4s. I also added a strip of trim underneath to give a little more height.
STEP 2: Cut the Legs at the Same Time
It's a no-brainer right? it'll take two passes to get through the 4x4s.
The cutting guide is a piece of hardboard w/ some 1" trim stapled to it. These guides are easy to make and save a lot of time.
STEP 3: A Nice and Sturdy Base
Here's the base assembled.
You don't have a lot of room for error when you drill your holes for the allthread in the legs. So, if you don't own a set of brad point drill bits consider picking up a set. I've found they're much more accurate than regular wood bits which always seem to travel off the mark a little before they begin to bite.
Note the top rails have two channels. The bottom is for the allthread, the top for the S-brackets you'll use to to attach the bench top. Strangely I couldn't find these brackets at Lowe's or Home Depot, but they were at Woodcraft and for once weren't overpriced.
STEP 4: Layout the Top
You should both glue and screw the top to ensure a good tight lamination between the layers of MDF. Pilot holes and countersinking are your friends (as always). If you don't own a countersink bit use the largest drill bit you have and just touch the pilot holes lightly.
The layout is important when it comes time to drill bench dog holes so don't just go randomly driving screws all willy nilly.
STEP 5: The Vise
This thing is great. It's a Groz 7" rapid action. Worth every penny. The pic is before I attached the jaw liners.
For the block underneath I used a scrap piece of MDF and an additional piece of hardboard.
16 Comments
joshuallen 11 years ago
fredellarby 12 years ago
Mine is similar with 2 doubled heavier legs at one front corner to support a 5" metal vice,and a doubled leg in the center/front where I do most of my heavy pounding
The nice part is when the top gets too messed up, you can just add a thin layer of hardboard to the top for a whole new surface.
If you buy your top as a 4'x8' sheet, you can cut a slice off the 8"side for a shelf underneath.
_diyMATT 12 years ago
I was reading it over and I noticed all of a sudden that I knew you. Lol. can't say that's ever happend to me before.
jimbotheconflictor 12 years ago
rusty0101 12 years ago
One suggestion would be to move the vice from the front of the bench to the end of the bench. That way you have the entire bench to work with for putting in bench dogs if you are going to work with longer panels. Most of these vices support having a taller 'front' block that in combination with a flush back block allows you to use the entire work bench as your vice, rather than just the 7" throw that the vice has (minus the thickness of your vice blocks.)
That said, I need to get on the ball with making my own bench. Probably more for general projects including metalwork, but from the looks of this, it's a great starting point.
Thanks for the incentive.
jdege 12 years ago
1st. I don't think MDF makes a sufficiently durable top. Allen added a sacrificial layer of 1/4" hardboard, and I think that'd make a huge difference.
2nd. Allen used three layers of MDF, resulting in a top that was 2-1/2 inches thick, as opposed to Christiana's 1-1/2". That extra thickness means you can pound on it anywhere, instead of only over the legs.
3rd. When Allen places the shoulder vise flush with the front of the bench, rather than extending out 1/2". That makes it possible to use the vise to clamp material across the front of the bench.
steambc 12 years ago
Tell me, what do you mean by mounting the vise flush instead of 1/2" extended? I haven't bought my vise yet and I'm wondering why one would decide to extend by 1/2".
Thanks!
jdege 12 years ago
In the latter, the inner face of the vise is in the same plane as the edge of the top and the front of the legs. This means that you can use the vise to clamp long pieces across the front of the bench, and have the pieces supported across their whole length:
If you were to do this with the Groz vise as mounted above, there would be a 1/2" gap between the board and the edge of the bench - making it much less stable.
In Allen's book, he inset the vise into the bench by just enough that the face of the vise would be flush with the edge. Christiana left that out, to simplify construction. In my mind, the advantages gained are worth the extra complexity.
jdege 12 years ago
No. Some woodworker's vises are designed to use the edge of the top as their inner jaw, others - like the Groz - have a metal inner jaw.
Allen's book used the Groz, and notched the top so that its inner jaw would fit flush.
You can see my old bench in some of the photos. I wanted to re-use as much of it as possible.
It's interesting you recommend using three layers of MDF w/ a layer of hardboard. I ended up using a scrap piece of MDF and scrap of hardboard between the vise and the underside of the top to get it positioned vertically. So your recommended set up would be perfect for my vise.
I thought about flush mounting the vise too, but I was in a hurry. There's always the next iteration. I'm already thinking of re-doing the top.
Tazo 12 years ago
I agree with you is a great easy to make workbench!
blkhawk 12 years ago
