ARDUINO TEMPERATURE SENSOR LM35
Intro: ARDUINO TEMPERATURE SENSOR LM35
Now make your own temperature sensor by Arduino and LM35 Sensor
You required following parts
1-ARDUINO BOARD ANY VERSION
2-LM35 TEMPERATURE SENSOR
3-USB CABLE
4-COMPUTER WITH ARDUINO SOFTWERE
MAKE THE CONNECTION AS SHOWN IN IMAGE AND UPLOAD THE FOLLOWING CODE ON ARDUINO BOARD.
int val;
int tempPin = 1;
void setup()
Serial.begin(9600);
void loop()
val = analogRead(tempPin);
float mv = ( val/1024.0)*5000;
float cel = mv/10;
float farh = (cel*9)/5 + 32;
Serial.print("TEMPRATURE = ");
Serial.print(cel);
Serial.print("*C");
Serial.println();
delay(1000);
/* uncomment this to get temperature in farenhite
Serial.print(farh);
Serial.print("*F");
Serial.println();
NOW SEE THE SERIAL MONITOR IN THE ARDUINO SOFTWERE ,
ITS DONE.
VISIT https://www.facebook.com/SparkingElectronics FOR MORE PROJECTS
115 Comments
spradana1 10 years ago
We can get value magic number 0.48828125 from following expression:
(SUPPLY_VOLTAGE x 1000 / 1024) / 10 where SUPPLY_VOLTAGE is 5.0V (the voltage used to power LM35)
1024 is 2^10, value where the analog value can be represented by ATmega (cmiiw) or the maximum value it can be represented is 1023. The actual voltage obtained by VOLTAGE_GET / 1024.
1000 is used to change the unit from V to mV
10 is constant. Each 10 mV is directly proportional to 1 Celcius.
By doing simple math: (5.0 * 1000 / 1024) / 10 = 0.48828125
conorb1 8 years ago
peter.mbiria 7 years ago
I think he meant the calibration value. instead of doing all the computation , just get the value from the sensor and multiply it with that value
minimadmalc 9 years ago
Hi Please can you tell me if I was to run this program through a Attiny85 on 4.5 volts what formula would I need to use to get the correct results?
spradana1 9 years ago
you can substitute the SUPPLY_VOLTAGE part which result in
(SUPPLY_VOLTAGE x 1000 / 1024) / 10 = (4.5 x 1000 / 1024) / 10 =
0.439453125
sghosh21 9 years ago
the supply voltage doesn't really matter , i think the analog to digital converter matters though, coz see we can even power the LM35 with a 20 v power supply, if we do that and still read the analog value from arduino, your equation will not hold,
Indeed the supply voltage can ranging from +35V to -0.2V. Well, I got the equation from the LM35 datasheet and never done things outside the datasheet.
LamSwetFan 2 years ago
FargingIcehole 2 years ago
pantou60 3 years ago
tgray1 3 years ago
apangesti 4 years ago
Turned out I got my pins (data and ground) reversed. Now it shows earthly temperature of 30-something degree. The sensor respond well to trial-by-fire as well.
Note to self:
Please double check your connection.
VCC - Signal - Ground
switchthepin 4 years ago
(remember to only switch the positive and grond pin only)
INDHRAK 5 years ago
#include "DHT.h"
#define DHTPIN 2 // what digital pin we're connected to
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
int val;
int tempPin = 1;
void setup() {
Serial.begin(9600);
Serial.println("Reading DHT11 data! ");
dht.begin();
pinMode(12, OUTPUT); // Green
pinMode(11, OUTPUT); // Red
void loop() {
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float hum1 = dht.readHumidity();
// Read temperature as Celsius
float temp1 = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(hum1) || isnan(temp1)) {
digitalWrite(11, HIGH);
digitalWrite(12, LOW);
Serial.println("Error in reading sensor data!");
while (isnan(hum1) || isnan(temp1)) {
else {
digitalWrite(11, LOW);
digitalWrite(12, HIGH);
// Wait a few seconds between measurements.
delay(1000);
float hum2 = dht.readHumidity();
float temp2 = dht.readTemperature();
// Compute heat index in Celsius (isFahreheit = false)
float hic = dht.computeHeatIndex(temp1, hum1, false);
Serial.print("Humidity: ");
Serial.print(round((hum1 + hum2) / 2));
Serial.print(" %,");
Serial.print("Temperature: ");
Serial.print((temp1 + temp2) / 2);
Serial.print(" *C ");
//Serial.print("Heat index: ");
//Serial.print(round(hic));
//Serial.println(" *C ");
//lm35 code
float cel = mv/10;
Serial.println("");
Serial.println("Analog sensor Reading !");
Serial.print(cel);
Serial.print("*C");
Serial.println();
Serial.print("Error = ");
Serial.print( ((((temp1 + temp2) / 2)-(cel))/ (cel))*100);
Serial.println(" % ");
Serial.print("Corrected output:");
// Serial.print(( (temp1 + temp2) / 2)+(( (temp1 + temp2) / 2)-(cel)));
Serial.print(cel);
Serial.print("*c");
Serial.println("");
Serial.print("-------------");
Serial.println("");
delay(1000);
if ((round((hum1 + hum2) / 2))>40)
//Serial.println("NEW VALUES");
digitalWrite(9, HIGH); // if high humidity on indication
digitalWrite(8, LOW);
else //if ((dht.readHumidity()) < 1050)
digitalWrite(8, HIGH); // if low humidity another indication i.e. motor on
digitalWrite(9, LOW);
BHADRESHT 5 years ago
Please tell me
const int temp = 0;
void setup()
Serial.begin (9600);
pinMode (temp, INPUT);
void loop()
float Real_Voltage = analogRead(temp)* 0.004882814;
float Temp_C = Real_Voltage * 100.0;
float Temp_F = Temp_C * (9.0/5.0) + 32.0;
Serial.print(analogRead(temp));
Serial.print("Voltage: ");
Serial.print(Real_Voltage);
Serial.print("Deg C: ");
Serial.print(Temp_C);
Serial.print("Deg F: ");
Serial.print(Temp_F);
if ( Temp_C >= 135.0)
Serial.println("Warning: The system is hot");
delay(1000);
else if (Temp_C
Serial.println("Warning: The system is cold");
delay(10000);
else
Serial.println("The system is functioning well ");
delay(10000);
But it's output generat without connect lm35 to Arduino Uno r3
In range of -12 to 460
MOUNIKA DATTA 9 years ago
I m getting d output as 132.34*C .....in ds pattern nly but not as 23*C n all...wat crctns can I make ????
TAPAN MOJIDRA 8 years ago
kepp it as short as possible
gabimal_ro 6 years ago
Hi,
It is short, actually I have inserted the output pin of LM35 directly into the board. Same high readings,+140 degrees. Any idea why?
TAPAN MOJIDRA 9 years ago
see the picture and connect exactly as shown in image
IanV48 6 years ago
wow
